Lilliput A5 aka Neway CT500HO Little 5" Monitor
    • FullHD 400 cdm² IPS panel
    • 1000:1 contrast
    • HDMI Video Input with 4K support
    • HDMI Video Output with 4K support
    • Input Voltage - 7-24V
    • Power Consumption ≤ 12W
    • 80 mm x 129.8 mm x 23.6mm
    • 118g
    • Very affordable at $145 - https://www.amazon.com/dp/B07D9WL9ZF/
  • 32 Replies sorted by
  • Our detailed video review
  • Lillupt A5 Inside
    4 main parts
    Very nice main board compatible in complexity with camera main boards
    TSUMV56RBUT-Z1
    This is highly integrated LSI by Mstar for controlling LCD and dealing with lot of inputs and audio output.
    Notice this big guy - it is Xilinx Spartan-6 XC6SLX16 FPGA very similar to one used in all BlackMagic cameras
    • Number of LABs/CLBs - 1139
    • Number of Logic Elements/Cells - 14579
    • Total RAM Bits - 589824
    • Number of I/O - 106
    Nice board quality
    Found only one place with flux residue due to human soldering
    Case is pretty tough with good brass thread mounts
    Note - you need to close monitor during rain - as it lacks weather sealing and button holes are on top
    LCD panel used
    800 x 369 - 47K
    800 x 483 - 105K
    800 x 686 - 126K
    800 x 658 - 141K
    800 x 609 - 94K
    800 x 824 - 116K
    800 x 450 - 55K
    800 x 609 - 85K
    692 x 426 - 33K
    799 x 696 - 106K
  • @pureaxis
    A5 has aspect menu item, but I am not sure if it has all anamorphic values.
    Andycine A6 has special Anamorphic menu with - Off, 1.3x, 1.6x and 2.0x.
  • Does it have a anamorphic desqueeze mode?
  • Color gamut, grayscale
    Gamut is wider than Rec 709
    Also it is nice idea to adjust blue down, red a little down and green a bit up.
    Color temperature
    Primaries spectrums
    White spectrum
    800 x 586 - 65K
    800 x 583 - 58K
    800 x 263 - 34K
    800 x 261 - 49K
    800 x 260 - 30K
    800 x 261 - 39K
    800 x 473 - 76K
  • Lilliput A5 Contrast and White Brightness at various backlight settings
    800 x 461 - 81K
  • Lilliput A5 monitor electrical measurements
    • Panel cutoff battery voltage - 6,24v (quite high!)
    • Panel cutoff DC Input voltage - 4,83v
    Standby consumption - 0,050 watts
    800 x 481 - 62K
  • Not so bad for sub US$150!
  • Delay at 1080p60
    Quite typical for such monitors
    800 x 486 - 45K
  • Monitor panel macro
    It is IPS panel.
    800 x 620 - 97K
  • Just finished my a weekend of shooting with the Liliput A5 for the first time, and I really liked it! Was a nice screen (in fact the B cam would often be using it for himself! Rather than for its purpose: to be pointed at me, so I could keep an eye on the B Cam shots), seemed to be battery efficient (I think? I wasn't doing battery management though, that was B Cam AC's job) while being super small and lightweight.
    For its price (only US$149!) I think this was an awesome bargain buy.
  • @jleo
    Thanks, fixed link.
  • Amazon Link in 1st post doesn't work. This new link.
    short link: http://a.co/gKEyyIi
    Linkdelight
    $149 Free Shipping
    sometimes they have coupons off new purchases, or current coupon : 6% off orders $300 or more : LD006, 7% off -$500 or more: LD007
    https://www.linkdelight.com/P0048011-Lilliput-A5-5-Camera-Top-Broadcast-Monitor-4K-HDMI-1920x1080-for-DSLR.html
  • $140 US Free Shipping
    Damn it, happens literally days after I purchased mine! Ah well
  • I received my refund, but held off on getting a replacement just yet. Any updates from the PV US Lab?
  • @Vitaliy_Kiselev did Alan test yet with NP style batteries? Just packaged mine up to send back. Hoping replacement works properly, as I really love the size and weight of this thing, not to mention the color and DR is pretty good. That's also a different ballhead than I received, though guessing that may not be the included one.
    Another note, you need to turn volume to 0 on monitor if you don't have headphones plugged in, otherwise sound from camera/mics comes through the speaker and feeds back.
  • In our US lab
    800 x 964 - 99K
  • I have been in contact with the seller and they are exchanging it for me. Will report back when I have the new one. @IronFilm, even if I hold the battery snug, it has issues. Touching the monitor with literally a feather touch causes the issues. Sometimes it just flickers, but most of the time, it just reboots. The connectors are very snug in the batteries. The fit is definitely better than some other devices I have that use NP batteries.
  • Having internal wiring that is loose is surprising! Usually it is the external connections, even if you hold it in firmly with your hands (or a rubberband) does the monitor still reset when you jiggle it?
  • You can see the prongs make very good connection with the contacts on the battery. Issue seems to be internal that wires going to connectors are loose or shorting.
    4032 x 3024 - 1M
    4032 x 3024 - 972K
    4032 x 3024 - 935K
  • @sam_rides_a_mtb
    Btw, make macro photos of connector.
    With some connectors you can make them better just using very thin screwdriver or such.
  • Great, thank you VK! Good to know that they will receive this feedback. Initiated the return on my unit and hoping to get a new one with the battery connection working properly. Will post updates when that happens.
