@driftwood. No issues with both 24p H and L modes on Quantum V2 today.
One interesting late day find was no issues with Sandisk 45/mbs card and a quick test on a 32 gb/ class 10 Sandisk. Then found that my blue label Class 10 16gb Transcend card worked in 24p H mode, but my 3 yellow labeled Transcend class 10 16gb cards got fairly quick write errors. Also, 2 clips from 16-20 clips on the Transcend 16gb class 10 blue card, show the clip length to be much longer than actual clip and playback is jumpy, but does show proper length in editor although play back isn't smooth. Can be rendered out and is ok.....
I do not know if this is possible. With a 2x adapter, could a hack be developed that would make the GH2 record only a central section (I would put tape on my monitor) such that It records a ~2.4 or ~2.65 image? That is throw away the extra width before recording.
And if I can help with any testing, I have 1.33x 1.5x and 2x adapters
My feeling about 2x Anamorphic is that the lower resulting resolution in the stretched dimension gives that anamorphic film feel. Likewise, the explanation that de-squeezing the image off the sensor before the compression, is a better option than doing it in post after running through compression.
at 30fps. No 24. And it squeezes the vertical dimension, which technically lowers your vertical resolution. But yes, I see your point about it doing the conversion straight from the sensor. For Blu-Ray (other than the 30p), this is actually ideal, as B-Ray cannot go wider than 1920 anyhow.
@LPowell Just so I understand, does this imply that one can currently actually hack the GH2 to shoot 1920x810 so the image is pre-cropped in camera and viewable that way on the LCD for framing purposes too?
If so, that would mean that the people shooting 2.40:1 with tape marks on their LCD and intending to apply the correct aspect ratio/letterboxing in post (i.e. those not shooting with anamorphic lenses) could crop in-camera and monitor correctly too.
So, could we take driftwood's AVCHD Intra settings and modify to shoot and display 1920x800 for example? Is this actually possible?
@B3Guy MJPEG mode is currently the only way to shoot at a 30p frame rate with synced audio. I find it very useful for conforming down the footage 20% to 24p, producing a very subtle effect that doesn't look like obvious slow motion. Plus, it's inherently Intra, which is all to the good.
When shooting anamorphic, it is very helpful to see your exact framing in the viewfinder. With a 1920x810 image in the LCD, I can judge exactly how to frame each scene without guessing. In addition, when the camera does the scaling, it works on uncompressed data from the sensor, rather than the compressed 4:2:0 data stored in the file.
@driftwood Thanks for the inside scoop on B-frames in SH mode. In the case where we'd have GOP-3 in both 720p60 and 720p50, are there encoder settings 1-4 you'd recommend?
I still don't understand the advantages of shooting these specialty anamorphic settings. Someone enlighten me. Would it not be best to just shoot the best quality currently possible from the sensor (INTRA or other), and do stretching (horizontally) or compressing (vertically) in post? Is the only benefit of these specialty settings that it is pre-converted from squashed anamorphic state right off the camera? what gives? I don't get it. What's on the LVF shouldn't matter, there are monitors that can desqueeze for your live viewing benefit if that's what you're after. If you shoot full 1920x1080 and stretch horizontally with good software, you should get a very good, very large image, no? If 2x is too wide, lop a bit off either side of the bastard, or even use it to pan and scan a bit . . . but why these settings that compromise vertical resolution? Seems backwards to me. Am I missing something?
@lpowell Encoder settings need to be switched for B frames. Problem is 720p 50 is fine on Intra but the shared settings for 720p60 result in 9 seconds recording on Intra hence Gop3 - im afraid we cant have it both ways. Oh how Ive tried! If you prefer b frames youll affect 50p on Intra. But theres no harm changing them both to gop3 and b frames.
Thanks for your advice on anamorphic stuff. Im away shooting this wknd up north so not at 'pute to continue tests.
@CraftyClown My experience has been that patching the camera to pack more than 1920 pixels into each horizontal line puts excessive stress on the MJPEG encoder. This forces you to reduce the MJPEG bitrate to preserve stability, and that lowers the image quality.
With the GH2 in VGA mode, a 2x anamorphic will produce an image that has a native 2.67:1 aspect ratio. Since this is wider than the desired widescreen frame, you have to crop the sides accordingly. In HD mode it's even more mismatched - a 2x anamorphic produces a native aspect ratio of 3.56:1.
In VGA mode, 2160x810 would be the ideal frame size for a 2x anamorphic, allowing you to produce a 1920x810 cropped frame without any frame-stretching in post. My 100Mbps MJPEG patch does work reliably at this resolution:
@LPowell So just to clarify, you think 1920 x 720 in HD mode would give the best image quality for 2x anamorphics. Would this still give us a super wide aspect ratio? I presume the only way to get a more film like aspect is to switch to vga and accept the quality loss?
@Sage Great image! What lens did you shoot that with, btw? Looks really sharp on his face with a nice amount of bokeh. Is it the Voigtlander 25mm @ approx f1.4?
@CraftyClown The 4:3 VGA mode has less horizontal sensor resolution than the 16:9 HD mode, and the images are not quite as sharp. However, with a 2x anamorphic, the 2880x1080 VGA frame size allows you to use 90% of the width of the lens, with a cropped 2560x1080 widescreen frame. In HD mode, you would need to use a 3840x1080 frame size, with only 67% of the lens width retained in the cropped widescreen frame.
For best image quality using anamorphic lenses, I recommend setting MJPEG width to 1920 pixels, and scaling the MJPEG height to match the anamorphic's squeeze factor:
1.33x lens HD mode: 1920x810 1.5x lens HD mode: 1920x720 2x lens VGA mode: 1920x720
These frame sizes produce geometrically correct square pixels that do not require frame-stretching in post-production.
@LPowell as 2 x anamorphic users, do we lose anything from the GH2 being in VGA mode? Does it limit any other settings? Also as it's using a 4:3 frame, are we best off going for 2880 x 1080 if we want to keep a decent resolution??
@FGCU Went back to look at the saturated frames Quantum does have less grey blocks in the shadows great work I'm going in with this patch thanks @driftwood@VK lol...
@driftwood - I need to know if you want the anamorphic container 1998x1080 (ratio 1.85) or 2048x856 (ratio 2.39)."
In order to produce precise square pixel geometry, it's more accurate to use digital aspect ratios on MJPEG frames rather than the vintage analog 1.85 or 2.39 ratios. With the GH2's 16:9 image sensor in HD mode, the geometrically correct frame sizes are as follows:
@driftwood Is there a change to 24H Quantum v2 beta over the previous? I hope not, since like yourself, I'm after the best quality!
It certainly appear FGCU shows the benefit of AQ4 setting.
Also, do you believe your changes with Quantum to help 24L span may have affected the quality for 24H?
I know there's many that want 24L to span on slower SDHC cards, but I would not trade that for a hit on 24H quality. Also, I 'm hearing the new 64GB SDXC is spanning with the 24H settings for SeaQuake, I also imagine it will also span with Quantum 24H.
