Choosing Light Kit
  • 69 Replies sorted by
  • thinking about grabbing this as a good starting-studio kit. Very small, but useable lighting later on if I decide to upgrade. http://www.amazon.com/ePhoto-Lighting-Portrait-Carrying-Fluorescent/product-reviews/B002SCGY5S/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
    Can I use my LED for a rim light with these or will the color balance be off? Same question If I later on upgrade to the AS-arri lights offered in the deals.
    good (CHEAP) starting kit? what do you guys think?
  • @Amadeus5D2 I actually had those before and as Vitaliy said, packing them up and building them are a pain in the butt. I actually went to the 4 bank flourescent panels. I bought the cowboy studio ones that look like the Diva kits and purchased the same bulbs as Kino uses. They just rebrand GE or Phillips. I can't remember offhand which. The doors suck but they work just as well as the Kino brand, without the dimming which I just do with diffusion or ND. I think you can pick them up for $250 a piece and that includes stand.
  • I love how they never actually show anything keyed in that video.
  • ah, o.k. I would use it only stationary, but what means you with fluos panels( fluorescent?). for me is important that the light is producing low heating.
  • They also very poor reliability and packing size. But stationary at studio they are ok.
    I think if you have resources it is best to invest in good fluos panels.
  • @Amadeus5D2.
    The only issue with that style of softlight is that they are fiddly to setup.
    You can't just throw it on a stand, they take about 10 minutes minimum each to set up:
    60-120 seconds per globe .. then .. 180-300 seconds per box and diffusor
    half that to pack away
    They are all soft lights .. if that's what you are after and you don't need to work fast
  • I would make inside chromakey video. Here from tubetape a studio lighting kit
    http://www.tubetape.net/servlet/the-754/5-Point-Studio-Lighting/Detail
    Is this a good solution?
  • @kronstadt
    A roll of black wrap can help control the LED's.
    I worked for a gaffer for a couple of years fresh out of school. My light kit lacks hard/point sources.
  • @kavadni wow, that's one mighty lighting kit you've got there. Enough to light up pretty complex scenes even on a constructed studio set. Are you like a professional "electrical department" person?
    I think I'll take your advice about acquiring another Redhead in the future, although I'm giving a serious consideration to a 2K Blonde or a 250W HMI. I know that there's a lot of hype around the LEDs, but I found it difficult to work with (no easy way to "contain" or "shape" the light), and same thing with fluorescent energy-saving bulbs - the light from them always somehow looks "unnatural" to my eye. I keep my own lighting kit as basic as possible due to cost, portability (I try to make sure that my entire cine-gear is no more than 2 bags so that it can fit an average taxi cab) and, importantly, workflow on location shoots (we all know that lighting gear is the most time-consuming to set up or pack up) and I can only afford to shoot in "natural" locations (inside real living spaces, for example), rather than inside studios.
  • @kronstadt .. doing a stock take on my lights for insurance.
    Tungsten 3 x Ianiro Reds .. genuine article .. had them for over 25 years .. in storage for for 13. 1 x Ianiro Blonde .. 25 years also 1 x Arri 650W .. it's not quite as old .. that's my kicker. It can take a 500w globe I ND it if it's too much. 2 x Lowell Tota's .. these are cheap and quite useful .. they throw a squarish pattern and work well to light up a background .. they're about the same output as the redhead .. no focus .. they are really compact .. they are fiddly.
    I've recently bought Floros and LED 4 of the Daylight AS312 through Vitaliy's offer. I throw these in the car whenever I take the camera.
    4 x 4 E27 Globe Flouro fittings with softboxes http://www.hypop.com.au/continuous-lighting/photography-octagon-soft-box-lighting-set/large-80cm-quad-head-single-octagon-softbox-lighting-set-by-hypop.html .. these are for the studio that is being built for green screening.
    They came with 4 x 65W globes. I bought them as 2 sets of 2. When I ordered the second set they sent me a set of two single globe pop-up umbrella softboxes in error .. when I rang them asked about sending them back, they said not to bother .. so I got lucky. I carry these and the two totas in the same bag now.
    2 x E27 125W Globe Flouro fittings with softboxes http://www.hypop.com.au/continuous-lighting/photography-octagon-soft-box-lighting-set/double-octagon-collapsible-lighting-set-by-hypop.html .. that kit.
    I bought two of these bags recently http://www.bhphotovideo.com/c/product/842404-REG/CineBags_CB_06O_CB_06_Gel_Roll_Black_Orange.html I have diffusion in one gels in the other.
