GH2 Shoulder Mount Follow Focus rig - Gini + TrusMT
  • 31 Replies sorted by
  • @stonebat
    Yes, the Satechi outputs power through its USB 2.0 port, so it should power up your USB-compatible preamp. You charge the Satechi from another USB power source, and can do so at the same time it's powering another device. It easily powers the Zoom H4n for six hours or more. I don't recall what other batteries I considered, but the Satechi was the most elegant and compact.
    Satechi iCel 5200 mAh USB Rechargeable Battery
    http://www.amazon.com/gp/product/B001BF12QO
    That solar-powered external battery looks interesting, but apparently it can only be charged up to 50% of its capacity by the sun.
  • @stonebat
    You can look at other batteries also.
    I remember few cheap ones with multiple voltages mentioned in GH powering topics.
  • @LPowell
    I have a small preamp with this power spec: 7.5-12V AC or DC < 150mA (external) or USB bus powered or 9V Battery @ 20mA typical, 50mA max. (phantom power)
    Will the Satechi iCel 5200 mAh battery work over the USB port?
    What other alternatives did you consider before choosing Satechi iCel? Have you considered this solar powered USB battery charger http://www.amazon.com/Premium-Solar-Charger-Built--Windshield/dp/B00449U3K0/ref=zg_bs_515383011_1?
    Thanks.
  • @PixCanFly
    My Gini rig is pretty quick to pack for transport. The matte box comes off and the camera and lens are simply removed from the Nikon lens adapter. I then detach the chest pad support arm and the top and bottom handles. The shoulder pad rails slide all the way forward without disassembly. Nikon lens mount and follow focus remain attached, and the compacted rig fits easily inside a duffel bag.
  • No, we'd leave it as it is in the grip truck till production is over. It really takes damn a long time to set up. Then on set, you have other things to think about- there is lighting design, which will take some more time. Sometimes, its easier to just set up things the old way - tracks, dollies, even a jib arm will be faster
  • I would think it's difficult to find a suitable bag to lug this thing around. So you disassembled it after every shoot?
  • Takes forever to set it up. And it weighs a ton, with a full load (morn, 12v bat, follow focus et al) LOL. Tried on a few, and my take is, if you lug this carcass with you on set, you're better off going back to big HD cameras. The reason why I came over to DSLR is because things are supposed to be alot lighter!
  • how do u guys travel with this giant rig. Do you assembled and disassembled it on shoot?
  • Love this configuration!
    Paid 65 dollars for the shoulder mount and X-grip (2nd hand)
    Lens is a 24mm 2.8 ML Yashica/Contax/Pentax PK plus the hot LA7200.
    2193 x 3472 - 1M
  • @ed_lee83 I like your rigs. Mine weighed in at around 16lbs...I have a larger battery pack. I've been looking for a decent tripod to support the rig...can I ask which tripod you use?
  • nice! I see we also have the same lens. Sorry if I'm butting in but here's my rig which also weighs about 6kg:
    1024 x 768 - 555K
  • Latest update! I scored a Century Optics 1.33X anamorphic adapter with an internal focusing mechanism that can be focused from 5 feet to infinity. This adapter can handle focal lengths down to 20mm without vignetting. It mounts on the 77mm filter threads of my Samyang and Tokina follow-focus lenses and needs no additional lens support. With this I can use my stripped-down ProAim MB95 matte box as a lens hood:
    http://www.thecinecity.com/eshop/product.php?productid=59&cat=26&page=1
    For additional lens shading, I have a velcro-mounted Cinetactics MB100M-FF1 Oversize Flag:
    http://www.cinetactics.com/-strse-2/Matteblox-DV-Oversize-Flag/Detail.bok
    In the photos below, you can also see a custom rail-mounted camera base support. I adjust this to provide just enough pressure to prevent the GH1 from wobbling on the Nikon-to-M43 adapter that supports the camera's weight.
