Official Low GOP topic
  • 1003 Replies sorted by
  • @Braamokiev
    settings=@stonebat ;-)
  • thanks @stip and @stray. no visible damage so far.
  • thx stonebat, hope you're not too close to Irene.
  • 110Mbps GOP3 AQ3 FB&FLx1.37 passed papps chart test from monitor screen. I'm sure some people who are eager to find out more would try out more tests. Tweak the settings in any way you want. When you take video with this setting, see if there's any macroblock mess or image quality degradation... because I'm not making any claim that this is better than any other settings. Who knows? It might degrade image quality. Haha. Have fun~!
    1277 x 675 - 295K
    sete.zip
    403B
  • yeah danyyyel, I was wondering exactly the same thing...
  • hello
    @Mihuel
    setting please?
  • Does anyone has a low gop settings with birate in the 66 or 88 mbit (AQ of 3 at least), or do you have always to have high bitrate in the 100+ for it to work.
  • @Stonebat
    @Drifwood
    @Stray
    Two JPG with stonebat 110Mbits AQ2 and 1.5 * FL / FB. First from my "death chart", the second, static-my beloved pregnant.
    1288 x 666 - 141K
    1289 x 668 - 149K
  • Ah right, I wasn't clear if it was the same, cheers.
  • @Stray
    What I posted is from @stonebat 110MB AQ3 gop3 settings . As you see its not stable yet with complicated scene .
  • So, is the trade off here, generally speaking, for a stable low GOP accepting less IQ (frame size) than you would get for the higher bitrate normally ?
    @stonebat that 110MB AQ3 GOP3 streamparser graph is mindblowing, have you got graphs from other footage shot with it ? I would really like to see the footage shot with that too. Hope you and yours get through the storm okay.
    What Mihuel has posted, where it peaks and then flatlines at a silly low level for the bitrate set I've seen myself trying to build a GOP3 at lower bitrates, and in some cases the settings did look good and produce a good stream with the deathchart too.
  • @stonebat
    110Mbist, AQ3 & 1.39x ....
    My "death chart" is : a tree in front of my window then street then a tree
    1288 x 666 - 140K
  • The higher multiplier, the larger B-frame. We wanna maximize the benefit of lower quantization, but the bitrate bandwidth might get choked.
    Anyways... storm is here...
  • AQ3 132mbps - multiplier tests
    1.39 fail! 20 sec, 4 secs, 34 secs...
    1.41 good for 2 - two minute tests, fail for 2 higher shutter/ not 9.5 i/3.5 b
    1.42 nope 1 min max, more fails.. plus samples not 9.5 i/3.5 b
    1.45 good for 3 two min tests, fail for 1 higher shutter / not 9.5 i/3.5 b
  • 1.66 is too high. Start from 1.39. If it works, pick the mid point between 1.39 and 1.5. That's like 1.44. If fails, 1.41. etc. Simple binary search. It will take about 4 trials.
  • Very close on a multiplier of 1.66 at 132mbps @ AQ=3. Nearly 2 mins on the death chart before it died. Plus a nasty spike in the buffer/b frames going to pap half way through for a few frames.
    1764 x 953 - 74K
    1313 x 699 - 89K
  • Good ol' AQ2! Ive been doing a load of tests on 100mbps and 132mbps. Probs wont get to the bottom of AQ3 till tomoz now.
  • I tried AQ2 1.5x.
    Try 132Mbps GOP3 AQ3 1.39x. See if you can get I-frame close to 9.5Mb. And B-frame close to 3.5Mb.
  • @stonebat and what multiplier settings did you cover when you had stability at 132mbps? That sounds more reasonable
  • Yes. This is 1.39x and AQ3.
    Chris did ask to try AQ3. 1.5x didn't work then.
    My reasoning is simple. I don't know crap about how AQ and buffer matrix work. But I did this stupid equations.
    AQ2 & 1.5x = 2 * 1.5 = 3 worked.
    AQ3 & 1.5x = 3 * 1.5 = 4.5 failed.
    AQ3 & 1.39x = 3 * 1.39 = 4.17 worked.
    There's one pattern here. Multiply by 10. Then it's 41.7 for the last case where B-frame is about 40% of I-frame. It's 30 for the first case where B-frame is about 30% of I-frame. It's 45 for the middle case where B-frame was almost half the size of I-frame before the cadence anomaly occurred. Maybe just coincidence for only 110Mbps. As I said, I don't know crap about the codec.
  • He gave 1.5 for AQ2 if I remember...
  • @driftwood That 1.5x multipler was given by @cbrandin. 1.39x is only 7% deviation. I'm sure everyone including Chris will be happy if it improves image quality.
    I picked 110Mbps because it's 5 times the recommended 22Mbps.
    Can you test the 1.39x setting on the pappas chart? I've been using my Japanese maple tree, but it's raining now. Hmmm... the storm is expected to hit within an hour.
  • @Stonebat 2 mins on pappas death chart on 140mbps/AQ=3 = nearly a minute before it died on 1.5 multiplier.
    edit: i c you have no death chart.
    Try a test on your screen. Maximise the death chart on your camera view, stabilise it to 60shutter , and see what happens.
  • The h setting is 110Mbps, GOP3, AQ2, X1.5 on FBs and FL. The j setting is 110Mbps, GOP3, AQ3, X1.39 on FBs and FL. Both worked. The attached diagram is from the j setting. My gut feeling is that... the B-frame seems little too big. Or is that a typical behavior from AQ3 setting?
    It would be nice if someone can do image quality testing between the two settings. My 10 years old printer sucks. It can't print the pappas chart well.
    seth.zip
    405B
    setj.zip
    406B
    1277 x 681 - 291K
