Samsung NX300, NX500, NX1 Cameras Hack
  • 82 Replies sorted by
  • NX300 dev menu
    1. Create a text file named nx_dev.adj with smart_camera content, length should be exactly 12 bytes.
    2. File must be in the root of SD card.
    3. Put SD card in camera.
    4. Set wheel to Auto.
    5. Power on the camera.
    6. Press in succession: down, OK, up, OK, right, press and keep pressed the exposure compensation button, press and release OK, and now release the exposure compensation.
    7. You should see the new menu on the screen.
  • Older NX200 and NX100 dev menu
    Turn power on. Select "Smart auto mode"
    Press buttons in sequence:
    1. UP
    2. OK
    3. DOWN
    4. OK
    5. RIGHT
    6. EV + OK (press OK while pressing EV button)
    The additional developer menu settings will be available.
  • Anyone got a link for the nx300 firmware?
  • @Dobbie
    What kind of firmware?
  • 1.45 Hacked for recording time limit and file 4gb limit. Does dev mode limit removal do this anyway?
  • Hello everyone! Most likely, many people will not respond, but I still want to write with hope. I have NX300. I want to break the video resolution of this. is it possible? 4k 30-25-24 Fps or 2k 30-60 Fps, this seems impossible to me, but maybe it will happen????
  • @cilsinan273
    No.
    Just buy used NX1 (or NX500 if you want small), this is my personal suggestion.
    With good lens it is now overall best camera option.
