1.) What, in layman's terms are the notable differences in these: cbrandin's 44M AQ4 cbrandin's 66M AQ2 mpgxsvcd's 42M AQ4 driftwood's SPANmyBITCHup' INTRA
2.) Will they all record continuously? I think I am picking up on the word "spanning" as a way to define this. (right or wrong?)
I am shooting 24P with a class 6 card, for reference. Rob
@pipoland, I have not heard this and wonder where you did. I think maybe you are confusing models. I have a GH2 I bought 1 month ago, and I had it hacked day one.
1) in case others get the same error as above, to fix i reset all settings and reformatted the card.
2) a possible bug? i just updated my gh1 to use LPowell's GH1 & GF1 : Reliable In-Camera Playback Patch - Version 2. i also selected maximum iso limit removal. when not recording the selected iso was used when recording the ISO display changed to auto (i know this is a known bug) however the display (and recorded file) changed to what looked to be 200ISO, regardless of what it was set to!
FIRST: THANK YOU ALL FOR GREAT JOB with GH2 patched firmware :-) I want to buy a GH2 and I want to use the patched firmware. Can I buy any new GH2? I heard that some models (newer/older) can't be patched... maybe I am wrong. Thanks guys for your replay.
Hi everybody. The Panasonic firmware update coming soon, with a new video mode and some features. Just want to ask if someone know what can we really expect from this update?
@mee i have the 32gb 45mb/s. I have a 64gb sdxc on the way. Has anybody noticed some of the other features not working after using the patches? I cant get the highlight feature to work.
recommended card for best throughput was the Kensington Ultimate XX, however the new Sandisk sdxc might be comparable, don't have benchmarks on those yet.
egh, like pulling teeth, but they are finally budging. I will post what they offered in the sandisk extreme card section. Would appreciate some advice.
Anyone have any experience with panasonic cards? After waiting ridiculously long for simple responses from sandisks online help desk I am getting fed up with this company fast.
@jeffryalan WOW, that sure does explain allot. I was already pissed at this card and sandisk, now I am more pissed. Anyone know if I can simply say I am extremely dissatisfied with this cards minimum write speeds for my return? I had a less than satisfactory experience chatting with one of their people, but I did not have this info at the time.
hello, it's my first post, so sorry for my basic english. I ve done a short film in 16mm (so 1,33 ratio) and i would like to continue this film but with my GH2. i tried to find the answer but ... what the better way to have the better result in 4/3 image. is there any patche existing, is it the same way than anamorphic expérience? thank you for all your works.
@kenoah, refer to my post above. I have the 16gb 45mb/s from sandisk and it has all kinds of errors if I try to use seaquake. Aquamotion2 works well except for 80% slowdown, and a few other rare errors. Allot of people have mentioned problems with this card line.
@frogman, I am guessing it is your card. I have a sandisk 45mbps card, and I still have issues with aqua2, seaquake, and the seaquake for lesser class 10's. Try spanmybitchup from driftwood. I have had no problems using this patch. I am going to be returning my sandisk, but want to save up for the 64gb 95mbps sandisk card since this apparently is tits as the kids say.
@jard667 forget HDV, wrong frame size, just use avchd
@glebnagorny No, no matter what patch you're using, the codec is based on the avchd standard. Everything works as it should with avchd, 1080p progressive 24.
actually with the hack I have found files easier and faster to edit with in both PP and AE
Aqua2 working perfectly now. I changed the dimension settings back and fixed the playback problem. I ordered a 64gb card and will be tesing out the seaqu
