GH4 Firmware 2.3, V-log for $99, Epic Panasonic marketing fail
  • 1451 Replies sorted by
  • @Brian_Shiano You can use Filmconvert vlog as technical LUT, and then, you can add -as output- any another creative LUT ( premiere workflow)
  • I finally had a chance to experiment a little with Vlog, and it seems like a tradeoff of ability to me. The gain is that we get an extra stop of sensitivity at the upper end, which means that if we overexpose by a stop or two, we gain a wider range of sensitivity.
    But the loss is that this wider range is compressed into a smaller range of values, and stretching those values across the full range of output means there's a risk of banding-- less so if we're shooting in 10-bit, but I can't afford a 10-bit recorder just yet. So, I didn't see a huge improvement in the Vlog footage, but that may be due to my shooting a basic street scene. I'm not sure if I'll be using the Vlog unless I'm certain I know it's getting me good skin tones.
    The LUTs I played with in Premiere Pro were the Alexa LUT that came with PP (Alexa Default Log c2Rec709) and the two Vlog LUTs that Panasonic makes available (Vlog to 709 for v35 and Vlog to 709 Varicam). The Alexa LUT seemed to bring the Vlog footage very close to the footage I shot in Standard mode: the Panasonic LUTs were similar, but didn't bring the darkest areas to black.
    Any recommendations for good, clean, basic LUTs to use as a basis for color correction?
  • @arronchicago, I'd like to try your workflow, do you know where I might download that Cineon to film LUT? One that will work in FCPX, Resolve LUTs do not...thanks
  • @Tjabo, just to clarify that you are correct - zebras can be set up to 100% but they do not function passed 80. I think I confused myself when shooting - thought I was using zebra 1 at 100 but in fact zebra 2 was selected, set at 80 and that does yield good results even though Camera meter may be over exposed a stop or two. I am wondering now where to set the spare zebra for average caucasian Skin Tones? Perhaps around 45 to 50%
  • Yea ... my version is the "free" one they used to provide ... 1.0.1 ... and it only works with sporadic LUT's in 2015, doesn't even "show" most cube's in a folder. And um ... $799 for that and the rest of the package would in some way be nice but hey, in my business, it ain't justifiable.
    Now ... in CS6 and even into CC, that LUT Buddy version worked fine. Sigh.
    Neil
  • @rNeil That's funny, it seems to work fine in PrPro CS5.5... ;)
  • @LPowell
    I've got LUT Buddy installed ... but in PrPro 2015, the little thing doesn't allow me to apply most of the LUT's that even shipped with PrPro, and ... most often ... leads to a crash of the program. I've used it in the past in Ae to good effect, both to apply but especially to "draw" a LUT from a grade.
    But now, in 2015, the thing just seems broken.
    And yea, I hear you on the 'consumerize' thing ...
    Neil
  • @rNeil Thanks for the props, and your info on Lumetri. I respect Speedgrade for those who like its workflow, but despise Adobe's attempts to consumerize its formerly professional tools. (Don't get me started on "Process 2012").
    For an Apply LUT plug-in you might find Red Giant's free LUT Buddy useful. I use it in AE to crunch entire adjustment layers into a quick lookup conversion:
    https://www.redgiant.com/products/magic-bullet-lut-buddy/
  • @balazar
    I've put in a feature request with Adobe for Prpro to have an RGB-space color correction tool to work properly with the GH4 log correction ... anyone else is welcome to put one in also. Oh and also for a simple "Apply LUT" effect also.
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Neil
  • @LPowell ...
    Personally, I love working in Sg ... once I understood what the OFFSET/Gamma/Gain controls of the color wheels there do, and when I like to cut to sliders instead of wheels ... and since my Kensington 2" trackball w/surround ring and four paddles works so nicely with the wheels ... click in a wheel, the ball handles chroma & slider the luma without re-clicking on anything. There's a few things I'd want changed ... AHEM! ... but in all, it's a great start ... and I'm MUCH faster and capable of so much more there than in PrPro or Ae. With any of their tools.
    I don't distrust the Lumetri panel/workspace in PrPro at all ... just as always, wanted to know precisely how and in what order it 'works' ... as those things DO matter. So I'm a bit of a techie-type as far as needing to KNOW how things work, but I think in all not nearly so far out as @balazar ... but I'm very grateful to have him here as he tests stuff even out farther than I'm willing to spend time on! Which is way cool ... we all learn from his work.
    Yours too, by the by.
  • This is what happens in v-log compared to GH4 0-255. This is a theoretical image made in Photoshop.
    1920 x 1080 - 286K
  • @ mrbill, I did a quick comparison and saw about 1 extra stop of DR. 11 to 12. Still awesome.
  • @vesku judging by eye it sure does. It's nearly impossible to see all of the capable DR on our monitors but after awhile you just compare apples. Looks very similar to BMCC DR in my opinion.
  • Yes, it's supposed to be a measurable improvement of nearly 2 stops in dynamic range, according to Ilya From HotRod Cameras
  • Does the v-log really have more dynamic range than for example Natural contrast -5, iDynamic high and some upped pedestrial and curve. In my tests the dynamic range with those settings is near RAW photo and I can get full 255 steps or gradients compared to 160 of vlog.
  • @balazer
    What's needed for basic color correction in a pure log space are offset operations: filters that will shift the R, G, and B values up or down uniformly.
    Can After Effects' Color Finesse plug-in do this for you? One trick I use is lowering RGB pedestals in the Highlight band to recover superbright channel data without altering shadow and midtone color balance. I've remained an After Effects fan as I never warmed up to Speedgrade's UI and share rNeil's distrust of Lumetri.
