I've been able to load different settings files and load the hacked firmware. Even though the version still says 1.1, I know it's different because I can see the data rate has changed. I can't figure out how to change the framerate. No matter which settings file I load, the framerate stays the same. I'm using quicktime's inspector window to check. Am I missing something or is all the talk about different framerates only for the GH models? Thanks for any tips!
it would be possible to replace the framerate of 25p per 23.976fps mode? as moon t7 de23.976 and 24p
I checked the FAQs and I didn't see the GF2 mentioned anywhere. Link?
I guess I should have specified that I was wondering if the GF2 can do 24fps? (not a setting in the manual)
Thanks!
Edit: Sorry man, thought you were talking about the GH2.
