FX-AUDIO DAC-X6 MINI HiFi 2.0 Digital Audio Decoder DAC
Get sellers $2/50 coupon.
And use suitable coupons from this topic.
It is best price even compared to 11.11
Nice USB lavaliere mike with headphone output
Especially good for latest Mac notes users. Heard really good feedback about it.
Aputure M9 alternative (CRI also high!)
Kingston A400 SSD
Netac N500S SSD
Professional 24 Color Card Test Color Chart
Price without coupons is not best ever, but thanks to coupons you can get it at best price.
Godox 60W LED Light for $109 and lower
Personal recommendation, you can check our big topic on it - https://www.personal-view.com/talks/discussion/17664/cheap-powerful-godox-sl60w-led-fresnel-below-199#Item_70
Make sure to add any other small item to $130 total (any other seller, with support of $6 from $65), and price will be as in title. Make sure to use select coupons (see above in topic).
If you use any other coupons price will be even lower as they'll sum.
Aputure AL-MX LED Video Color Temperature 2800-6500k, $137 and lower with coupons
Get seller coupons and use one of the bigger coupons listed above in topic to get nicer price.
120cm motorized slider with smartphone control for $264 and lower
Note - price in title includes only seller coupon and $24 of select coupons applied (see early posts in topic!).
If you'll also use other coupon it'll be even better
Very fast portable 256GB-1TB flash drive
Use coupons above and it'll be price ever for good portable SSD.
Panasonic GH5/GH5s camera cage
Use coupons from above to make it even cheaper (all coupons from $25 and below work).
Goldenfir 2.5", SATA3, 360GB, $31.44
Nice thing to put in your old note or as additional drive.
Use $6/30 coupon I mentioned above in topic.
SJCAM Action Cameras
Good Godox light panel light
Use $3 seller coupons and any suitable coupons mentioned in topic also.
Padded tripod/stands bag
Famous Scythe Gentle Typhoon fan
Uses Nidec motor.
It won many tests beating famous Noctua fans. No longer made du to high costs, so it is remaining stock.
You will pass it in working state to your children.
Use any coupons that work over $25 sum.
GPD Pocket 2 Mini PC
Smallest among competition and still useful.
Two high CRI panels set with stands
Deal for US and Russia.
Carbon fiber monopod with legs and ball head
New very good coupon - $5/10
Code - ALI
Note that if you are not in Russia you need to use trick for it to work.
Make some Russian delivery address.
Use code.
Make order (without paying!).
Next got to Orders and select cancellation with reason - want to change delivery address.
After this add even another. different goods and use coupon and make normal order.
SmallRig Cages - best quality among affordable Chinese made cages
Very good sunhood for GH cameras
Add something to $10 and use $3/10 or $5/10 coupon you can find above in topic.
Leveling bases
Very important item if you like to shoot on small photo like tripods, saves tons of time.
Such sales time is best to get them as without coupons price usually remains almost same all the time.
On humorous note - get your girlfriend Xiaomi gadget
All coupons mentioned above in topic work here also :-)
YI Discovery Action Camera 4K
$6/$30 or $6/42 discount coupons work on it, see topic above.
Another little trick remainder
For any order you will get following set of coupons:
But, first you need to made extra delivery address in Russia.
Use additional $0.01 value order like such
