Driftwood Quantum X Settings, Series 2: Sedna A, B, C
  • 1030 Replies sorted by
  • @davidhjlindberg Wow loving your work! and the Samyang 35mm 1.4, very Sharp. about to Buy this lens but can you give me some info on yours is this the canon version? and what adapter was use? Thanks
  • dark matter v3 nostalgic -2-2-2-2 another grading test. This time i pushed the footage pretty far. Love the details kept in the image!
  • @paglez general i use neat video at 3200 iso. i use one denoise profile for all my videos.
  • The paid version does batches - I was mostly asking though just from a workflow standpoint. The clips feel like they had a lot of latitude in the shadows while still be well-exposed for the white snow, so I was wondering.
  • @Oedipax Thanks! I was using Nostalgic. Forgot to mention that... Nope, I think 5DtoRB can only transcode single files, and not groups, right? And if that's true it would take too long time.
  • @davidhjlindberg, looks great! Nice and crisp, great colors too. What profile were you using? Did you transcode with 5DtoRGB and do any grading before editing?
  • @BillC My last test used short clips but after 10 seconds, none of the following cards had given me any trouble in 50p SH mode (while Span... V1 had trouble on many of them in 6 or 7 seconds).
    Transcend Class 6 32GB Blue. Transcend Class 10 32GB Black. Transcend 64 GB SDXC Black. Delkin Elite 633x UHS-1 16GB.
    4b, 4c dm1, 4c dm2, 4c dm3.
  • Here's a commercial I made with v4b Orion constant bitrate. I used Samyang 35mm 1.4 and my camera settings was -2+2+2-1
  • Quantum X v4 Orion test that I posted yesterday ( above ) I used a 16 gig, 30md Sandisk Extreme Class 10 had zero problems. I use SDFormatter V 3.0.0. once completed then I put back in camera and format there as well, takes about 3 seconds to do both. No problems, and yeah I can see playback in camera monitor.
  • Hello, I just tried v4c with 45MB/s Sandisk Extreme Pro. GH2 stops recording randomly (27 seconds, 160 seconds) in 24P mode (files show 144kbps). In HBR mode no problem, bit rate is 74kbps. Does this excellent patch require 90MB/s Sandisk for 24P? Thank you...
  • @Meierhans thank you for the info,.. then why we shoot all into -2?? same reason recently i started shooting in +2 sharpness thats just because of the orion v4b and its capability,....we reached far most i feel,..a boon for budget film makers,..the new intra matrix orion v4b,.. nost -2 is very nice,.... what u think?? did u tried v4d??
  • @Driftwood I found your choice of picture profile quite interesting! I also like Nostalgic but some say that it gives a yellow cast over the image... What are your toughts about it? Do you find it the best setting combined with your patch?
  • @Kihlian I tried the same card (which I have in my vast collection now!) and tested HBR 25p without problems. Check your install procedure first. See stages 1 to 8 on page one of this thread and check ptools, check you havent accidentally overwritten your panasonic v1.11 firmware, check the settings. Finally, some cards of the same make and model are genuine/made to the calibre... some are not.
  • @Giovassi @Rammstein I have SanDisk Extreme HD VIDEO 30MB/s 16gb Class 10, tryed the Quantum X (v4d Orion) CBR with 'Dark Matter v3' Matrix, in 25p HBR camera freez, have to remove battery..
  • From the tests I've seen posten on vimeo the Dark matter V3 is the one that gives the least ammount of "blue noise" in the image. Is this patch usable outdoors in bright light or is this one made for only low light situations?
  • @Rammstein Pictoris v5d, I guess, I use the VBR version. All my cards work with all settings and I'm very happy :-) It should work for you also.
  • Gonna take either Pictoris or Orion to the Cebit tomorrow and the day after. I bet that'll be interesting.
  • So... does the camera work better with a 3200ºk bw? should i always shoot like that and use a 85 filter outside?
    i thought it would be the other way around just to get rid of IR polution..
  • Driftwood. For class 10 You Don't have nothing ?ALL PRESENT DRIFTWOOD SETTINGS are for extreme memory card? I tried v5b Hybrid Matrix and 25p HBR freez my camera .
  • @stray thank you, I check out if I found a thread about editing, I hope I can get my workflow going and be able to contribute with something helpful here. I will keep following this thread also, I am very interested in Driftwood settings and anything I can learn from this. Best luck to all of you.
  • In camera noise reduction is cheap and kills details. With the high bitrates possible today much better results with denoise in post.
  • @driftwood which is the best profile setting,...why we keep noise reduction -2 all the time? is it useful or necessary to keep noise reduction filter to -2 even in higher iso?????
  • @driftwood cinema all -2??? u prefer cinema over smooth??? never tried before tried only smooth and nost all -2,....i think i missed one,.. ;(
  • @pop24 Did you use Neat video or similar in postpo? Is very very clean images. What settings did you use?
  • @klem007 Yes, not aware of it, I've clipped the RED channel many times. There's something going on here.
    I need to find the time to get back to some testing. I've been buried in work and also a music project.
    I'd like to give this whole noise discussion a good rogering with some controlled tests.
