B4 lenses and mounting solutions
  • 147 Replies sorted by
  • And what would happen if is screw the back Off an old kitlens, keeping the optical element at the back. And place the EOS ciecio adapter on there. Would that retain infinite focus without upgrading the image too much?
  • would it be possible to take such an FD converter, and place the B4 mount of cieco7 in place of the FD mount, and keeping more focus distance
    Image quality will be bad :-(
    You can just get Panasonic and NEX body, not necessary GH2.
  • Hey all,
    Most of you all use a GH2, but I would like to use a B4 2/3" lens on a Canon 600D. I already know of the ciecio7 adapter, but like Turbodog, I am not pleased with modifying the body. I thought about putting Macro tubes in between the two pieces. Unfortunately this means that I will lose infinite focussing and will only have very shallow depth of field at the front of the lens. I think the teleconverter of Turbodog shifted this shallow depth of field to the long end of the lens.
    But then I read about FD to EOS adapters, using optical correction to make it able to use older FD lenses on EOS bodies. So my question is... would it be possible to take such an FD converter, and place the B4 mount of cieco7 in place of the FD mount, and keeping more focus distance?
  • An interesting comparison between the use of 2x extender and digital zoom on a GH1 camera with a B4 lens mounted on.
  • @AthenaProductionsNet Ok sound great. Thanks
  • @Petee28, is it possible the adapter is physically short enough to take it out of the 'back-focus' sweet spot? I will post the measurement of my adapter when I have it.
  • @Galvoguru, there is a "DC 12v to 6 Pin Hirose Cable" on eBay, not cheap at $63. Link here:
    http://www.ebay.com/itm/DC-12v-to-6-Pin-Hirose-Cable-AF100-GH2-Power-B4-2-3-Fujinon-Canon-Nikon-Lens-/180895600493?pt=LH_DefaultDomain_0&hash=item2a1e37cf6d#ht_1666wt_1371
    I have one on order.... Like you, I long for a variable speed, internal mechanism lens for live events. I am working on a killer tripod plate made of stainless steel right now.... Music Videos, here I come (again). Stand by.
  • Guess not. Seems to be identical to this: http://www.ebay.com/itm/B4-to-micro-4-3-lens-adapter-Canon-Fujinon-2-3-Panasonic-AF100-GH1-GH2-Olympus-/170859098271
    "Suitable for lenses without handgrip/zoom rocker. The orientation of this adapter does not allow the use of lenses with handgrip attached."
  • @Roberto Is the P-V deal adapter compatible with Fujinon A14x8.5 BEVM lens? I remember reading that some adapters are not compatible with B4 lenses which has integrated servo zoom.
  • I have a Canon J15x9.5b4 and I cannot get it to focus at all on my gh2. I tested it on a 2/3 camera and it focused great. I'm using 2x mode and ill attach a link to the adapter I'm using. If anyone has any suggestions or solutions I'd appreciate it. Thanks
    http://www.ebay.com/itm/Adapter-MICRO-4-3-GH2-GF3-G3-GH1-AG-AF100-AF101-AF102-Mount-2-3-B4-Lens-/370593516398?pt=LH_DefaultDomain_0&hash=item5649184b6e#ht_4439wt_1094&afsrc=1
  • I bought the polish adaptor to use with my GH2 and my Canon J9x5.2, got the best results using the 2x extender, need to do more testing though. One thing, nobody seems to have mentioned the fact that these lenses have super-smooth, variable speed zoom, I've made a living out of video using ENG 2/3" cameras, all of which use electric zoom, the reason I bought the adaptor was to enable me to use my 2/3" lenses and my matte box and filters. I would love to try a broadcast 2/3" HD lens to see if there's a difference... Does anyone have the wiring for the lens Hirose connector? Also the GH2 has a built-in speaker, has anyone had alook at the speaker inside the GH2? It would be nice to take a feed off this and connect it to a headphone amp...
  • @kavadni Earlier ones did have focus ring markings at the top, mine does, apparently fixed later. No play at all. Cannot compare to the Ceico.
  • Has anybody used the $99 adapter available as a PV special offer.
    Does it align lenses pointing upwards? How much play did you experience .. that is, is it a nice tight fit?
    How does it compare to the cecio?
  • thanks guys. BTW: i've also had the same problem with a Angenieeux T15x8.3 AIF. I'll have a look at that soon and let you know!
  • I use Canon B4 lens and didn't have problem with glow. If he has problems with glow with two different lenses, I suggest trying a coating on inner side of the adapter...
  • @Grunf he uses the ciecio adapter the same that I use, it is gr8 adapter and it is not that cheap
  • @DirkVoorhoeve "I've tested with a few more B4 lenses but with all I get a glow around highlights."
    That might be adapter ring with reflective "inside". I get this with FD 55 f1.2 as well when using cheap adapter ring. Stray light bounces off the edges of adapter barrel and strikes CMOS chip at weird angles, giving "halo".
    Try coating the adapter ring with something non-reflective.
  • @DirkVoorhoeve wow thats bad, I also wanted to buy 9x5.4 but did't have the money.
  • A Canon IF+ J9Ax5.2B4 (with extender) and a Fujinon A12x10BRM-88 (model VCL-1012BY). Both are very recently revised, so it's not the lenses.
  • @DirkVoorhoeve can you specify the lenses that you use?
  • Ive tested both. I found it gets better if i adjust the backfocus, but it doesnt disappear. Any suggestions?
  • @DirkVoorhoeve do you use lens with built in extender?
  • I've tested with a few more B4 lenses but with all I get a glow around highlights. It's at all apertures, and everywhere in the frame (not on corners only). Anyone else got the same problem / solution?
    @Roberto Thanks for the link to the mod thread. We'll move this mic-idea there, shall we?
  • @Turbodog I am interested to hear that the B4 to EOS adapter didn't work out for you with the Kenko 2x adapter. It sounds like there must have been an issue with the flange depth. Perhaps the Kenko ES mount on the extender is a different thickness to the camera one, in that case maybe it would work with shims or on a Canon extender?? I presume you tried playing with the backfocus adjustment on the lens.
    Even though you couldn't get it focussing to infinity at the long end, did you get it working well enough to determine if the corner image quality was improved over using an internal 2x teleconverter in the B4 lens? I would imagine it should be
