BOSMA G1 8K camera - Another Chinese camera
    The BOSMA G1 8K features a Micro Four Thirds (MFT)-sized image sensor and is capable of recording in 8K/30p and 4K/60p resolutions.
    https://ymcinema.com/2021/04/24/bosma-g1-8k-camera-released-mft-sensor-that-shoots-8k-30p/
    “8K high-resolution video streaming can be implemented in a wide range of fields such as live video distribution and aerial videography”, the company said. The Micro Four Thirds form factor enables a the BOSMA G1 8K to have a compact form factor.
    • 7680 x 4320 pixel resolution (approximately 33 million) (4/3 CMOS image sensor, 18.84 mm x 10.60 mm);
    • 8K/30p real-time streaming over HDMI 2.1 output;
    • RTSP and SRT video transmission protocol support;
    • CFast 2.0;
    • long recording time capability via connection to an external SSD and remote control functionality.
    The camera encodes video in H.265 HEVC Main 10 Profile and High Profile H.264/AVC. Sound/voice codecs are handled as AAC/PCM, and video file containers include MOV/MP4. Recording bit rates are 200M for 8K/30p and 100M for 4K/60p. Color tone is 10 and 8 bits, while sound is either 24 or 16 bits with sample rates of 48 kHz and 44.1 kHz.
    • Bit rate control methods are VBR and CBR, and available frame rates for 8K include 30/25/24 fps and for 4K 60/50/30/25/24 fps.
    • Using color gamuts of SDR BT.709 and HDR BT.2020, and will dynamic range as SDR8, SD10, and HDR10.
    • The included single HDMI output handles a maximum of 8K/30p.
    • The camera will record normal and time-lapse speeds.
    • The camera is supplied with single 3.5mm audio input and outputs; a 5-pin LECO (XLR 2ch) terminal, and include built-in stereo mic.
    • Has both an ethernet port and IEEE 802.11b/g/n/a/ac (2.4GHz and 5GHz).
    • Uses CFast2.0 card slot (exFAT compatible) for storage.
  • 11 Replies sorted by
  • 12 but and 12 stops DR doesn’t sound bad at all for a global shutter sensor.
    I’m planning on buying the chronos 2.1 for appetite appeal shots for food products and effects. Any comments on that camera?
  • Specs for the model 4830--12 bit global shutter fanless.
    Screenshot_2021-05-15 AB-4830 AC-4829 Multi-Purpose Camera System ASTRODESIGN Inc.png
    904 x 573 - 30K
  • 12 bit fanless global shutter, I like the sound of that. https://www.astrodesign.co.jp/english/product/ab-4830_ac-4829
  • All suddenly kinefinity sounds good.
  • It would be better if it did 8k 60p, but what do you want for $5000?
  • Saw somewhere that this camera probably uses the same sensor as the (dead?) 8k camera from Sharp.
    Anyone knows who is making this sensor?
  • @DrDave
    It is nice to have alternative, as no one knows the amount of chips Z-CAM still have. As the supply will end (I expected it to start really happening in February already, but they got new batch) it will be the end of Z_CAM as we know it, they will need totally new cameras and designs.
    As I told - they already are selecting the models they like to sell to dealers, at least outside major markets.
  • I mean, if you want an 8K cube get the Z Cam F8.
  • Woooooho, another ultra-hackable shit!
  • something smells strange here,
    only records up to 30 minutes, what is this?????!! passed like a photo camera then used as a videocamera for paying less taxes????
    What is this !!!! bitrate limited to 200mb 8k30p and 100mbps at 4k 60p.
    10 bit no external RAW and you tell me $5000 is cheap!! damm sure the know something i dont.
