Why is there no in-body image stabilization (IBIS) in the EOS R?
Shoji Kaihara: We had to look at the balance of the entire camera, like the size and other aspects. Based on that, it’s not something we are able to include in the EOS R at this time. We are quite aware that there are pros and cons to that.
That’s why we have image stabilization built into the lenses. We believe the lens will do the job of stabilizing at the moment. As we look into the future, we think about how we can build IBIS into the body as well.
But it’s not something we were able to achieve at the time of the EOS R’s launch. We know that there are pros that IBIS can provide, so we are looking into that. But not now.
Why does the EOS R shoot 4k video with a 1.7x crop?
Shoji Kaihara: When developing the EOS R, we looked at all the hardware we had in the pipeline. When we look at the image processor and CMOS sensors that we have — we have restrictions, unfortunately, and that’s why we ended up with the 1.7x crop.
We could have tried to pursue full-frame (4K video capture), but it would bring more instability into the video shooting. For example, heat issues might have arisen. We didn’t want to risk that. That’s the reason we decided, in terms of the best balance we can achieve at this time, to come out with 4K at 1.7.
Absolutely made my day!!!
Interview with IR
NOTE!!! IR this year became like some kind of PR agency, lite version, for both Nikon and Canon. Like story of "Nikon made" sensors was all other the top. take all their materials with big grain of salt.
As is the case with the new Nikon Z7 and Z6 full-frame mirrorless cameras, the autofocus points in the EOS R are all horizontally-oriented line-type points, meaning they're sensitive only to subject detail in that direction.
Logic tells me that camera do not have such points AT ALL, and just use Dual Pixels.
Most mirrorless cameras use a combination of PDAF and CDAF; phase-detect gets the lens close to the correct focus, then contrast-detect fine-tunes it. This appears not to be the case with the EOS R, though. When I asked whether it had a hybrid AF system, the engineers replied that no, it was always only phase-detect.
Well, David has issue understanding how DPAF works, hence such questions. And even worse, inaccurate answer.
Conventional separate-sensor PDAF systems have reached an incredible level of sophistication and ability, so matching their performance is the defining challenge of the mirrorless revolution.
Conventional DSLR sensors have HUGE issues with lot of subjects. And even more issues with alignment.
They said that relative AF performance depended on the subject; that the EOS R would win sometimes and the 5D IV or 1D X II other times. They didn't elaborate on what subjects they thought each would be best at, but I thought it was significant that it wasn't all one way, and that the EOS R in fact would win some AF matchups, even against some of Canon's top SLRs.
Of course it can win. You can provide lot of scenarios where simplest slow contrast AF will win hand down also.
Being able to position a large rear lens element very close to the sensor brings a lot of advantages for optical design, and Nikon make a big point of this in talking about their new Z-mount, which has a flange depth of only 16mm.
Actually it is mostly reverse. For portability they select small flange distance. But it introduces optical design issues, especially for wide lenses. So you are FORCED to make it larger to reduce angle of light hits the outer areas of the sensor, especially FF one. It is CHEAPER and simpler to make lens for old mounts.
As was the case with Nikon's new Z-mount, the reason for the new contacts is to increase the communication bandwidth between the lens and camera body. The old-style 8-contact arrangement comes from decades ago, when the camera and lens needed only infrequent, low-information communication. ("Shift focus to this distance" ... "Are you there yet?" ... "Yes, I am.")
Each time I reach such - I want to vomit. David, go and read something like SATA or PCI-E specs.
Old style arrangement had been needed for 4bit (and later 8bit) extremely stupid and slow simplest processors inside DSLRs.
I believe here main goal is to make closed and encrypted protocols more complex and allow them to deal and check each individual chip inside lenses. And have nothing to do with any speed.
https://www.imaging-resource.com/news/2018/09/15/canon-eos-r-qa-with-the-canon-engineers
Poor people can preorder EOS R now
Canon has created a....GH4. Crop in 4K. Internal recording disabled when outputting 10bit.
How very 2014 of Canon!
From interview
New firmware coming soon
That can be right... Never thought that way I dont travel with camera :)
@konjow "Better" is subjective. A 24-70 f/4 is an excellent small travel lens.
Shutter sounds
@eatstoomuchjam yes f4 is good for 24 105 but not for 24 70 here 2,8 is better
The sponsored bloggers grapevine is promptly hammering out the BIG news.