    The entire rig, with counterweight and anamorphic adapter, weighs about 6kg.
    4928 x 3264 - 6M
    4928 x 3264 - 6M
    4928 x 3264 - 6M
  • I recently updated my Follow Focus rig with two new components:
    TrusMT DSLR viewfinder (Aluminum):
    http://www.ebay.com/itm/Trusmt-Dslr-LCD-Viewfinder-AL-/280722708651?pt=LH_DefaultDomain_0&hash=item415c6098ab
    Carbon Fiber version:
    http://www.ebay.com/itm/Trusmt-Dslr-LCD-Viewfinder-carbon-fibre-/270799891209?pt=LH_DefaultDomain_0&hash=item3f0cee6b09
    TrusMT Shoulder Pad
    http://www.ebay.com/itm/Trusmt-4-holes-lock-DSLR-shoulder-pad-kit-/280724012351?pt=US_Camera_Camcorder_Accessory_Bundles&hash=item415c747d3f
    The shoulder pad position can be adjusted along the rails to fit your shoulder. I also revised the lower grip mount to center it under the camera lens and added a small rail mount under the camera itself. This mount is not needed to support the camera's weight, it's there to brace the camera against the sloppy fit of the lens adapter.
    The TrusMT DSLR viewfinder comes with a bottom mounting plate and an offset bracket that was not designed for the GH1 or GH2. To center the unit on the camera's LCD, I had to shift the offset bracket on the bottom plate, mounting it with just a single screw. The assembled unit is completely rigid, however, and holds the viewfinder firmly against the LCD. I was also motivated to hack off the protruding front and side of the mounting plate, to provide battery access and clearance for mounting the camera on a tripod-mounted lens adapter.
    Pictured in the photos below is a Sigma 70-200mm f2.8 HSM non-DG zoom lens in Nikon version, mounted on its own tripod collar. (I chose this particular version for its manual aperture ring.) While this is about as long a lens as I'd use on this rig, total weight is still only 5kg (11 lbs).
    The focus ring on the Sigma is too far forward to use with the follow focus, and it rotates in the wrong direction anyway. I've instead mounted the follow focus gear on the lens zoom ring, which works quite well. Using this rig, I've discovered that adding a bit of zoom to a panning shot creates a more natural-looking move than either technique alone. In addition, the adjustable stops on the TrusMT follow focus allow me to preset the exact zoom range I want to use in the shot.
    3136 x 2352 - 2M
    3136 x 2352 - 2M
  • @brianluce
    Like most Manfrotto gear, I've found the 701 head to be a combination of solid construction and sloppy tolerances. I think the tripods in my equipment bag have been taking turns harassing the 701, it's looking pretty beat up lately.
  • OT, but how's that 701 head working out for you?
  • Not a fan of using FF on Lumix G lenses. Who knows. There might be no focus ring at all. New 14-42 has neither focus ring nor zoom ring. I definitely prefer internal focus and fixed barrel length lenses like Samyang's primes for practical reason.
  • @bslsmth
    If you mean the Lumix 20mm f1.7 pancake, it's not going to work well with any follow focus unit. In addition to being too thin for the FF gears, the pancake's focus ring is a fly-by-wire design that is not mechanically coupled to the lens' internal focus mechanism. As a result, the position of the focus ring bears no stable relationship to the lens' focus setting and cannot be calibrated to a follow focus unit.
  • Hey LPowell,
    Love your set up but I had heard that the Trusmt FF didn't work well with your camera because the pancake lens is too close to the camera for the gear to attach to it. Do you have any problem with it?
    Bas
  • Make your own EVF eyecup... unless you have stash of cash for HDMI EVF. I need to save money for GH3 :)
  • @Rambo - Yes, the 16X9 HDV7X1 wide angle adapter is discontinued, the 16X9 EXII 0.75X adapter is probably the best substitute. I also tried 16X9's lightweight EXII 0.6X WA adapter but the difference in image quality was unacceptable.
