Lilliput A5 aka Neway CT500HO Little 5" Monitor
  • 32 Replies sorted by
  • Lilliput A5 monitor electrical measurements
    • Panel cutoff battery voltage - 6,24v (quite high!)
    • Panel cutoff DC Input voltage - 4,83v
    Standby consumption - 0,050 watts
    800 x 481 - 62K
  • Lilliput A5 Contrast and White Brightness at various backlight settings
    800 x 461 - 81K
  • Color gamut, grayscale
    Gamut is wider than Rec 709
    Also it is nice idea to adjust blue down, red a little down and green a bit up.
    Color temperature
    Primaries spectrums
    White spectrum
    800 x 586 - 65K
    800 x 583 - 58K
    800 x 263 - 34K
    800 x 261 - 49K
    800 x 260 - 30K
    800 x 261 - 39K
    800 x 473 - 76K
  • Does it have a anamorphic desqueeze mode?
  • @pureaxis
    A5 has aspect menu item, but I am not sure if it has all anamorphic values.
    Andycine A6 has special Anamorphic menu with - Off, 1.3x, 1.6x and 2.0x.
  • Lillupt A5 Inside
    4 main parts
    Very nice main board compatible in complexity with camera main boards
    TSUMV56RBUT-Z1
    This is highly integrated LSI by Mstar for controlling LCD and dealing with lot of inputs and audio output.
    Notice this big guy - it is Xilinx Spartan-6 XC6SLX16 FPGA very similar to one used in all BlackMagic cameras
    • Number of LABs/CLBs - 1139
    • Number of Logic Elements/Cells - 14579
    • Total RAM Bits - 589824
    • Number of I/O - 106
    Nice board quality
    Found only one place with flux residue due to human soldering
    Case is pretty tough with good brass thread mounts
    Note - you need to close monitor during rain - as it lacks weather sealing and button holes are on top
    LCD panel used
    800 x 369 - 47K
    800 x 483 - 105K
    800 x 686 - 126K
    800 x 658 - 141K
    800 x 609 - 94K
    800 x 824 - 116K
    800 x 450 - 55K
    800 x 609 - 85K
    692 x 426 - 33K
    799 x 696 - 106K
  • Our detailed video review
