Olympus hacks
  • 153 Replies sorted by
  • @invaders As far as I got, 00.main-code-01.bin is just loaded at pre-specified memory address distinct for different camera models.
    The main problem in loading the firmware into IDA is to determine the correct loading offset. And it can easily be solved by looking for ": This command list" string without quotation marks. The next DWORD is an address of "init\0init " in the block before the first string.
  • Sounds like you have done some fantastic work. Has the firmware been updated for the M10iii?
  • Super late to this form- but how are you able to get the firmware files, since updating firmware requires pluggin camera into computer? I can't figure out how to find a direct link to the files (E-M1 mkii in my case)
