I own both. What are you trying to get to match? Color?
I have the HMC150 and the GH2.
Vibrant on GH2, and 'spark F3' setting get it pretty close. I believe it's b press gamma, sharpness to +3, master ped to -5, chroma to + 3 or 4.
I find cine-gamma on hmc150 and cinema on gh2 gets reasonably close as well.
Both require a bit of color tweaking to fully match.
hmc150, white balance on a white card like normal. GH2, white balance on a white card with custom balance set to a few ticks towards blue, and a few towards magenta. I use colorista to color correct, and I found that I had to pump up the contrast/saturation on the blue tones on GH2.
The hardest part for me is getting the yellow/green hue out of the GH2.
I filmed a short using a HMC150 as a B cam last weekend and it wound up matching pretty well. With some slight color grading it's difficult to tell the difference in the footage. A lot of it simply came from lighting the scene well and matching the white balance and aperture I was using Sanity 5 and Smooth -1, 0, -2, 0 on the GH2. Not sure about the settings on the 150.
found a old topic,
Both Wb was 3200k. I had my gh2 a few notches inside the Blue channel on wb too
HVX settings: "GH2 HT" 720p30N (client request), 180d shutter, ~35mm (~250 effective), f2.8 detail: -4 v detail: -2 detail coring: +4 hroma lvl: 0 chroma phase: 0 color temp: 0 master ped: +5 gamma: cinelike V matrix: norm STD: off
GH2 settings: FSH mode, SS=60, ISO=320 Leica Summicron-R 50/2, f2.8 Custom Film Mode, -2, -2, -2, -2
ill try some outside tests tomorrow.
