@Lpowell "You're right about Vimeo's web compression - it does a very poor job of rendering the details that can be seen in the original footage."
Of course the compressed video could never be as the original but expecially with the original MTS files, Vimeo struggle to compress them properly. Actually during the import Vimeo alerts you that the clip has a bitrate too high and that conversion could be poor. Anyway is always better than dropbox to share mts files ;)
Hi Lee,
I was shooting with a tripod and the 14-45 with a marumi polarizer on. I arrived ther with the sedna preloaded. I took a shoot and then I changed settings loading FM 2.02. In the meantime the sunlight changed a lot so I had to move the camera to find a similar spot.
Hoping to get exactly the same shot as the previous time I have to go there in the morning. That part of the resurgence is well lit only in the morning.
Anyway It seems to me that shooting in 24p cinema mode things get better.
@LongJohnSilver I downloaded your test footage from Vimeo and had a look. You're right about Vimeo's web compression - it does a very poor job of rendering the details that can be seen in the original footage.
Could you fill in some more details on your shooting setup? Although the original Flow Motion v2 footage looks virtually flawless, it's not clear to me how the situation differed in the case of the Sedna AQ20 footage.
I write here because I already posted here my video showing the codec suffering shooting a lake bottom through transparent water with small ripples. The previous clip was shot in VMM 80% mode. Yesterday afternoon I came back shooting the same subject. Unfortunately in the afternoon I found a completely different light and I could not replicate the same scene. Anyway I managed to get a couple of clips. I preloaded my GH2 with SEDNA A20 then I flashed the camera with FM 2.02. Both clips are in 24p cinema mode shot withthe lumix 20mm with a marumi polarizer. Unfortunately while I changed setting the light changed rapidly so the two clips are not very useful. @cbrandin streamparser shows that clips were recorder nearly a the top bitrate offred by these settings.
This time it seems that things went better than before also if the light is more forgiving than before.
Lesson learned: I throwed away HBR and I will use 24p cinema mode for this kind of scene. It's a shame but it's nearly impossible to spot flaws on the camera display and you'll discover imperfections once at home on a proper computer screen.
Again, if you are curious on the codec behavior don't look at vimeo clips but you have to download the original files.
FM 2.02 24p cinema mode
SEDNA AQ20
@peternap Thank you for posting your frame grabs on the previous page! That cannon firing is a stunning one-frame transition, truly an acid test of the camera's ability to track instantaneous motion. What is undoubtedly happening under the hood is that the encoder is using Intra-frame-type macroblocks to encode the completely changed areas of the canon firing, while using Inter-frame encoding on the rest of the B-frame. This is an example where the coarse B-frame Quantizing Tables used in the unhacked firmware would probably not be able to maintain I-frame image quality in its P and B-frames.
@LPowell No no no you might've misunderstood me, obviously I'm not here to offend anyone at all, especially you, I am greatly appreciative of your work, its probably sometimes how I word things or the way they come out (I'm dyslexic, but I often try not using this as an excuse), and not taking any cheap shots at you in any way.
What I mean by "doesn't look too pretty" was to say that I was able to distinguish the frames from the I-frames from the B-frames, from what I did was zoom in 200% and slowly analyze the frames and noise and saw that get 'washed' away due to the compression, noticably enough that the fine detail (of the noise especially) was not as visible compared to the I-frames.
This is probably how I should've explained it in the first place. Because of this all as well and trying to get the most from my (our) cameras, that is where I asked about the possibilities of making changes or improvements.
I also come with some news now (which myself I took time to do to help you and manjy others), I have by now tried recording at ISO12800, 10000, 8000 and 6400 just now in 100Mbps 24p and none of them was able to get past 4minutes, and whilst I can 'preview' them in playback, it just plays 1 second before giving an error message stating something's wrong with the card. Now I will try ISO5000 to see if it will make any difference.
But overall, I hope you are not upset or frustrated with me, that is not my intention whatsoever. Hope you understand :)
@LPowell Yes that is the card I have been using the whole time, especially when I was reporting my problems here and indeed it is unfortunate that the file system they persist in using is FAT32 but I would consider this minor, the file-splitting thing is not a biggie for me when it comes to capturing :D
Not too long ago I have taken my newly recorded Flow Motion v2 1080i50 footage into After Effects, and actually I am able to distinguish the frames from the I-frames and it doesnt look too pretty (just being honest!) This is probably why I favour Intra-frame recordings and went with Driftwood's patches before but was having imense problems with them. This is also why I mentioned of the P-frames, I think it would noticably help the image quality as it contains motion-compensated difference from the I-frame. The B-frames is what I was referring to them not looking too pretty by the way.
I know this may seem quite abit to ask, but is it possible to make a Intra-Frame Flow Motion where it is able to playback incamera and for it to span successfully in all modes? Or even keeping your GOP3 but the structure at I-P-B?? Right now I'm going to see if the camera will span completely (filling up my SD card) on 24p ISO12800. This should be interesting :D
@GH2_fan Yes, that is a 95MB/sec Class 10 SD card, and it's good to hear that you were able to confirm file-spanning with Flow Motion v2 at 100Mbps. ISO 12800 is an extremely noisy setting that I'd recommend against using in general. Closing the current MTS file and opening a new one in the middle of a high-bitrate recording is a fragile process. It's unfortunate that the GH2 and most other SD card cameras persist in using an archaic file system with a 4GB file-size limit that forces the camera to juggle files in this manner.
Flow Motion v2 1080 modes are designed to use a 3-frame GOP with very fine B-frames whose image quality is indistinguishable from its I-frames. There would be no value to downgrading its encoding efficiency with P-frames.
