The DMC-FZ200, which is due for release in late August or early September, replaces Panasonic's FZ150 as its new flagship bridge camera. Included is a highly formidable 25-600mm lens, which is incredibly wide yet capable of zooming extreme distances. Even more impressive is that the lens on the FZ200 maintains a constant f2.8 aperture throughout.
Specifications:
Previews:
Samples:
Available at:
Btw, as you can see, both cameras have dedicated manual movie mode setting on wheel.
G5 don't have it :-) Weird.
Looks very promising.
Are there any infos on the differences between FZ60 and FZ200 already??
First one I see clearly - lens. Sensor must be something like 14Mp 1/2.5".
I bet that VF on FZ60 is worse.
Guys, I removed to messages that have no relation to FZ200.
FZ200 series offers high-speed - up to 12 frames / second at full resolution. Just like the previous news, Lumix FZ200 allows you to shoot video with the highest quality - 1920x1080 50p AVCHD Progressive. Three-inch swivel screen will work under different scenarios, and the battery capacity of 1200 mAh will make up to 500 pictures per charge.
Source: http://www.3dnews.ru
And up to 120fps in 720p and 240fps in 480p (VGA)! This would be a good feature for the GH3! Would consider buying this camera, and adding in with the GH2 kit, as another tool when needed.
Put it in the shoulder rig with audio recorder, mattebox etc, and you have a good run and gun event setup for when needing a lot of different focal lengths very quickly or when wanting super slow mo, and are not overly concerned with shallow dof.
I imagine the video will be pretty good from this. It's approximately a 1/2" sensor. Remember this is larger than some very high end camcorders and nearly the size of a 2/3" ENG camera.
Btw if you look carefully, this camera is direct competitor to small sized cameras.
1/2.3" sensor, 1080p60, very good VF, full manual video, 720p120, Power OIS with active mode
I am sure GH3 will be able for more :-)
"I am sure GH3 will be able for more :-)" - VK
I will poop my pants!
This is first consumer camera then Lumix division seriously collided with consumer video cameras division.
Wow! - constant 2.8, power zoom, HDMI - it's got possibilities!
the 17MB/s is a bummer but since we're here in hack heaven, I'm hopeful. I could certainly use it for weddings. Does anyone know if the HDMI out is live while recording? - I'd need to pimp it out and an external monitor would be great.
50p/60p is using 28Mbit/s, pressty good, really. As any of Panasonic camcorders.
and this sample below shows almost no signs of noise, though could have NR up high, as the image looks a tad soft, though really good for indoors! Guess the constant f2.8 helps plus new processing engine and sensor technology allow for cleaner high ISOs:
