For my purposes, I can't use 100Mbit. With the same scene, I don't have a banding problem with the 44Mbit patch and it was around 30Mbit when playing back just like the Flowmotion patch was using the FH setting. I was just wondering why would there be banding with Flowmotion patch and not the other patch at the same data rate. There was a significant difference.
Randy
I have a GH2, with a hack, my friend installed. I wanna install this new patch. Since I have absolutely not idea, how to go about with installing a patch, could someone tell me, step by step. I have a card reader, on my laptop. Do I still need any other device, for installing the patch? Also, could you Please tell me, in very simple steps, how to go about with things. Thanks in Advance
@Cavemandude To minimize banding high bitrates are sometimes required. Rather than using Flow Motion's 60Mbps FH video mode, I'd recommend trying its 100Mbps FSH mode.
Have asked again but i am really interested.... Love FM 2.02 but is it possible to shoot anamorphic with it? I just bought myself a Kowa 2X anamorphic lens and looking foreword of playing with it. Can i do so with FM?
@LPowell - It is not at all clear that the problem is or was fragmentation. The two 45mb/s cards were problematic from day one, one more than the other. Previously, I formatted them in camera before each use, with no improvement. Based on my experience in enterprise support, it is entirely possible that the problem was a process error during manufacture, of which Sandisk was unaware because their clueless support people are so busy pushing back that they cannot send bad news upstairs. As far as best practice moving forward is concerned, my instincts are the same as yours and RockHunter's - format, not delete, but my experience with in-camera formatting has not been good. I am perfectly willing to sacrifice principle for a good result. As a practical matter, the only time I clear a card in the field is when testing - for real work, everything gets moved to disk before I clear the card, in which case SDFormatter is available.
Why would I get heavy banding in overcast skies with the Flowmotion patch at FH 1080 60i and not with EOSHD 44Mbit Vanilla patch at 1080 60i? Hope it is a simple setting I messed up on.
Randy
@CurtisMack As you discovered, with high-bitrate patches it's important to guard against SD memory card fragmentation. However, using the trash button to delete video clips will not necessarily keep the card free of fragmentation. I'd recommend using the GH2 to reformat the SD card before each important shooting session.
@CurtisMack I would suggest after using the SDFormatter, you need to format again using the camera. Then format with the camera periodically after using the camera. How often? Depends on how much you used it. I do mine about every third outing. Then I also suggest using the SDFormatter occasionally. I use it about every 3 months.
At first, FlowMotion V2.02 choked after 10 seconds or so in 24H on my Sandisk 45mb/s 16 GB cards, shooting my death scene, surf breaking on rocks. Per LPowell's documentation, 24L worked fine. After formatting with SDFormatter, 24H presents no problem. Even EX TELE works. When running SDFormatter, I chose the Overwrite option, which took about 20 minutes to complete. In the past, I have always formatted in camera to clear the card. From now on, I intend to leave the card's format intact and use the trash button to delete everything, that is, when I don't have access to SDFormatter.
OK, I finally tested with FlowMotion v2 and I didn't get any of the PPro timeline responsiveness issues I had back in February :)
Sorry in advance for my newbiest. I'm looking for a 1080/25p patch and I tested a few of it in HBR mode like LPowell Flowmotion 1.1 or Quantum. When I insert one clip recorded in HBR in the StreamParser, the stream mode say that it is 1080/50i, and this is usual as can I view in the users screenprints of another patchs.
Adobe Premiere (for example) don't recognize the progressive mode, an says that is interlaced. Anyone can help me? Thks
@soulkeeper Thanks! I shot RAW. Smooth -2, -2, -2, -2. White balance with 18% gray card. ISO 160. I didn't drag my shutter correctly, because I had no idea what I was doing at the time haha. Also ND filter helps
Oops, had my HDMI cable still plugged in. All solved.
Randy
I've got Flow Motion installed but I can't get into the "Rec Mode" to change it 720P. What setting is preventing access to this menu?
Randy
@TheRuggedAdventurer Amazing!! Any tips for settings used to make the timelapse?
