BlackMagic Pocket Cinema Camera 4K
  • 497 Replies sorted by
  • PR
    NAB 2018, Las Vegas, USA – April 9, 2018 – Blackmagic Design today announced the all new Blackmagic Pocket Cinema Camera 4K, a handheld digital film camera with full 4/3 HDR sensor, dual native ISO with up to 25600 ISO for incredible low light performance as well as 13 stops of dynamic range. It also eliminates expensive external recorders, as it features a unique new USB-C Expansion Port, which allows customers to record using the internal SD/UHS-II and CFast recorders or directly to the same external disks they will use for editing and color correction. The Blackmagic Pocket Cinema Camera 4K will be available from Blackmagic Design resellers worldwide later this year for only US$1,295.
    The Blackmagic Pocket Cinema Camera 4K will be demonstrated on the Blackmagic Design NAB 2018 booth at #SL216.
    The revolutionary new Blackmagic Pocket Cinema Camera 4K is the handheld digital film camera that customers have been asking for. It packs incredibly high end imaging and professional features into a portable and affordable design that can be used anywhere. The compact body style is perfect for shooting independent films and documentaries, fashion shows, travel blogs, web videos, weddings, corporate video, sports and much more.
    The Blackmagic Pocket Cinema Camera 4K features a full size 4/3 HDR sensor with native 4096 x 2160 resolution and 13 stops of dynamic range for true digital film quality. The full size of the 4/3 sensor is designed to perfectly match MFT lenses so the crop factor is greatly reduced, giving customers a wider field of view. It also features dual native ISO with up to 25600 ISO for incredible low light performance.
    The Blackmagic Pocket Cinema Camera 4K is packed with features such as a MFT lens mount, large 5 inch touchscreen monitor, 10-bit ProRes and 12-bit RAW recording, 3D LUTs, 4 built in microphones, mini XLR audio input with phantom power, Bluetooth wireless camera control, HDMI on set monitoring output and more. The latest Blackmagic Design color science lets customers shoot images that are far better than DSLR cameras and even better than professional digital film cameras costing tens of thousands more.
    Designed using a space age carbon fiber polycarbonate composite, the body of the Blackmagic Pocket Cinema Camera 4K is extremely strong and light. The carbon composite material consists of a high strength polymer that’s reinforced with carbon fibers. This gives the camera body incredible strength and rigidity to help protect it from accidental knocks and drops which can often result in damage. The handheld design features a multi function grip which has logically placed buttons and dials that allow super fast access to essential shooting functions such as recording start/stop, still photos, ISO, shutter, aperture, white balance, power and more.
    Fourth generation Blackmagic Design color science lets customers shoot HDR images in film, video and new extended video modes. The new extended mode combines the latitude of digital film with an optimized video file. This gives customers working on fast turnaround projects an ideal solution for shooting great looking images that don’t need a lot of color correction or post production work.
    Images can be recorded onto standard SD cards, faster UHS-II cards or CFast 2.0 cards in either ProRes or RAW formats. The Blackmagic Pocket Cinema Camera 4K can record 4K images at up to 60 frames per second and windowed HD at up to 120 frames per second. It’s also the first camera that lets customers record directly onto the same exact external USB-C media drives they use for editing and color correction. That means customers can turn projects around much more quickly because they don’t have to transfer files. All they need to do is unplug the USB-C drive and then connect it to their computer to start editing.
    The Blackmagic Pocket Cinema Camera 4K uses the same MFT (Micro Four Thirds) lens mount as the original Pocket Cinema Camera so customers can use the investment in lenses they already own. The MFT mount is extremely flexible and allows for different lens adapters so customers can also use PL, C, EF and other types of lenses from manufacturers such as Canon, Nikon, Pentax, Leica and even Panavision.
    The rear of the camera features a large bright 5 inch touchscreen that makes it easy to frame shots and accurately focus. It also uses the same Blackmagic OS as URSA Mini so customers can use simple tap and swipe gestures to adjust settings, add metadata and view recording status. On screen overlays make it easy to see recording parameters, status, histogram, focus and peaking indicators, and playback controls. In addition, 3D LUTs can be applied for both monitoring and recording.
    For audio, the Blackmagic Pocket Cinema Camera 4K features multiple built in microphones with an extremely low noise floor, a mini XLR input with 48 volts of phantom power to connect professional lapel and boom mics, and a 3.5mm stereo audio jack for connecting different types of video camera microphones. The high quality built in audio recording means customers don’t have to carry around a separate recorder.