    I make cutters from black foamcore, I buy 4 x 6 sheets of poly for reflectors. I have 2 x 5in1 pop-up reflectors .. 1 option is diffusion, and two by holders for them that attach to a stand. I have 7 Manfrotto stands, 8 crap ones, 3 grip heads, 1 c-stand boom with a grip head, and 2 manfrotto autopoles, 4 superclamps, and 4 piece backdrop support rod ... assorted adapters and spigots.
    My current wishlist : A couple of kino style lights probably 4 tubes .. the flouro softboxes are a little slow to set up and pack up. Kino's you just plop them on the stand and turn them on, c-stands, and a butterfly frame.
  • Has anyone used 120W Par38 bulbs? Or 250W infrared bulbs? Would they make for a good backlight kicker light?
    I wonder what do people in this forum use for kicklight (backlight)?
  • @Mark_the_Harp Yeah, I've struggled with keeping bounce cards and flags at an EXACT position too. A slight degree variation and the whole lighting is off.
    But, this is what they often use on sets http://www.ebay.co.uk/itm/110895093434 I'm gonna make mine DIY with a piece of wood and some long screws (or nails) to screw into the foamboard. At the bottom of the wood plank I'll attach (with epoxy putty) a 1/4" nut. That will allow me to screw it onto a small camera ball-head. The ball-head screws onto the tip of a light stand (provided that it has a 1/4" nipple on top of its spiggot. Those ultra cheap stands on eBay for £8.05 have it). Total cost £12-£15. Simple.
    But this setup has no booming arm. I think I'll also try your idea with the boom mic stand. Can you post some e-bay links for cheap mic stands? As long as it is secured with heavy sandbags http://www.amazon.co.uk/Silverline-868732-10-Pack-Sandbags/dp/B000NBVA3W/ref=pd_sim_sbs_light_2 (10 for £4), it should work fine. I've also read that drum cymbal stands should also work, although their height is limited.
  • @kronstadt Poundland white baking paper = clever idea! I'd also love to know if / how you work out how to clamp bounce boards 'cos that's the thing I've most struggled with (without buying the proper bits). I use a strong mic stand & boom arm because you can quickly tilt it to any angle, but how to attach the board properly - I use bulldog clips attached to a mic clip on the end of the boom arm, with the other end clamped as best I can to the main bit of the mic stand, but that's not ideal as the thing moves round on the boom arm. Certainly not much use for anywhere windy.
    Re your b&w experience, I read that in the days of b&w TV, that the studio was much more colourful than it is now. Presumably people used slightly reddish tints to be kinder to skin tones? Or maybe b&w TV cameras had a particularly strange spectral sensitivity?
    I've not done CTO on windows as it needs a lot of CTO but I can see it would make more sense to knock down the daylight level and the use un-gelled lights (as opposed to letting it all in and then balancing it with lights which are losing a bit of power due to being gelled). BTW but possibly related, have you ever seen those clothing shops with what looks like CTO covering their windows? I think it was something popular with shopkeepers in the 1960s or so. I wonder what that was about?
  • E27 bulb holders I've also recently purchased one of those eBay E27 bulb holders, thinking that I can make a "kicklight" with it with black-foil or adding a matte black tube, to make a directional back-light source.
    But I'm having trouble finding a decent powerful enough (~250W) E27 halogen bulb. Can anyone help but posting links to tungsten bulbs that I could use on these bulb-holders? I've found 250W infrared bulbs, but I'm not sure if that's gonna be health hazard or fire risk.
  • @kavadni yes, thanks for clarifying that about the contrast ratio. Yes, that makes sense.
    @Mark_the_Harp yes, that's what I've been doing for daylight scene rehearsals/readings (I mean adding a 1/2 CTB or 1/4 CTB). Works ok, but I've gotta try this CTO on windows trick too at some point - sounds compelling. I'm only just getting started with shooting in color and using filters, after a long sleep after once shooting on super-8mm and 16mm B&W many years ago. With B&W however you light it, even a simple single hard-light + some practical light, it looks interesting and "stylish", but with color and HD it's a whole different ballgame.
    By the way, I've found that using white baking paper (£1 for 8m roll from Poundland) works pretty well in creating a "diffusion filter". I'm gonna update my list with this item.
    I have a question to everyone. What would you say is a good cheap bounce-card? Foam-board or polysterene, or what? Any eBay links would be appreciated.
    I'm also interested to know what would make for a cheap substitute to a C-stand in order to hold fairly lightweight items (white bounce-cards and black flags). So far I'm thinking of getting those ultra-cheap eBay light stands (£8), mounting small ball-heads on them (£3) and constructing some sort of DIY foam-board forks with wood/plastic and nails/screws.
    The more I delve back into lighting gear and experiment, the more I recall how indispensable bounce-cards and flags are. I'd say maybe just as important as the light projectors.
