The website Photography Blog has published a 14 second sample move shot with the Panasonic GH3 in 72Mbps in ALL-I.
http://www.photographyblog.com/previews/panasonic_gh3_photos/
I have attached a screen shot taken from the movie. Unfortunately I am disappointed with the quality of the movie which I find inferior regarding sharpness and compression artefacts to driftwood's ALL-I hacks for the Panasonic GH2. Hopefully the 50Mbps IPB mode is better.
Below is the specifications of the movie.
MediaInfo Mac 0.7.36.0 file analysis report.
Report for file: panasonic_gh3_01.mov
Video Stream #1
Codec (Human Name)................................AVC
Codec (FourCC)....................................avc1
Codec Profile.....................................High@L5.0
Frame Width.......................................1 920 pixels
Frame Height......................................1 080 pixels
Frame Rate........................................25.000 fps
Total Frames......................................360
Display Aspect Ratio..............................16:9
Scan Type.........................................Progressive
Color Space.......................................YUV
Codec Settings (Summary)..........................2 Ref Frames
QF (like Gordian Knot)............................1.362
Codec Settings (CABAC)............................No
Codec Settings (Reference Frames).................2
Video Stream Length...............................14s 400ms
Video Stream BitRate..............................70.6 Mbps
Video Stream BitRate Mode.........................VBR
Bit Depth.........................................8 bits
Video Stream Size.................................121 MiB (98%)
Date of Original Encoding.........................UTC 2012-10-08 13:59:21
Color Primaries...................................BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer Characteristics..........................BT.709-5, BT.1361
Matrix Coefficients...............................BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio Stream #1
Codec.............................................PCM
Codec (FourCC)....................................twos
Audio Stream Length...............................14s 400ms
Audio Stream BitRate..............................1 536 Kbps
Audio Stream BitRate Mode.........................CBR
Number of Audio Channels..........................2
Sampling Rate.....................................48.0 KHz
Bit Depth.........................................16 bits
Audio Stream Size.................................2.64 MiB (2%)
hope it is due to high iso, it could be an excuse for the quality!
I think; it does not rain. There is very noise in the background!
It looks like a typical video image quality from a few years back, sharpening is not too nice looking.
