@kholi Your saying " 1/50 is ugly, has been since the dawn of 24p digital cinema, will be until it dies out." isn't quite consistent with your to each his / her own stance.
I would of course like the 1/48 option. But I also suspect the fact that the 24p of the gh2 (and many other digital cameras) being actually 23.976 also matters to how motion blur is perceived. 1/50 is close enough for my tastes, and sometimes I prefer 1/60th. I think your on firmer ground with saying that it's a matter of taste as to what to use for "normal" shutter angle.
1/48th and 180 degree is considered normal, but I seriously doubt that any professional cinematographer would simply rule out as unprofessional using a tiny bit higher (1/50 or 1/60) or lower shutter angle (1/40) for "normal." In fact, I wouldn't be surprised if a slightly higher shutter angle would be preferred as normal for certain shots if it helped with things like car rim rotation, etc.
Also note that some real film cameras (like some bolexes) actually have different shutter angles as their standard.
@lpowell interesting thoughts. Can you elaborate on or link to some good info about "double flashing" in theaters?
Exactly. It's just the tiniest increment, yes, but when you're talking narrative and watching people move around in a scene, it stands out over the span of a few frames. I cannot bare to watch digital cinema with the shutter cranked down to 1/30 just to get the light.
Go and watch HORRIBLE BOSSES, the entire bar scene is probably 1/35(ish), and it is SO freaking annoying.
Superbad, the scene when they're outside at the bus stop at night, and a few other scenes, totally 1/30.
Miami Vice looks like the most amateurish material on the planet, slurring and blurring all over the place, But, that's his style so cool.
1/40 isn't bad, I would use 1/30 if I needed the extra light at night but would prefer not to. Sometimes you have to do what you have to do to get the shot aka see people/subjects.
I'm not telling others they have to shoot 180 degrees, don't really care. Don't care if people shoot 30P to avoid flickering or whatever, do what you have to do. I don't like the look of 30P or off shutters unless it's specifically done for effect (high speed, action, dream sequence, so on and so forth.)
I always shoot at 1/60 sec to eliminate any trace of 60hz power line flicker. I've been staring at monitors with 60hz refresh rates daily for well over two decades, and before that I was continuously brainwashed with interlaced 60hz TV broadcasts. In fact, I'd have to question whether I've ever seen anything displayed at 24fps - even theatre projectors will double-flash a movie at 48fps. I suspect I was simply born too late to develop an appreciation for the 180-degree rule.
@kholi Is it the smaller amount of motion blur that 1/50 gives you that you don't like?
As a side note, I used to work with a Guy who could tell me what refresh rate my crt monitor was set to. Even being able to distinguish 120hz from 110hz.
Hey, if you can't tell the difference, cool. Just don't go around telling other people that they can't. It's silly. Some of us do this for a living, it isn't about being held over from "olden golden days". It's a specific look that we're after and we reproduce in real production environments, on stages, on sets, on locations.
If it weren't the case, and people didn't see a difference, then it wouldn't matter. Films are not being shot with "all sorts of shutter angles". You shoot 180 degrees as a standard for motion rendition and exposure, no different in a digital camera. You only shoot with lower or higher shutter angles for light or effect, it is not a standard.
Do it with home videos, nobody cares. Use whatever you want.
I shoot 1/40 with GH2 and 1/45 with 5D for this specific reason, 1/50 is ugly, has been since the dawn of 24p digital cinema, will be until it dies out.
You mean a little MORE motion blur? 1/40 isn't going to give you less, the lower you go the longer the shutter stays open, the more motion blur you get.
@danyyel, Those three videos are the best camera comparison I've saw: Arriflex, Weisscam, 5D Mark, 7D, 1D Mark, Nikon D7000, SONY F35, SONY EX-3, Phantom, RED ONE, Alexa and AF-100. The GH2 wasn't tested because is not a DSLR, but the AF-100 was tested. I don't know if the results of the AF-100 can be extrapolated to the GH-2; anyway the test is very interesting.
@kholi and @rigs, it would be nice if someday you bring your hack gh2 on one of the red shoot. At least just pointing at some scene so that we could get a idea of how the gh2/hack looks beside a red. It would be even better if we could get a true side by side test but I do understand that it will take time etc.
I wrote a thread about the need or lack of recognition for the gh2/hack. The problem is that, strangely this camera is the least tested one on the video side. I am sure that it will be beaten by a red, but it just needed to have some reference comparison.
I am no fanboy but I see all type of things written against it (some valuable criticism and many completely unfounded usually by fanboys hatters who can't like anything which does not have their brand sticker on it) it brings those endless discussion and we have no good example/test to use as benchmark for the gh2. I know that for some (in the know here) it is not important, but I think the gh2 in itself is a true landmark (the the dvx100, 5d mark 2) in the quest of cinematic motion capture for the mass and I would like it to be shared to a greater audience but unfortunately there are a lot of people that are in the dark because of other brand dominance and their fan boys.
The latest trailer of the movie Musgo by Vesubio is one of those benchmark that the gh2/hack really needs. It shows to the world that very good cinematic images can be done with this little camera. His micro budget film does not look out of place compared to what I have seen in the Canon recent Hollywood budget Canon C300 movie.
Right. I think it's a bias left over from the days of trying to re-conform 30fps footage to 24p. Personally, I use 1/40th frequently if it serves the look I'm after. (A little less motion blur, a little more exposure).
Of course being able to see the difference between 1/48th and 1/50th is pretty darn amazing! Wow, that guy must really know his stuff.
I think people have taken the 180-degree shutter "rule" from the cinema world and turned it into some kind of gospel. In the cinema world, that rule is really more of a guideline - a starting point. Films are being shot with all sorts of different shutter angles. There's nothing magical about 180 degrees. If you can explain to me why a 180-degree shutter is important for anything besides your own magic eyes, I'd be interested in hearing it.
@rigs The camera opens the shutter at the start of each frame and keeps it open for as long the shutter speed dictates. If you had a 1/48 setting, the shutter would remain open for 20.833 msec instead of 20 msec at 1/50. In either case, the cadence is 23.976 fps.
@balazer "I'll eat my hat if you can really tell the difference between 1/48 and 1/50." Sure most people can't - but most cameras can. 180 degrees is propper for cadense. sure would help allot of things out if we could dial it in on these.
Yes, these are the exact same things I feel as well. Epic is a different look. A glass window look! It's awesome, indeed. But I also am totally in love with the hacked GH-2 look, and I consider it a very serious alternative to Epic and RED-MX, especially with PL Glass attached.
That's saying a ton.
I think we're on the same page about adjusting curves to something that would help with the 8-bit. That, and a combination of 5DtoRGB DPX processing should be enough to turn the 8-Bit into an honest 16-bit image from which you would be able to work with in DaVinci.
Also, what about the burst mode limitation being lifted? That's probably been explored. I would take 10 seconds of 2.3K 24fps footage! Haha. I doubt it though. =]
1/48th would sure make a world of difference. I too have been filming with Epic latlely and is a great camera to use. Workflow is a bit tough. It sure is nice to have the small form factor and ease of a GH2 to play with every now and then. The hacks have sure gave it a whole new look. It would be nice to be able to dial in some new curves to help with some of the 8bit 420 limitations.
