Radeon RX 6000 GPUs lineup based on RDNA 2 architecture
    • RX 6970 XT - 6800 stream processors, 425 texture units, 160 ROP raster units, frequency 1600MHz, GDDR6 memory (1750MHz);
    • RX 6900 XT - 5120 stream processors, 320 texture units, 128 ROP raster units, frequency 1500MHz;
    • RX 6800 XT - 4352 stream processors, 272 texture units, 96 raster units, and a frequency of 1500MHz;
    • RX 6700 XT - 3584 stream processors, 224 texture units, 96 raster units, and a frequency of 1400MHz.
  • 24 Replies sorted by
  • AMD Navi 24
    744 x 638 - 70K
    800 x 288 - 52K
    800 x 507 - 85K
    800 x 463 - 73K
    694 x 912 - 74K
    695 x 645 - 64K
    690 x 772 - 67K
    693 x 702 - 66K
    693 x 860 - 69K
  • Not bad
    800 x 463 - 46K
    800 x 466 - 45K
    800 x 442 - 44K
  • Board
    800 x 362 - 70K
    800 x 545 - 107K
    800 x 183 - 44K
    War that is already lost even before start.
    800 x 836 - 174K
  • On power consumption - it is big
    800 x 389 - 42K
    800 x 377 - 43K
    800 x 372 - 42K
  • Navi21 XL
    • Base clock 1350MHz to 1400MHz
    • Game clock 1800MHz to 1900MHz
    • Boost clock 2100MHz (maybe 2200MHz)
    Navi21 XT
    • Base clock 1450MHz to 1500MHz
    • Game clock 2000MHz to 2100MHz
    • Boost clock 2200MHz to 2400MHz
    • Radeon RX 6900XT Navi 21
      • Shader cores - 5120 (80 CU blocks)
      • 16Gb GDDR6 RAM
      • only 256 bit memory bus
      • 1500Mhz GPU frequency
      • around 250-300 watts consumption
    • Navi 22 r
      • Shader cores - 2560
      • around 170 watts consumption
    • Navi 23
      • Shader cores - 2048
    584 x 194 - 31K
    • Top Navi21 based card will have 16GB VRAM
    • Cheaper Navi22 based card will have 12GB VRAM
    800 x 441 - 61K
    800 x 443 - 55K
    800 x 443 - 47K
    800 x 437 - 52K
  • Quite bad cooling design (and this will be only one available for long time)
    800 x 627 - 49K
    746 x 261 - 42K
  • First relative benchmarks
    • MSI Gaming X Trio 2080 Ti 74,4 FPS (156,63%);
    • EVGA XC Black 2080 Ti stock 64,9 FPS (136,63%);
    • AMD Radeon RX6000 Graphics 63,9 FPS (134,52%);
    • MSI Gaming X Trio 2080 stock 54,4 FPS (114,52%);
    • NVIDIA GeForce RTX 2070 stock 47,5 FPS (100%).
  • Some more info leaks
    • AMD will target profits for new GPUs, same as they did with Ryzen chips
    • Simpler architecture to make chips small that they used for game consoles
    • Using of cheap and slow GDDR6 instead of GDDR6X used by Nvidia
    • 256 bit memory bus allows allows to save around $2 compared to wider bus
    • GPU will have 128Mb cache
    • AMD will present another variant of fake AI scaling
    Both companies are expected to advise reviewers to push test numbers in 4K mostly in DLSS and similar AMD scaling modes to show new cards advantages.
    AMD does not plan to much new cards much due to new secret cartel agreement with Nvidia, instead they will focus on Ryzen/Threadripper chips with their staggering profits (highest profits any consumer CPU ever had in the industry by far).
  • AMD RDNA2 architecture and Radeon RX 6000 Series graphics cards will bring the best of Radeon to gamers worldwide. Learn more October 28.
  • Some partners got info from AMD that top of the line cards will indeed slide in price from $599 to $549, and new info tell that discussion is now even about $499 now. As performance can only match RTX 3070 version with 16GB memory. Same as info above says.
    AMD is not much interested in producing lot of GPUs, as margin Ryzen chiplets is around 3-4x compared to profit on top line GPU. Actually Ryzen 7nm CPUs chiplets profit set absolute records in the industry for wide used products.
    For GPU AMD still can drop around 120-150$ from remaining margin on main GPU and around $40 from their part of GDDR6 margin (so it is around 30-40$ for PCB board, $20-30 cooling, AMD margin is around $200 total in card price).
    581 x 481 - 49K
  • Raytracing demo
  • Sounds interesting.
    Do you have any info about the performance?
