NX300 dev menu
Older NX200 and NX100 dev menu
Turn power on. Select "Smart auto mode"
Press buttons in sequence:
The additional developer menu settings will be available.
Anyone got a link for the nx300 firmware?
What kind of firmware?
1.45 Hacked for recording time limit and file 4gb limit. Does dev mode limit removal do this anyway?
Hello everyone! Most likely, many people will not respond, but I still want to write with hope. I have NX300. I want to break the video resolution of this. is it possible? 4k 30-25-24 Fps or 2k 30-60 Fps, this seems impossible to me, but maybe it will happen????
No.
Just buy used NX1 (or NX500 if you want small), this is my personal suggestion.
With good lens it is now overall best camera option.
Hi, I just got the NX200 and the developer menu instructions doesn't work. Is there any other way to get there? Thanks
Can we never find such a setting in open source codes? Maybe there may be lines of code, files, commands or similar things that write video recording formats in the documents in the nx 300 open source code .tar file. you never know. Or you may have encountered it...
