So who would like FF gears for their OCT-18s? :)
  • 32 Replies sorted by
  • Looks good, but I own RAF gears for the OCT-19s and the quality on them is great. A bit more expensive, but IMO, worth the price as they fit perfectly!
  • Aye regular gears - Cinevate are great but going to pop Rafs on the Lomos - made for the job :)
  • @soundgh2 cheers for the pics and review! Looks good.
  • Does the fit seem tight enough, once the gears are in place? (on the lomo's) Or does it seem like there could be some sliding action?
  • The fit is sturdy as the nylon tips do angle to the surface you point them at very well - shouldn'y have any problems to be honest - will try the 18mm and 22 and 28 later see if they work as well - the 35 50 and 75 are pretty much the same fit.
  • Thanks, sounds like it will be all out cinevate then.. I'd rather keep the same kind of gears for the whole set and 5 RAF gears would be a bit too much. +I'd get an additional gear for future additions to the set / to use with other lenses. Should work brilliantly with my LPT FF.
  • The width helps on the Lomos as they wind out a little on some
