Driftwood Quantum X Settings, Series 4: Cluster v2, Mysteron, Sedna, Orion...etc...
  • 1015 Replies sorted by
  • @proaudio4 - Surely the hack process began because of the remarkably poor quality of the 17mb/sec GH1 codec, and the lack of 25p in the GH2 prior to the 1.1 firmware. In the last 15 pages of this thread, I see a great many examples of people's beautiful hacked movies, but no actual comparisons with stock, that's my point. It's worthwhile to create an actual split screen and see if you or any of your film's viewers can actually see the join once it's graded and has had even rudimentary post. Otherwise, we can all too easily get excited about how great our movies look, but we won't make much genuine progress.
    I do see effects from Mysterion, though so far it might be hard to pick in a blind tasting. Perhaps my expectations are unrealistic, or my settings wrong, or I'm looking at scenes that just happen to work well with stock settings. Which is why I'm discussing it here, I have no interest in an argument.
    Thanks to all the serious testers putting in hard work on this.
  • I think it's kind of like MP3 files. Not everyone can notice the difference between a 128kbps and a 320kbps file. You have to have an ear for that sort of thing.
    Of course with video it is a little different but the comparisons are there. You just have to find out what works for you and do that.
    I shoot quite a bit of landscapes and buildings here in Japan and I notice that the higher bitrates do help with keeping things looking sharp and clean. Especially in low light. Using a GOP1 setting with a high bitrate really does make a difference to me.
  • @peternap
    Everyone concedes that different lenses produce different results. But I don't think it's unreasonable to ask if there are significant differences between hacked and unhacked footage shot under identical conditions, and if those differences are readily perceivable either before or after customary post. (Also, it would be interesting to know, assuming differences can be perceived, at what frame size or GOP structure, beyond which there's no added benefit.)
    Proof of that claim is all itsguy was asking for, if I understood him correctly.
  • @jrd Some of the LA people are doing tests but I don't think they've put anything together to look at. As a rule, everyone is doing their own testing because we all have different needs. I shoot mostly in 720-60 so my choices are a little more limited.
    There are also so many different things to look for, how a setting responds to color correction or grading, macro blocking, etc, you could write a book on it.
    Then you have to consider the different lenses used to test. I have 9 lenses I use with the GH2 and the settings respond differently to each one.
    Asking which is better is a little like asking what the best rifle to hunt Deer is.
  • @proaudio4
    I haven't gone through the entire archive, but if there are detailed comparisons of identical stock and hacked footage, color-corrected at levels likely to stress the codec and reveal differences, could you indicate where?
    There have been stills posted within the last few weeks, subjected to maximum levels of saturation, and those did reveal differences in noise, if I recall. But is there anything comparing the results of cc more in line with what might actually occur in correcting footage for actual release?
  • Of course stock GH2 footage looks great. If it didn't, Vitaliy would never have bothered to hack it. Here, there's been endless display of showing differences between hacked and not hacked. If you're not seeing it, go back to stock and be done with it.
  • @Itsguy If you really want to see a difference, you should shoot both unhacked and hacked flat...then go in and do the same post to both. You should see the difference then and yes, I agree, stock firmware looks very good beside the hacked settings and it requires a hard took to see any difference at all.
    The devil is in the details.
  • jrd - Sorry, my mistake. Stock 24p and 25p are of course running the same bit rate. I thought I saw a big improvement in 24p but on closer examination it was just a focus issue with the stock footage. Obviously I would hope for major improvements over lower bit rate stock 720, which is very useful.
    JWalters - I was also stunned by my hacked test footage... until I compared it frame by frame with unhacked stock HBR of the same scene shot at the same time, and could see very little difference at all. Mysterion did at least have some results (a different grain feel), while in my tests so far many other popular settings did nothing much at all in terms of detail and compression artefacts. It's all too easy to get carried away here, bring on the science!
    Sorry for this voice of doubt, I hope it's temporary, I love the GH2 and I want to believe! But I haven't been able to create a convincing side by side, split screen test yet, and I haven't seen anyone else's. For some reason this isn't what people are concentrating on - just great looking films in isolation, without side by side evidence. This has to be scientific, as a lovely shot with a good lens will always look convincing, regardless of the actual encoding - even recompressed on Vimeo or YouTube where it's meaningless.
    It is not my intention to talk down all the fantastic work being done by everyone here, and I hope to help with it. I want the best possible settings too. However, since I am using hacked and unhacked bodies side by side, shooting out the window of a fairly well specced edit suite, I am trying to understand better why I see very little improvement as yet as compared to stock HBR, just minor tonal variations or slight sharpening of grain, without much if any perceptible detail improvement in still or moving footage. Perhaps it has something to do with the scenes or settings I am using, with is why I'm checking with you all here - though they are typical real-world scenes where I'd want to see some results to make it all worthwhile.
