@warlightUK what lens? and did you mess with the colors at all to get the moon to look more white? or was the moon actually that color temp?
@driftwood 7c and 1/50 looks a little better, I see a few clips that for some reason appear to having a "slow motion" playback. it appears less actual "motion" blur (probably thanks to 1/50) but it's more looks like a crazy frame rate/slow motion? and my pc shouldn't be lagging in playback via VLC, 32gig of ram and a geforce gtx 690 overall from a-c was huge improvements, I'm going to grade some stuff and render it out to a more natural format and see if the playback looks a little cleaner.
moon 7c overall is probably the best setting since sedna, intravenous, and moon t3&5. ALL of the settings are really nice and tons of hard work was put into each, but those 4-5 settings I just mentioned just have something extra special about them : )
Yay! Thankyou @WarLightUK Love it. :-)
@driftwood Here is a quick edit of the full moon over London filmed with Moon T7
Continuing with some of the "motion blur" talk from series 2, I've found this is as well in my first tests of Moon 7. I always test first with static, well lit and properly exposed shots of me talking, and I'm about as animated as most humans but I do "talk with my hands" as they say, and the blur is noticeable as I'm hammering home a real earth shattering point. I transcoded to Cineform, and then rendered out to MP4 with Vegas Pro, avg 25 MB, peaking 50. Shooting w/ Lumix 20 and 14. But then again, I've also become accustomed to shooting at 1/40 with GH2, and I'm using the same 45 MB/s cards as danielortega is, which could be part of the problem. (?)
Apart from that, the setting is really nice. Viewing on my JVC HD projector at 120 inches I wouldn't say it's too soft. I'm testing out various settings for a project I have coming up, and honestly I'm still quite a fan of the original Intravenus with the '444 Soft', and I like stuff in focus, John Ford/William Wyler depth of field etc, and it holds up pretty darn nice. Anyway, if my tests weren't me talking like an idiot about the Spring Breakers Blu Ray I'd put it up, but that'd be too embarrassing, so I'll keep testing out some stuff, including 1/50 shutter, and the 'B' and 'C' trials, etc. Again this isn't much of a complaint, these settings are terrific and the work is appreciated big time.
Update News (Monday 22nd July) DREWnet T9 released today. Including the findings of moon T7 (read above) You'll get a QP of 1 throughout many less busy pictures but most pictures will resolve sub QP of 10. Death charts code at a quant of around 15-16 average!
Superior Quantisation
80Mbps constant in 24p modes for exceptional quality.
1080i/FSH Maybe only around 40Mbps but the quantisation and PSNR is brilliant!
720p modes Just the best there is.
iA and iDynamic modes simply work!
MJPEG mode - best available (like moon)
Per Lichtman stunning audio resolution.
To download Click on the file icon link below labeled 'DREWnet T9.zip'
Here's Cluster X 'DREWnet T8' in action courtesy of Matteo Sacher ( @microfourthirduser ):-
'Nebula T7' (Released 24/07/2013) Including all recent findings in moon, even lower quantisation and improved GOP related stuff.
1080p24 at 86+Mbps avg
1080iFSH50/60/HBR25/30 at 50+Mbps
720p50/60 superior setting at 60Mbps - this could even beat moon's 720 modes for quality.
new softer matrix - targeted at Pany lenses.
iA modes working it appears.
iDynamic mode on 24p best on Low.
Great sound from Per Lichtman of Pasadena Pulse AKA @thepalalias
Includes the long-time best looking mjpeg setting and greatest Quant.
Here's an early 'Nebular' 6 GOP video courtesy of Ernesto Mántaras ( @charlie_orozco ) - Has anyone ever shot a video on Cluster X Nebular/ not many of you like GOP 6 it seems...? ;-
Update News (19/08/2013): Spizz Trial 6 is released!
3 GOP expert Katsu (aka @bkmcwd) and r&d PAL specialist @towi put together some ongoing ideas of theirs and mine in this new setting of the experimental Spizz series. We've chucked out so many variations before deciding to release this that I was beginning to think T6 will never be realised! Anyways, what we've got is the best looking 3 GOP in areas of quantisation, bitrate spread and measured performance for all 1080 modes. 720 is 6 GOP.
There's some unusual values in the Top bitrate settings - an experiment based on a Texas Instruments formula of 'maxbitrate is 1.5 times that of actual bitrate' under the current rate control - but everything is allocated in AVCHD Compression accordingly and close to what you can expect.
For the first time we see the 1080i matrix adapted more towards the left side (not just top left) as an interlaced slice is scanned differently to progressive slices which I believe improves the spread of QP values and DC coefficient range in the low frequencies. Certainly the results on Elecard look good.
Ive tried hard to make this work with iA modes or iDynamic and though it passes my tests some of you may find that it may / or may not pass yours. So trial away.
Spizz T6 on average offers similar bitrate consumption to previous Spizz releases and settings like Flow Motion but is much more constant - qualified by the higher QP values without any lineage breakup in the overall picture.
24p 100Mbps average can go much higher if pushed. The best QP around (below QP10 for most pics).
720p modes on 6 GOP and refined to work with iDynamic/iA modes - 55Mbps avg
1080i/HBR modes around 68Mbps avg finely measured matrix and quantisation. (QPs below 10!)
The best mjpeg mode from Driftwood (anamorphic users should experiment with their own frame sizes)
Don't forget to donate to Vitaliy's link above if you use this setting.
GOP3 Spizz T6 versus Flowmotion v202
Update News (updated 21/07/2013) Two months after the experimental moon T6 and lots of new research I present you 'moon' T7.
UPDATE: Both variations of moon T7 (24p & 23.976p) are included in the one zip below. Both also include the slightly adjusted 720p60 for stability in iA modes (thanks @flaschus ).
INTRA 24p minimum 130-147Mbps - best looking ever with extreme Quant values - period.
INTRA 25p/FSH50i at 80Mbps.
3 GOP 30pHBR/FSH60i at 72Mbps+.
720p modes minimum 50-70Mbps max - best ever 720 setting? ;-)
Great sound from per (Per Lichtman of Pasadena Pulse AKA thepalalias!!!!) ;-)
Choose between setd 24p, 25p/50p, 30p & 60p or sete 23.976p, 25p/50p, 29.97p & 59.94p frame rates.
Please don't forget to donate to personal-view and help this site continue.
An early version of moon T7 is on the other thread, just going over a few tiny little changes to improve iA mode stability - released here shortly.
Here's Cluster X 'moon T5' and 'Nebula' in action courtesy of the boys at 'DeployAerial' ( @DeployAerial );-