    The Tokina 20-35mm is a full-frame lens for Nikon FX cameras, and the center crop used by the GH2 is sharp and bright in the corners. The 16X9 0.7X wide angle adapter has to be seen to be believed, it is massive and distortion free all the way out to 14mm focal length. The focus ring on Nikon lenses rotates in the opposite direction as Lumix and Canon lenses. This makes the TrusMT follow focus rotate toward you to pull focus closer to you, which is how I prefer it.
    @stefanos - Yes, the rig is front heavy, especially when using the 16X9 adapter. However, I like the solid heft of the rig and most of the time I am gripping it rigidly with both hands, pressing it firmly into my chest and shoulder. Balanced on one hand, either right or left, the rig needs two additional points of support, which the shoulder and chest pads provide. When holding it with my left hand, my elbow is dug into my ribs and locked in a 90-degree angle with my wrist straight. For me, this is a strong and comfortable position, though I typically don't hold it in one hand for much longer than it takes to adjust the follow focus. I actually prefer the flat shoulder mount as I can shift it forward and back as needed for different shooting positions.
    @stonebat - The camera/lens mount can be positioned close enough to use the GH2's viewfinder directly with my right eye. What I'd really like to find is a hotshoe-mounted eye cup or hood of some sort to shade the sun, but my searches have turned up nothing.
  • Imagine holding a virtual rig with front handles. The angle of elbows would be no greater than 90 degree and no less than 45 degree. Draw a mid point between hands and shoulders. That's the comfort zone to position center of weight of a rig. The further away the center of weight, the lower the hands with the same angle. To keep the center of weight closer to my body, gotta keep the camera body close to my body. Either EVF eyecup or HDMI EVF can help that. For a fully equipped rig w/ matte box, FF, big lens, and wide angle converter, definitely high quality front handle like the universal grip will help a lot.
  • @LPowell
    I had bought the "DSLR EXTREME-PLUS" a few months ago for a huge bargain, with the magic handles too. I'm extremely satisfied with the quality and price. Some advice for your shoulder's sake: get rid of that godawful shoulder pad and keep the 2 rods that go through it. Buy the cheap and famous 30$ shoulder support (no excuse:)). Trust me, you'll be a happier person when you do, night and day difference. Not only will you be 10X more confortable, but you'll get tired 10X slower as it's truly the only solution to get completely hands free for when you're just dialing knobs or not shooting, and it makes a huge difference. I will try to post a vid of how I use it and the benefits.
    Also, I think the next step to improve your rig, is the balance. I can tell from the pic you're slightly front heavy so you either need to add more weight somehow, or if you have any longer rods, make it extend further away from your shoulder, this makes a big difference to the balance and steadiness of shots too, and a front heavy rig is very tiring for your hands and more shaky; better to be back heavy than front heavy. Another little tip after experience is that the less offset the better, but if you don't have ultra long rods, it might not be easy for you straight away and it's not extremely important anyway (I'll try to illustrate what I mean soon)
    hope this might help a bit and give you some thought for your next steps
  • @stefanos
    I'll make review with time and also provide all info to similar designed handes.
    About bundles. Normally guys you are dealing with are sellers that ask factories to put their brand (sometimes).
    Sometimes they make custom producs that uses many standard parts.
  • Nice rig. I like the double support from chest and shoulder.
    BTW how's the Tokina at its widest angle and largest aperture on GH2? Good corner sharpness? Barrel distortion?
  • @Vitaliy_Kiselev
    I've been eyeballing those handles for a long time, they seem to be the best out there. Generally that company seems to make high quality stuff like their shoulder mount, v mount powering plate, FF, mattebox. Very good designs. I wish they had better kit bundles though. When my pockets have more cash in them I want to get these handles, their shoulder mount and mattebox, but that won't be anytime soon:)