  • @kronstadt Also I think people use 1/2-CTO on windows, as this doesn't entirely correct the windows to tungsten, but half-corrects it, leaving enough difference that you see a slight shift in colour between natural and artificial lights. Similarly, you can get 1/2 CTB to use on tungsten lights to do the same thing (leaving the windows unchanged). It can be a nice look to keep a slight difference but without the colours being too wildly different.
  • @kronstadt
    thanks for the advice about using CTO gels on the window. But wouldn't that look weird that a tungsten color light is coming from the window?
    My suggestion is for when you want all light sources the same colour.
    If using daylight from window and tungsten inside .. if you put CTB on the tungsten sources your contrast ratio goes up or you need more tungsten light .. if you put CTO on the windows contrast ratio goes down, or you need less tungsten light.
    You white balance appropriately
  • @kronstadt, thanks that's really useful! i like how the 2 light approach you are talking about is both budget friendly at the start, but also forces you to think about working/moulding the light you have with reflectors.
  • @Albertz yeah, I guess I'll get one of those IKEA table top goose-neck clip-lamps with 100W tangsten bulb (for mid-shots), but will probably go with 300W As-ARRI as a general kicker light. (To light the actual background walls one will need more power like a 650W I guess).
    @jules No worries - we are all learners. Basically, this is a kind-of a neo-noir style. The key-light often comes from my redhead 800W which is being projected not directly onto the talent, but onto a white card, which bounces light to one side of the talent. So my key light actually comes from the white card. This creates quite dramatic, but at the same time relatively "soft" light. My guess is that most of the interviews in this great video were shot using this simple technique
    I tend not to use fill-light. Instead, I might place a silver reflector to the other side of the talent that serves as a minute "fill-light", so that the other side is not completely dark.
    The second light lights up the background (walls, shelves etc).
    This is pretty much a Two-Point lighting. Check this video for more explanation
    The third light (kick-light or back-light), (which I don't have, and would like to have) throws a very thin and focused light edge onto the dark shoulders and jaw-line of the talent. Thus separating the talent from the background.
  • @kronstadt forgive my novice ignorance, but when you say " key-light with diffuser-panel/softbox+honeycomb or bounding off a reflector card" does the reflector card serve as your fill light source?
  • for backlight I think that a 150W Arri would be too low..on the other hand, I have seen a video where even two 100W CFL bulb were used as backlight (medium shot) and they worked fine..
  • @Vitaliy_Kiselev , me too might be interested in a C stand , if I could get them for cheap. What's the approximate price for those Weifeng C stands? and do they come with the gobo grips and the arm?
    @Mance thanks, I'll be updating my list as I go along. I've outlined a VERY basic kit. What I notice is that the Lighting kit is all about smallest (and seemingly useless) accessories. If you're not careful it can spin out of control and then you'll have too much stuff (which is also heavy) to carry around.
    @Mark_the_Harp yeah, that's a good idea, but one still needs to bag it in order to hang it on a light stand. Another good idea would be the camping water containers from Poundland - same principle, but more water/weight (also great for carrying drinking water to the location). So far I've been using ordinary plastic supermarket bags filled with stones to stabilise my light stands. It's an okey temporary solution. But I've noticed a set of 4 sandbags (specifically for lighting gear) on amazon.co.uk going for £13. I might get those.
    @kavadni thanks for the advice about using CTO gels on the window. But wouldn't that look weird that a tungsten color light is coming from the window? So far I actually like mixing the sunlight (blue) as fill and internal (orange) colors as jaw-line and background lighting - in the same shot. I know it's a "NO-NO", but it looks pretty cool. Regarding getting 2 Redheads and 1 As-Arri 500/600W, which would be the weakest light in the kit, but with a GH13 or GH2 isn't 500-650W an overkill for backlight????
    In my lighting style, which is very very simple, I could actually use 2 Redheads (1 for background lighting, and 1 for key-light with diffuser-panel/softbox+honeycomb or bounding off a reflector card, which is my favorite method). But the question of the backlight remains - I have a feeling that 500W would be an overkill for the jaw-line.
    I have a question to everyone: what is in your experience a good light for the kick-light (backlight)? Specifically, to create a nice jaw-line highlight in the shadowy area of the face during the dialogue scenes. So far I'm thinking of a 150W or 300W Fresnel As-ARRI (because of the fresnel lens it should be able to focus the light without spilling too much into shadow areas of the face).
  • Could you save weight and cost of weights / sandbags by using screw-top plastic milk containers which you fill with water as needed? Just an idea really, never tried it.
  • @kronstadt The thread would be very interesting. Your list is very detailed. Thanks for your share.
