I think that is Vitaliy is recommending the usage of Elecard Streameye for visual confirmation. As StreamParser was reporting my 1080i60 files as 1080p24w but on visual inspection they were most definitely i60
Probably trying to run before I can walk but finding it difficult to get "1080 progressive" working without the camera saying the card speed is too slow. Have tried duplicating the encoding and GOP settings of both the 24p and the 720p60 modes to no avail.
I'm thinking the "Overall Bitrate" 1 & 2 do nothing but change the video tag information.
Look at this clips using trial of Elecard StreamEye. Post screenshots also. We must be sure that it don't do any fancy things (look at reported 24p in wrapper).
Note the streamparser reports it at 1080p24W but it's not it's most definitely 1080i60 I can still see the interlacing and it handles the whip pans far better than p24
The bitrate figures didn't change at all.
Have done some more recording, with a smaller aperture and taking my camera on a flying "Starwars" run. Camera didn't crash at all, despite the high detail and motion. Getting codec breakdown of course though
But even in all these preliminary tests 1080i60 with B frames looks better than without it, at exactly the same bitrate
Ok I think the Panasonic engineers hoped that the GH2 would be hacked this time around. I've flash my camera half a dozen times now. It is solely the Encoder Settings 4 that is responsible for whether or not B frames are in the encode or not. The only reason why I thought it might be is because it is the only setting which 24p doesn't share with the others at default.
I was trying to get 1080i60 to get B frames, easy enough right, put the setting at the same as in p24 mode,8 , but no not so easy sure it gives you B frames the footage is horribly jerky and a low bitrate. At a whim I thought what the heck I will use the value of 16 since the original is 17, one less. 720p60 is 9 and 1080p24 is 8. Bam I have a 17mbps file with B frames that is still at 1080i60 and it seems beautiful so far. Will have to do more testing though as I didn't have a detailed scene, only a static with the fast whip pans.
@mpgxsvcd You were asking how to do a screen capture? Depends on the machine but if you have windows XP like I do, there's a key which is usually somewhere near the top right of your keyboard called PrtScn or PrintScreen or similar.
This key on its own copies whatever is on the PC monitor and then you paste (usually ctrl+V) the image into whatever graphics editor you use and can crop it there.
This key together with Alt copies just the top open window (quite useful).
If neither of the above work, you may need to experiment with / without the F Lock key on.
BTW you can also use it to take a grab of a bit of video being displayed, and the video has to be playing in order to grab it, so a bit hit-and-miss. Resolution will be at your screen resolution in all cases.
Apologies if this is stuff you already know, but hope it's helpful to others with XP.
@plasmamp Thanks for all this! Looking promising. Just noticed that the version actually on YouTube (as opposed to your embed in this list) also has the "original" resolution option which is presumably the best one to watch it on?
@mpgxsvd - tried your patch. Causes motion recording cancelled on all the cards that work with the 100mb patch on the gh1. Maybe its time for some high end Sandisk cards
I have consistent 720p @ 60 FPS with B-Frames working. This is actually a break through for 720p. I have 28 mb/sec average + BFrames working in iAuto mode. It is absolutely stunning. Uploading samples now.
I got B frames to work with 720p. I just duplicated the 24p settings for the 720p settings and it produced similar bit rate video with B frames. It did fail in iAuto mode though. I also tried the same settings for 1080i and it produced a lower frame rate video that was useless. I will try some more tests and then post the results spreadsheet.
Here is an empty spreadsheet in a MS Excell format with all of the values listed. Makes easy to keep track of experimentation. Hope it helps. Was created with Excell 2007.