@LPowell Well I just came back to my camera and it seems to have filled up the card with no problems in 1080i50 on ISO3200 at 100Mbs :D I understand what you mean but the only 'failure' that happens is when recording at ISO12800, but I'm glad you've pointed out that it's a poorly implemented feature (how did you know this?). So recording at 100Mbps seems to be fine afterall.
Also to let you know THIS is the card I own and bought from: http://www.amazon.co.uk/SanDisk-Extreme-16GB-SDHC-Card/dp/B005LFT3MA/ref=sr_1_1?s=computers&ie=UTF8&qid=1340579623&sr=1-1
Regarding the AVCHD encoder, I was pretty sure it did do P-frames, wouldnt a I-P-B frame structure weild better results? And either way, isnt it possible to implement this as well?
@GH2_fan When the GH2 stops after filling up a 4GB file on a slow SD card, it is a card limitation rather than a patch failure, and there is nothing to fix. If you want to record lengthy videos at 100Mbps, you'll need to invest in a 95MB/sec Class 10 SD card. Even with that, there may well be certain conditions at the extremely noisy ISO 12800 that interfere with file-spanning, as it is one of the camera's most poorly implemented features. In cases where file-spanning at 100Mbps proves unreliable, I recommend using Flow Motion's 24L, SH, or H modes, which are limited to 60Mbps for this purpose.
Regarding your technical question, the AVCHD encoder always uses an IBB frame sequence, it is a built-in feature of the encoder.
@LPowell Hello again, I have just discovered something, I am currently doing another (static) shot recording at 100M in 1080i50 at ISO3200 and it seems to be going along fine, at the moment it's got 6mins remaining and it has not failed on me yet...sooo...it probably means that having it at ISO12800 seems to be the trouble, can this be your next fix? :D
Also I forgot to mention, when analyzing the video files (I left the GOP at 3), I saw that the frame type structure was I-B-B. Shouldnt it have been I-P-B may i ask?
@LPowell. Thanks for the explanation. That certainly clears up the questions I had.
@RockHunter Flow Motion v2.02 is an integrated PTool patch file that is designed and tested as a complete, self-contained update to the GH2 firmware. It is intended to be used exactly as delivered, with no changes made to any of its settings, both checked and unchecked. High bitrate GH2 patches are complex and difficult to optimize and test thoroughly, and are not really designed for end-user customization.
There are, however, two settings that may be freely adjusted without running the risk of destabilizing Flow Motion's 100Mbps 24H, HBR, FSH, and SH video modes. The 24L, FH, and H video modes have been set to about 60Mbps peak bitrate to support 4GB file-spanning when using Class 10 SD cards rated lower than 95MB/sec. If desired, you can adjust the 24L Video Bitrate setting or FH/H Video Bitrate to any reasonable value up to 95,000,000.
When creating a bin file with Flow Motion 2.02 (and all other patches), many of the options are pre-selected but a few of them are not. I'm guessing that those that are not checked were left that way for a reason. Can you shed any light on why they were not included and whether any of these options should be checked? For example Auto Quantizer for 1080 modes and for 720 modes? If yes, then which level from 0 to 4? And audio AC3 compression, yes or no? What are the pros and cons for selecting or not selecting these items? Thanks for the help.
@LPowell But I am using a 16GB Sandisk 95Mb/s SD Card that I bought specifically (from Amazon) for applying these patches, I have mentioned this in my previous posts here. The fact that when recording at 100M at ISO12800 in 1080i50 and for it to stop at slightly random times, just got me wondering...
@GH2_fan It's because the slower Class 10 SD cards cannot reliably support 4GB file-spanning at bitrates much above 60Mbps. That's why I recommend using FM2's 60Mbps 24L, FH, and H video modes when you need file-spanning on Class 10 cards rated lower than 95MB/sec. With the fastest SD cards, Flow Motion v2 supports file-spanning on all of its video modes.
@LPowell Well what I'm actually after is probably what all of you are after as well, to be more definitive what I'm saying, I obviously want to capture footage at the bestest quality the camera is capable of but without any fault i.e. random cut-offs at any decent bitrate setting and high ISOs which was my problem when trying out Driftwood's patches. Also, wanted to try and keep it (as close to) Intra-frame recording to help things in editing and keeping frames of high quality.
My SD card seems to span well when recrding on 50M (lower bitrate) in 1080i50 but not so on 100M (higher bitrate), this seems to be my only problem. Could it be because I raised it to 100M from 95M as you set it?
Amazing cinematography!
@GH2_fan I'm not sure what you're looking for. A recording more than 9 minutes long will most likely need to span across more than one 4GB file. Before experimenting with untested patch alterations, I'd recommend testing your SD cards to determine their spanning capabilities. While 95MB/sec Class 10 SD cards should be able to span in all Flow Motion v2 video modes, slower Class 10 cards have only been verified to span reliably in 24L, FH, and H video modes.
@LPowell Thanks for that info, I went ahead and reapplied your settings 'as-is' but yet again changed the bitrates to 100M and 50M, and interestingly (all done in 50i) the 50M seems to have recorded all the way through, however not so much luck again with 100M, whilst it did much better it did cut off at 19mins and 9mins when attempting this twice, both of which was done on a formatted card (meaning I formatted the card everytime I did a new record setting).
Now I havent yet seen the files on my PC yet (battery died) but why do you think the camera cut off at the higher bitrate on random times perhaps?
Mind you, this was all done statically, no movement and at ISO12800.
