Panasonic GH3 72Mbps ALL-I Sample Movie
  • The website Photography Blog has published a 14 second sample move shot with the Panasonic GH3 in 72Mbps in ALL-I.
    http://www.photographyblog.com/previews/panasonic_gh3_photos/
    I have attached a screen shot taken from the movie. Unfortunately I am disappointed with the quality of the movie which I find inferior regarding sharpness and compression artefacts to driftwood's ALL-I hacks for the Panasonic GH2. Hopefully the 50Mbps IPB mode is better.
    Below is the specifications of the movie.
    MediaInfo Mac 0.7.36.0 file analysis report.
    Report for file: panasonic_gh3_01.mov
    Video Stream #1
    Codec (Human Name)................................AVC
    Codec (FourCC)....................................avc1
    Codec Profile.....................................High@L5.0
    Frame Width.......................................1 920 pixels
    Frame Height......................................1 080 pixels
    Frame Rate........................................25.000 fps
    Total Frames......................................360
    Display Aspect Ratio..............................16:9
    Scan Type.........................................Progressive
    Color Space.......................................YUV
    Codec Settings (Summary)..........................2 Ref Frames
    QF (like Gordian Knot)............................1.362
    Codec Settings (CABAC)............................No
    Codec Settings (Reference Frames).................2
    Video Stream Length...............................14s 400ms
    Video Stream BitRate..............................70.6 Mbps
    Video Stream BitRate Mode.........................VBR
    Bit Depth.........................................8 bits
    Video Stream Size.................................121 MiB (98%)
    Date of Original Encoding.........................UTC 2012-10-08 13:59:21
    Color Primaries...................................BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer Characteristics..........................BT.709-5, BT.1361
    Matrix Coefficients...............................BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio Stream #1
    Codec.............................................PCM
    Codec (FourCC)....................................twos
    Audio Stream Length...............................14s 400ms
    Audio Stream BitRate..............................1 536 Kbps
    Audio Stream BitRate Mode.........................CBR
    Number of Audio Channels..........................2
    Sampling Rate.....................................48.0 KHz
    Bit Depth.........................................16 bits
    Audio Stream Size.................................2.64 MiB (2%)
  • 4 Replies sorted by
  • It looks like a typical video image quality from a few years back, sharpening is not too nice looking.
  • I think; it does not rain. There is very noise in the background!
  • hope it is due to high iso, it could be an excuse for the quality!
