@simurg the thread is about firmware suggestion (software), not hardware ;-)
From the leaks: 1080p50/60, 1080p100/120, 720p100/120....YES PLEASE!!!!
Firmware:
using Olympus 4/3 lenses via the normal adaptor (so, NOT dropping support for them!)
free (within limits) choice of x and y dimensions of picture size (e.g 2,39:1, 4:3,...) in video mode, markers/guidelines
free setting (within limits) of frame rate from 1-120fps (1fps stepps)
working HDMI out with any video mode (720p!)
focus, iris, shutter,... live control via USB port from computer (with special program for Mac and Windows, keyframing all functions)
displaying the actual focal length when using m4/3 and 4/3 zoom lenses
setting % IRE for over/under exposure false colour/zebra (e.g. under 20% -> blue, over 80% -> red)
custom curves
focus assist mode (zoom in mode) even when recording, also on HDMI out (if processing power is a problem, it would be enough to have one selectable output, HDMI or built in screen)
storing different settings/profiles on SD-card (or in camera)
HDR video in 1080p25/30 and 720p50/60 mode (writing 2 images for every frame on the SD card, no time shift)
no very-expensive-battery check (maybe only check when firmware gets updated to prevent bricking)
open up the firmware/camera software for programing (like Canon)
It would be usefull to have controll over the camera via a mobile phone, but make the same possible with a laptop and the USB port.
Edit:
Just to go a bit crazy, I want the GH3 firmware to be Android (or Tizen or any other fairly 'ordinary' mobile OS as a base) with a full SDK so that people can freely program the camera and get the firmware to do whatever they want. You can write small apps to do focus and aperture control to automate moves however you want. Write encoder plugins so the camera saves to .MP4, .MOV, .OGG, or whatever else. Assuming the GH3 allows wireless, allow custom recorder apps to record streaming audio from microphones over wireless alongside the video recording. You could come up with all sorts of crazy things if there was an SDK.
Obviously, I don't consider that plausible, so I'll be content with custom profiles. I would own a GH2 today if I could do something like Canon's "Technicolor CineStyle." Assuming the GH3 allows me to make a flat profile for grading, and I expect that I'll be able to do high bit rate recording, I may order one on launch day. If it does 10 bit 4:2:2 on top of that, you won't be able to stop me from ordering it on launch day.
does this mean you have a Gh3 alpha firmware
Nope. I mean GH2.
^interesting - I meant for Gh3 development (vs Gh2) does this mean you have a Gh3 alpha firmware @_@
Intelligent Dynamic with fixed, and controllable values. I.e. Does not fluctuate in a shot as you pan around.
I spent time looking for ID and other things.
Unfortunately I couldn't track it down to image processing stage.
Here's a pretty easy one:
Intelligent resolution with fixed and controllable values.
Perhaps the ID and IR setting can be programmed before rolling by using a Keyframe or raw frame in camera? sort of like custom white balance off of a Raw photo.
Here is a Link to Panasonic's explanation of iD and iA http://panasonic.net/avc/lumix/systemcamera/gms/gh2/ia.html
Generally more direct, non-fluctuating control over DSP/Signal Processing algortithms/signal chain.
•True 180º Shutter = 1/48@24p
•2.39:1 widescreen shooting aspect •2.39:1 widescreen grid while shooting in other aspects
(BTW, 2.39:1 is widescreen standard, even on DVD. 2.35:1 hasn't been used for widescreen for 40 years. It's confusing because some people and DVDs continue to call it 2.35, but if you measure it, it's 2.39:1.)
http://en.wikipedia.org/wiki/Anamorphic_format#2.35.2C_2.39_or_2.40.3F
•Highlight rolloff that would avoid ugly highlight color shifts by normalizing color channels as one channel approaches clipping. IOW, if two or three color channels are within a threshold range, as the hottest channel approaches 255, the other channel(s) are gently increased so they overexpose with balanced color.
The rolloff would also need a shoulder curve to make the transition more gentle.
I would like it if when I went into the menu, I could always access all the settings, instead of having different ones hidden if I am in IA or M Movie Mode or Manual. Sometimes it is tricky to remember which dial setting you need to change a setting.
Also, it would be helpful if the setup section were more organized by categories. For instance "EVF/LCD" could have all the settings related to those "Lens/Focus Options" could have the "shoot without lens" and "MF assist" settings and things like that. It can be easy to miss options in the pages upon pages of settings to go through under the same heading at the moment.
Maybe the first screen of the menu could be labeled icons for each of the sections?
Also the "M, A, S" settings for M Movie mode should be moved from a menu option to a "Q Menu" option so that they can be easily seen and changed while shooting.
I mean, those are some of the types of things that might make it easier.
But possibly the most helpful, would be to have the firmware configured to match the exposure you will get in your shot when you are setting it up - by default - so that you do not get an exposure shift or gamma shift or what-have-you when you hit the shutter button.
It would be great to have that kind of mobile app, but those settings should be left available on camera too, in case your phone or whatever gadget dies..
I think, real changes will be possible only as we'll see capacitive screens on cameras.
Also, most expert settings must be moved into mobile applications out of the camera.
Easier menus. Sometime find or change what you need is very tricky..
Please, be more specific. How you want menus to look? May be some examples.
New redefined menus.
Can you be more specific?
Voice command! Siri, Action. Focus. Cut!
Nope. It'll be:
Siri, Make perfect photo.... ok... Now, Siri, I need you to make perfect sex scene video.. No, no, not with you, stupid.
+1 For the suggestions Shian made about zebras, highlight clipping and focus assist.
+1 For the suggestions Bueller made about 4:2:2 and log.
+1 For changing ISO, WB and audio while recording, like Evero mentioned.
+1 For being able to shoot any mode "VMM" style and have it record at a different frame rate and playback at 24P, 25P or 30P.
+1 For editable picture profiles.
+1 For Wi-Fi or USB app to control intervalometer shooting and bracketing (preferrably together).
Or
+1 Firmware support for the protocols used by the Promote Control.
Previously mentioned, but would like to emphasize:
RED DOT while recording, GREEN DOT while standby. Option to have the dots viewable in hdmi output. I need it when I'm with steadicam under sunlight conditions... Sometime it's hard to see if you're recording or not.
I miss the LANC, if something like that could be possible with the usb port it would be great. Zoom, Shutter, Focus, Exposure....