  • @balazar,
    I'll be interested in your results ... Sg's color controls are actually Offset/Gamma/Gain, a little different than other grading apps, though you can select to get over to O/G/G in Resolve rather than their "standard" L/G/G. And of course you can adjust the pivot on all of them, the "overall" controls, and the triple-sets of Shadow, Mids, and Highs ...
    Neil
  • @rNeil,
    Load Fast or Three-Way, got to Basic tab & load your LUT, then go back to the Fast or Three-way "above" that in the Effects panel, and work the controls ... does that get you what you need?
    The problem with Premiere's Fast Color Corrector is that it operates in YUV space instead of RGB space. The Three-Way Color Corrector has that problem too, plus it's just not the kind of operation that's needed for a pure log space. What's needed for basic color correction in a pure log space are offset operations: filters that will shift the R, G, and B values up or down uniformly. And for contrast, you want a linear slope with a 0.5 pivot. Premiere's Brightness & Contrast effect, and the Channel Mixer's Red-Const, Green-Const, and Blue-Const are actually the right idea, except they are only 8-bit and the adjustments are too coarse for an HDR wide-gamut log space. If you want to have a try, here's a little test file that lets you see how operating in YUV space is not equivalent to operating in RGB space: https://www.dropbox.com/s/3aq70zap8tucehm/Gradients.mp4?dl=0 Watch the RGB Parade scope while performing some adjustments to that file.
    I'll give SpeedGrade a try and see if it has the right tools.
  • @tedramasola and @AdamT, thank for your info regarding the zebras. Looks like the 80% value makes good sense!
  • @balazar ...
    PrPro's Lumetri color workspace "panel" is designed to "smooth" things, so they've built new controls not just brought Sg's ones over ... it's an effort to simplify things for the Masses. So depending on the footage, the controls are designed to induce knee & shoulder roll-offs to "protect" the upper/lower values. And remember ... that Color workspace is total Rec709.
    I can understand the choice for the "main market" they're expecting to use that part of the program, but ... it ain't ideal for people with specific "power use" needs. Hence my comments, if one uses the Color workspace, about putting another color-control effect on the clip PRIOR to making ANY changes on the Color controls panel, and putting out-put film/print emulation LUT's on say LUT Buddy effect AFTER the Lumetri panel controls in the Effects Panel.
    The Color Workspace panel's "Basic" tab, that Input LUT option ... that is designed to convert whatever footage you've got into Rec709 workable media. Which is why, again, you MUST have a color effect control loaded onto the clip & in the Effects panel BEFORE doing anything in the color workspace. Load Fast or Three-Way, got to Basic tab & load your LUT, then go back to the Fast or Three-way "above" that in the Effects panel, and work the controls ... does that get you what you need?
    For the stuff you're doing, SpeedGrade would get you the better results ... and be easier to "control". And I'd note ... for a lot of people (though not everyone) ... PrPro & Sg in Direct Link workflows are not as smooth a combo with the 2015 build ... the 2014 pairing is more stable & robust, very little if any lag issues & so on. Now, some people are working in 2015 just fine without lag & such. Some days, & smaller projects, I can do it fine. Other days, it is a bit cranky. Your mileage will vary ...
    But I'd love to have you try the above workflow and see if by using a Fast or Three-way prior to the Basic Tab intro of your LUT's into the 'chain', you can get the proper action of things ...
    Neil
  • Used V Log for a medical company promo. The process is just so easy in my opinion. Add a Cineon to Film Contrast LUT and bam. Every now and then I'll add a little more contrast or saturation, but the LUT usually gets it 90% there.
    1920 x 1080 - 1M
  • There is a very nice analysis of VLogL here -- suggest everyone give it a read: http://www.provideocoalition.com/v-log-l-on-the-gh4-don-t-panic
  • In Vlog, black is clipping around 7% and white at around 80% so set zebras to 80%. and your good with highlights even if you still go over by 1/2 or 1 -1/2. In Adam Wilt's tests he found "Compared to normal gamma curves, V-Log L uses only 73% of the available levels in video-range 16–235 encoding, or 63% of the levels in full-range 0-255 encoding." Its basically same with version 2.3. No difference.
  • ZEBRAS!!
    Hello everyone. Today I received my 100% legit unlock code and installed VLog-L on my GH4 with firmware V2.4. Unless I am totally messing something up, neither of the zebras function at any percentage above 80%. Not at all, no matter how blown out something is... I'm planning to do some testing to see if I can really work with the zebras at 80%, but in the mean time I figured I would just check in here.
    I have seen others, such as @crowbar mention using the zebras at higher than 80% settings, but I just wasn't sure if that was the covert version still being used from before, or the legit version on V2.3 firmware, or what.
    Some really slapdash test footage I shot using only the exposure meter and the histogram provided results as expected, and so far I am happy with VLog. I think I'm going to shoot a little bit of slightly more important footage with it tonight and see how that goes. I'll try to gain more understanding of how the histogram relates to the 80% zebras.
    @balazer, thank you! I haven't used SpeedGrade because I've always been happy enough with what I was able to do manually (3-way color corrector and RGB curves mainly), and I'm still learning -- a LOT, Lol. I really never felt like I should use a LUT before because I wanted to learn about color science. I've gotten pretty good results with VLog samples so far from my manual efforts, so is it a real benefit to use LUTs? If so, I will see about trying SpeedGrade or Reslove.
    @rNeil, thank you also! I have to study your post a bit more to make sure I'm understanding you well. I will try what you said first for PrPro and see how that goes.
  • Hi, @Tjabo. I tried Premiere Pro. Lumetri loads the LUTs, but unfortunately Premiere does not include the 32-bit RGB offset and contrast filters necessary for working with log footage. Some third-party plugins might work, but I don't know which ones.
    Do you use SpeedGrade? I'll try that too. But for now, DaVinci Resolve, FCPX, and Sony Vegas Pro are working fine.
