Hi there everyone! I've got a question and found no topics better suited for it like this. I have a european GH2 (Hungarian) fw 1.0 without hack. I see on the hungarian panasonic site that 1.1 is not available yet, maybe not have been translated yet. My question if it is possible to load the fw 1.1 from the link on the first page although it is not for my country? Or does it count anyway? Another question is if it will be available to hack it (even back to 1.0fw) after 1.1 is installed? Thank You & have a nice Christmas to all of You!
Hello guys, i'm new to all that i actually had problems with dead pixel on the first GH2 i bought so i m only now ready to upload the hack...Except that i tried and when i push play it doesn t ask me if i want to upgrade the version...But if i put the official update 1.1 in the SD Card it does work...So i suppose it's not a problem coming from my card...
Off course I didn't do the update at 1.1 because i want to use Vitaliy's hack...But I need help on this one...
I'm on a mac i opened ptools i opened firmware v10, check version increment and uploaded SpanMybitchUp...i saved the firmware with the exact same name as the new firmware update...I copy it in my SD card, i push play and nothing happens, it just tells me that there are no pictures to show...
@AlexManta Make sure you put two under scores __ and not one _ This is the most common issue. Also in pTool make sure you check the version increment box.
@phenixone yep i did all that...i don't understand the problem...i would believe it is an SD card problem but if i put the new firmware update .bin file in my card it asks me if i want to update....so it must be with the build i created....
@phenixone Hey I've found my problem, It seems i had to update to the new panasonic updated firmware first...Then and only then I was able to upload the Hack in my camera...It's good to know....
Don't think that way, Vitaliy. Your work will give us HBR mode with high bit rates. That's a great and important thing, regardless of whether it's the latest Panasonic firmware or not.
