I've been able to load different settings files and load the hacked firmware. Even though the version still says 1.1, I know it's different because I can see the data rate has changed. I can't figure out how to change the framerate. No matter which settings file I load, the framerate stays the same. I'm using quicktime's inspector window to check. Am I missing something or is all the talk about different framerates only for the GH models? Thanks for any tips!
Edit: Sorry man, thought you were talking about the GH2.
I checked the FAQs and I didn't see the GF2 mentioned anywhere. Link?
I guess I should have specified that I was wondering if the GF2 can do 24fps? (not a setting in the manual)
Thanks!
it would be possible to replace the framerate of 25p per 23.976fps mode? as moon t7 de23.976 and 24p
