@mikus : check your pm for the explanation of an hack process, in french.
What There is no hope of, c is really a shame to condemn him
mikus, no hack.
hack is possibly possible, but uncertain if entirely doable.
check again next year :p
ok I read every post, but I don not come to understand or are the D7000's hack, and especially if there are already what is new in the video function
thanks
@ Micah: the mechanical limitation is how the aperture arm is operated, on the d7000 it is using the same motor used for the mirror up/lock function. thats why you have to disable and re enable live view , to get the mirror down, so on the way up the new aperture setting takes effect, they did not do the same for the D4, the D4 is not the D7000, it has a dedicated aperture drive not connected to the mirror. its nothing you could fix with the software.
@swfree: this is not a mechanical limitation. The new D4 has the same mechanical aperture arm actuator and works fine with video (or at least during live view, which if unlockable would still be an improvement!)
by neogene "My only missing for d7000 is the lack of ability to change aperture during video recording"
sadly this is mechanically not possible due to how the d7000 aperture operating mechanism is constructed, it is not a firmware fixable thing, you better get some manual aperture lenses, or get a manual aperture ring
to me please
Hi !
I just wanted to know what are the current progresses on the D7000 hack. Is there any news ? Thanks for the work you've done so far.