    None of this applies to other, lower bit rate modes, which are no doubt vastly improved. Other improvements like PAL-NTSC switches and record limit removal are obviously also extremely welcome. But my goal is to find side by side improvements over stock HBR mode which non-scientists can clearly see and appreciate!
  • I have been stunned by Mysteron and the progress since I first starting using the great hacks here last August (kaes/butt). For me Mysteron does it all. This was taken at f8, 1/50th, kit 14-140mm lens, iso160, 5200k WB, nos -2-20-2, 24p cinema, variable ND, placed in CS55, fast color corrected for WB, luma adjustments, mild sharpening and rendered out at 24p, 30 CBR mpeg. Eye-wateringly delish. Many thanks Driftwood, VK and all.
  • @Itsguy
    Could clarify your comment that the improvement with the settings is apparent in 24p, but not HBR mode, "given the lower 24p bit rate"?
    I believe the rate of both is 24mbs, if you use the 24H setting for 24p. Are you saying you see definite improvement in 24p, but not HBR?
  • Edit to above - to clarify, I meant I was using cinema picture profile / gamma in HBR mode, not 24p cinema mode.
  • This is my first post so please bear with me if I'm missing something.
    I'm a professional, and have delivered several music videos and corporates shot with the GH2, sometimes side by side with 5Ds (mk II and now III). I also have Sony XDCAM, RED and Arri Alexa s-log footage, and even shots from old super-16 and 35mm neg, to compare. I love the convenience of working with the GH2, and I'm excited by what everyone here is doing. So excited, I found a spare body going cheap and hacked it. So now I have one hacked and one unhacked body, which makes it easy to do more or less scientific side by side testing.
    I've been comparing a bleak rainy view of the back garden, and a soft grad of bathroom tiles and underexposed noisy areas, using cinema mode, 0,-2,0,-2, 200 or 400 ISO, and either a 1.7 Pancake or a Zeiss 45mm f2 prime from a Contax G2. I've mainly been looking for improvements in 1080p25 HBR which is what I would generally use in real life. I've used a combination of static, slow and wild panning shots, and analysed the results imported as ProRes HQ in FCP7, at 100%, 400%, 800% sizes, frame by frame and moving, on an accurate broadcast monitor.
    I've tried a range of popular settings, compared side by side with the exact same shot using stock HBR. I'm posting in this thread as the Mysterion setting was the only one so far where I could see anything much of note going on at all. While the improvement in 24p is there for anyone to see, and not altogether surprising given the lower 24p bit rate, in HBR mode the improvement seems at best subtle, or perhaps even debatable.
    Am I missing something, or have I done something wrong? Or is stock HBR already pretty close to the limits of the AVCHD format, 4:2:0, the chip, and other non-codec related factors?
    Hopefully, I'm in a good position to help test which settings really make a difference. Thanks for any advice on the best direction to go to see genuine improvements in HBR mode.
  • @xavieramelio thanks and glad that you liked it. I did some heavy grading with MB looks. Shot in 24h with panasonic 14-42/pancake 20mm and olympus 45mm i really start to like that small lens.
  • @shian thanks man the music is a big part of the video. I chopped it a bit though to make it work with the different clips
  • My first post. Butterfly Garden, Key west.
    Thanks to Driftwood and Vitaly for the patch. Thanks for all the users with their input.
    Panasonic GH2 14-140mm 1080, 24p converted to 720p. Orion 4b patch. Nostalgia -2, -2, 0, -2. Color Graded.
  • @magixian lovely pace and variety of different-sized shots! Thanks for sharing. Beautiful bikes, too.
  • @Swiss_Boy that Rambo soundtrack is awesome. Looks fantastic. Great work!!
  • @Swiss_Boy, beautiful images, wich lens and film settings did you use? Any color correction? Thank you
  • Hi everyone. Here is one of those hundreds of works made possible by Vitaly and Driftwood and this whole great community. Only YT quality, sorry for that, but I need it THERE. Made with mysteron. Nothing extraordinary (quick work), just to show that there is another thankful user.
  • Another SEDNA A AQ1 video before Canis comes out i also used 5DtoRGB in this one
  • Great stuff so far! @driftwood keep up the good work. Can't wait for Canis, it's going to be epic. ;)
  • Canis Majoris (VY CMa) ist ein roter Überriese. Dieser Stern ist der größte Stern von allen, deren Größe bekannt oder abschätzbar ist und vielleicht auch einer der leuchtstärksten Sterne.
    Na dann lassen wir uns mal überraschen.. ;)
  • Looking forward to it!! :)
  • so tomorrow is gonna be the "canis majoris" day,....
  • @Greek_m43 Nice work! I watch 13 news btw.
