Low Contrast Filters/Ultra High Contrast Filters - what's the difference in real?!?
  • 35 Replies sorted by
  • Yes, and there is even #4 which I really want to buy.
  • Like Psyco said, in spite of it's confusing name, the Ultra Con lowers contrast, and the number relates to strength of the effect. Low cons are not technically a mist/diffusion filter, but they do act like one! (I've got #1 thru #3, and like I said I like em, but wouldn't use them on everything, or even most things) Ultra Cons are a more recent invention, which lift the blacks but don't have the misty effect. Ultra Cons will flare on you, though.
    Now, how well do any of these do for improving DR? Maybe a little, but unless you want to start and end "milky" in the blacks (sometimes I do for a "pastel" look), I'm not sure it gives you much detail. Especially with the better patches from Driftwood or Lee Powell, you have more detail in those shadows than you might think. With a camera like the GH2, I like getting the look close in-camera. On the other hand, Shian has posted good tips on this sight for lighting to get an image that's very grade-able.
  • @producer No no, the Ultra Contrast is a series of Tiffen (and other brands?) filters, which spread light from the highlights to the dark parts of the frame -> lowering the total contrast by iluminating the shadows.
  • Don't the Ultra Cons produce higher contrast instead on lower? As long as I know they are used for stars and galaxies shots.
    Since I use Yashica manual lens 28-105mm 2.8 with rear thread 72mm, it's a real headache to find 72mm low contrast filter.
  • Nice. I just got an old, but unused 58mm Ultra con #3 from ebay for half the price. :) thanks for the heads up! - As the GH2 doesn't offer me a flat picture style, this is a valuable option :)
    what do the numbers indicate, anyway? intensity of the effect?
  • If what you're aiming for is simply lowering the contrast for a "flatter" image, you may want to look for Ultra Cons instead, which don't have the halation around highlights and what-not a Low Con has. I like the look of Low Cons a lot, but it's a particular aesthetic that is what it is, not a short-cut to creating a flat picture style for grading. The most sterling use of Low Cons must be Kubrick - the #3 on "Barry Lyndon", and a #1 on "Eyes Wide Shut".
  • Im was just wondering if there is any improvement in the workings of these filters in the past years, or if it is sufficient to get used one from old 35mm camera? :)
  • I have a tiffen 1/8 lo contrast filter - only used it once since getting it on sunny exteriors, but it definitely left me with shadow details to work with. Must use it more!
