I'll post links to coupons and interesting items here, make sure to follow topic.
Cheap fluid heads
Such are made for photo like tripods and monopods. Of course during really cold days outside their behavior changes, so for winter you need to check them first and may be change grease.
YI Lite Action Camera 16MP Real 4K for $67,3 and lower
Get seller $10 coupon.
If you apply any of coupons listed in topic above price will be even lower!
Famous iFootage design stabilizers
For some work such thing is more useful than gimbal. And always handy to have.
Another little trick remainder
For any order you will get following set of coupons:
But, first you need to made extra delivery address in Russia.
Use additional $0.01 value order like such
YI Discovery Action Camera 4K
$6/$30 or $6/42 discount coupons work on it, see topic above.
On humorous note - get your girlfriend Xiaomi gadget
All coupons mentioned above in topic work here also :-)
Leveling bases
Very important item if you like to shoot on small photo like tripods, saves tons of time.
Such sales time is best to get them as without coupons price usually remains almost same all the time.
Very good sunhood for GH cameras
Add something to $10 and use $3/10 or $5/10 coupon you can find above in topic.
SmallRig Cages - best quality among affordable Chinese made cages
New very good coupon - $5/10
Code - ALI
Note that if you are not in Russia you need to use trick for it to work.
Make some Russian delivery address.
Use code.
Make order (without paying!).
Next got to Orders and select cancellation with reason - want to change delivery address.
After this add even another. different goods and use coupon and make normal order.
Carbon fiber monopod with legs and ball head
Two high CRI panels set with stands
Deal for US and Russia.
GPD Pocket 2 Mini PC
Smallest among competition and still useful.
Famous Scythe Gentle Typhoon fan
Uses Nidec motor.
It won many tests beating famous Noctua fans. No longer made du to high costs, so it is remaining stock.
You will pass it in working state to your children.
Use any coupons that work over $25 sum.
Padded tripod/stands bag
Good Godox light panel light
Use $3 seller coupons and any suitable coupons mentioned in topic also.
SJCAM Action Cameras
Goldenfir 2.5", SATA3, 360GB, $31.44
Nice thing to put in your old note or as additional drive.
Use $6/30 coupon I mentioned above in topic.
Panasonic GH5/GH5s camera cage
Use coupons from above to make it even cheaper (all coupons from $25 and below work).
Very fast portable 256GB-1TB flash drive
Use coupons above and it'll be price ever for good portable SSD.
120cm motorized slider with smartphone control for $264 and lower
Note - price in title includes only seller coupon and $24 of select coupons applied (see early posts in topic!).
If you'll also use other coupon it'll be even better
Aputure AL-MX LED Video Color Temperature 2800-6500k, $137 and lower with coupons
Get seller coupons and use one of the bigger coupons listed above in topic to get nicer price.
