Base system
Top system
Cooling had been improved, but for top configs it is absolutely not enough with it's single heatpipes for CPU and GPU.
Even much cheaper Xiaomi Notebook Pro this year offers double the cooling with lighter heat output.
Horrible heat design again, Apple!
GPUs specs are really weak
AMD Radeon Pro 5000M series mobile GPUs are built upon the all-new AMD RDNA architecture, designed from the ground up. The new GPUs include up to 8 GB of high-speed GDDR6 memory with up to 192 GB/s memory bandwidth - double the bandwidth of GDDR5 - and also deliver up to 4.0 TFLOPS of single-precision floating-point (FP32) performance. The GPUs are optimized for content creation applications and compute-intensive image rendering workloads.
Return of scissors keyboard (still much inferior to famous Thinkpad keyboard)
Apple still mainly aims to shortest travel possible to advertise thickness of laptop (that has zero value if it is lower than certain quite high value) and do not properly make leak proof construction.
Looks like a great update from Apple! I might get one to replace my iMac!
Get instead any good universal small PC with AMD card and install hackintosh on it.
As this thing will be throttling and will have around 30-40% performance of any normal 8 core PC that is real cheap now.
Speakers grill is designed and located to maximize chances of water damage.
Adorama providing $100 rebate for this model preorders
Totally unrepairable construction
As told on day one - this thing throttles
Small fun is how she downplays this, as no, not all notebooks throttle.
But to not throttle you need two additional heatpipes and better coolers.
Special - Apple 16" MacBook Pro, i9 2.3GHz, 16GB RAM, 1TB SSD, Radeon 5500M 4GB, Silver, $154 discount
https://www.adorama.com/acmvvm2lla.html?EmailPrice=T
Simpler config - https://www.adorama.com/acmvvl2lla.html?EmailPrice=T
I ordered one with 1TB SSD, 8GB GPU, 32GB RAM and 2.3Ghz i9 to use with Asus PA32UCX monitor. Both should arrive by the first week in January.
MacBook 16" with $350 discount
Code 19CYBERPROG
https://www.google.com/shopping/product/18381129246155810521?psb=1&tbm=shop
Still some sales of it at B&H
https://www.bhphotovideo.com/c/buy/macbook-pro-16-2019/ci/45584
can you recommend a PC laptop that can be hackintoshed easily?
Or if you need top power Xiaomi Gaming machines.
Make sure to visit hackintosh resources to check.
At discount in B&H
https://www.bhphotovideo.com/c/product/1520435-REG/apple_mvvk2ll_a_16_macbook_pro_late.html
The latest macOS Catalina 10.15.3 beta build contains references to a new “Pro Mode,” which can be turned on and off by users. Some strings mention that “Apps may run faster, but battery life may decrease and fan noise may increase” and “Fan speed limit overridden” when the Pro Mode is activated.
Idea is to just lift fan limits, so your note will start to sound like rocket during launch.
So you’ve got a brand new space grey16″ MacBook Pro with the incredible Magic Keyboard – a huge improvement over the butterfly keyboard of Apple’s previous laptops – and you’ve also patted yourself on the back for applying a screen protector to keep those magical keys from scuffing the Retina display. What’s the very first setting you should change on your laptop? Unsurprisingly, next to no YouTubers are mentioning this, but for those for whom choppy 24p video is the bane of existence, the new MacBook Pro has the answer: customizable refresh rates. You see, unlike 30p, 24p video does not divide evenly into a 60 Hz refresh rate – it leaves twelve frames remaining, introducing judder. So the very first setting you’ll want to change when picking up your MacBook Pro is the refresh rate. Choose the Apple menu > System Preferences, then click Displays. Press and hold the Option key and select the Scaled button. The refresh rate appears. Click the Refresh Rate pop-up menu and choose the refresh rate (48 Hz for 24p, 47.95 Hz for 23.976p).
i9, 16" 3072x1920, 16GB DDR4, 1TB SSD, $2349
Code - LFPKMV
