Hello, I have a GX85 and wanted to experiment with old film c-mounts. Like the Kern Paillard. It seems like 25mm+ is the safe zone, is that correct? I just don't want too much vignetting. Thanks!
Search the forum, lots of threads about c-mount lenses. In some of them this spreadsheet is mentioned: https://spreadsheets.google.com/pub?key=p9kkgjwEQQQ-HJwvNDobeEw
@thebmillz I used a 26mm f1.1 on the GH1 and had a little darkening in the corners of the GH1's Multi Aspect Sensor (MAS). I think the were Panasonics don't have a MAS so there's a little more cropping (= less vignetting) then there was on the MAS of the GH1 and GH2 generations.
It's actually the image circle of the lens that's creating the vignetting, not the focal length. C-Mount lenses cover a wide range of sensor/film sizes, so you get vignetting if a lens can't cover the entirety of the sensor. I usually search on Youtube to see if anyone else has used the same lens/camera setup as I do before buying it. And here's a list of C-Mount lenses with their image circle sizes: http://www.filmcentre.co.uk/faq_ic.htm Good luck!
