Anyone familiar on how to check shutter count? I followed directions on how to get to the Temporary Service menu. But when I tried it, all i got was a screen with a bunch of squares with numbers. And if scroll left, right, up or down. Bunch of random numbers and letters appear.
Turn it off and back on, and everything is back to normal. Any ideas on how to do this?
Thanks
@lmackreath I mainly shoot wildlife videos, and those settings seem to work really well for that too.
@lmackreath, I'm not a pro like many of the people on this forum are, but I suspect not too many of the pros care much for on-camera mics (like I don't either, actually).
At any rate, with the VMP I often find that the mic set on +20dB gives me a bit more gain than I can dial down to the preferred level in the camera, and the 0dB setting requires me to have to dial a bit more gain in the camera than I really want to... Having said all of that, both methods seem to give adequate results for what you can get with an on-camera mic. Neither one is great, but both are decent for some people's purposes.
@h2otara, correct me if I'm wrong, but I think Dave's use of the VMP setup like you described is for his video narratives with the mic off-camera on his desk? In that case I would undoubtedly end up using the same setup, because he has the mic pretty close to the subject, in a mostly quiet environment. Should (and does) work very nicely like that.
@lmackreath I set the camera on -12 and the mic on 0, per Dave Dugdale, and seems to work great. He's got a video about using that mic with the GH4.
Depends on how you want to use the Rode VideoMic Pro. For interviews just mounting it on the flash shoe and plugging it in may be enough. For serious Video it may be used only for synching sound but you could use the internal one for that.
Not sure what the range of the Rode is or whether it is effected by Camera or other nearby sounds.
I use an Azden SMX-10 directional, stereo shotgun mic mounted on camera to record the Church Service 20-40 foot away. The results are very satisfactory.
Anyone got experience with using the gh4 with the rode videomic pro?..need to know what the best in camera and rode audio settings to get the best sound
That's just a matter of taste and get used to it... I bought a GH4 and a FZ1000 after that and I find the FZ1000 much more pleasing to use. For instance, I never though I would like to have just one dial since all my recent (Sony) cameras have both front and rear dials, but the way Panasonic implements this, with push bottom ability, I much prefer this control system over dual dial to change shutter and aperture.
That said, the ultimate image quality is in GH4 and that's a relevant part of the equation... :)
ps - I do find GH4 to be smaller than I would like it to be. I much prefer FZ1000 (bigger) size.
truth being told, i do indeed need to have the camera in my hand for a true test obviously. my initial reaction was of course a bit childish. :-) the larger size of the gh4 will certainly be an advantage. using for now the gh2 with metabones and manual nikon assorted glass, and i love the results. the attraction is of course the 4k and maybe a new version is just around the corner...should i wait a little?
thanks for the reassurance however.
I agree and think if you get the GH4 you will find it a great camera ergonomically...I just shot something with my GH2 today and have no issues switching back and forth...although I will never get rid of my GH2, if Pannie releases Vlog for the GH4 today, I'd immediately buy a 2nd body!
@touviere7 I find the GH4 to be a much more ergonomic camera to use. The GH2 seems tiny to me now. I assume when you focus, you have your hand on the lens. This is where the balance comes from. I have no problem using my thumb on the Fn3 button when focusing. Strange thing to be a deal breaker for you.
thank you both for the clarification.
i am not very happy about that sad and frustrating news :-( the gh2 scenario was the most natural, having the thumb on the wheel at all times. i have a hard time imagining pushing either fn2 or fn3 while holding the camera - seems unbalanced. kind of lost my desire to buy. since they love to change things around, maybe i'll wait for gh5 and see...
@touviere7 I understand your question now. I had the GH1, GH3 and GH4, but not the GH2. Actually, as fredfred27 said, the Fn3 is programmed to activate the focus assist by default, and I've changed the Fn2 button to the 4 arrows that allow you to move the magnifier where you want it. I find it easier to move the box where I want it first, and then magnify the area I want than to magnify first and then try to find what I'm looking for.
@touviere7 As @h20tara stated, read pg.107 of the "Owner's Manual for advanced features". You will see which button is the default for this feature, the Fn3 button on the back of the camera. It can also be programmed to another function button if you prefer. It cannot be programmed to the thumb dial on the GH2, because the dial does not have a push feature like it does on the GH2. I have a GH2 and GH4, and they are very different in their control layout. It can be frustrating when going between the two.
Personally, I use the default Fn3 button for focus assist on the GH4. I use my thumb just like on the GH2.
Just did a test on recovering sky detail with GH4 set to Natural and all other settings at 0. I did a bracketed exposure and chose the best dynamic range on the waveform display in DaVinci Resolve. There was no highlight clipping. In-camera zebras were visible across most of the sky and were set to 100%. Video range was set to 16-235 and was shot at 100MB 1080 25p.
Before and after grading screengrabs below. Extra colour added to sky to reveal the sky as it appeared to the eye.