    The Blackmagic Pocket Cinema Camera 4K also includes a full size HDMI connector which can output HDR video as well as a clean 10-bit video feed with optional on screen overlays. There’s also an innovative high speed USB-C Expansion Port for adding external accessories such as flash drives and an SSD for external recording. The camera uses standard LP-E6 batteries and can be charged via USB-C or the locking DC power connector, which protects the camera from being accidentally unplugged during a shoot.
    “Customers love the original Blackmagic Pocket Cinema Camera and have been asking us for a 4K version,” said Grant Petty, Blackmagic Design CEO. “We’ve listened and built a camera that combines all of our newest ideas and customer feedback from the previous model! The new Blackmagic Pocket Cinema Camera 4K is exciting because it packs so much technology into an incredibly small design. We feel it will go well beyond what customers expected. It’s perfect for anyone that needs a truly professional ultra compact digital film camera. This is not a consumer camera that’s trying to do high end work, it’s a true high end camera designed for high end work.”
    Blackmagic Pocket Cinema Camera 4K Features
    • Full size 4/3 sized sensor with native 4096 x 2160 resolution sized sensor.
    • Compatible with extremely high quality Micro Four Thirds lenses.
    • Super wide 13 stops of dynamic range allows capture for high end feature film look.
    • Up to 25600 ISO for incredible low light performance.
    • Carbon fiber polycarbonate composite body which makes it lightweight, portable and durable.
    • Multi function grip for quick access to recording start/stop, still photos, ISO, shutter, aperture, white balance, power and more.
    • Built in SD, UHS-II and CFast card recorders.
    • USB-C expansion port allows longer duration recording directly to an external SSD or flash disk.
    • Standard open file formats compatible with popular NLE software such as 10-bit ProRes and 12 bit RAW.
    • Features full size HDMI output for monitoring with camera status graphic overlay.
    • Professional mini XLR input with 48 volts of phantom power for connecting to pro microphones.
    • 3.5mm audio jack, headphone jack, and locking DC 12 volt power connection.
    • Built in 5” LCD touchscreen allows accurate focus when shooting 4K.
    • LCD supports on screen overlays including status, histogram, focus peaking, and transport controls.
    • Records 4K images at up to 60 frames per second and windowed HD at up to 120 frames per second.
    • 3D LUTs can be applied for both monitoring and recording.
    • Blackmagic OS as used in URSA Mini and URSA Broadcast cameras.
    • 4th generation Blackmagic color science.
    • Supports remote camera control via Bluetooth.
    • Includes full license for DaVinci Resolve Studio editing, color, visual effects and audio post production.
    Availability and Price
    Blackmagic Pocket Cinema Camera 4K will be available later this year for US$1,295 from Blackmagic Design resellers worldwide.
  • Once you consider the license price for Resolve, it is the same price as the original BMPCC!
    960 x 540 - 56K
  • Amazing, gonna sell like crazy!
    Looks like Panny will need to drop the price of GH5s a lot so they can sell as many units as possible before September :D
  • No EVF? Is there anywhere they state just how bright that screen is? I've yet to see anyone making one built onto the camera that is actually usable in broad daylight.
  • this would be perfect it if had more high speed frame rates for slow mo.
  • Missing: DNxHR, flippapble screen, IBIS. But I can live with that just take my money!
  • It's not a super 16 sensor. It's a full-size micro 4/3 sensor.
    But yeah - based on Black Magic's previous failures to meet shipping estimate times, placing a pre-order is a quick path to frustration and anger. It's better to wait until they're actually shipping it.
  • I don't mind what the camera looks like, but I'm wondering if its specs match the GH5 and GH5s's. Cinema 4K at 60 fps is a serious plus, especially if it can record it in 10-bit more or less internally. The dynamic range seems to be comparable to the GH5s, as well. (I don't know how the use of the Super-16 sensor differs from M 4/3.)
    Obviously, Wait and See. But at half the price of a GH5s, this is severely tempting.
  • Haha you are 100% right, VK. This is Blackmagic, after all, they had me in their swoon.
  • Pre-ordering now.
    And this is stupid step. :-)
    Wait a year at least before jumping.
  • Records straight to a hard drive?! Built in LUTs? Redone audio, micro 4/3 mount...holy crap. 1295?!?!?!?! Pre-ordering now.
    650 x 367 - 33K
    650 x 371 - 32K
    650 x 283 - 29K
    650 x 427 - 42K
    618 x 500 - 38K
    650 x 404 - 27K
    650 x 456 - 43K
    650 x 404 - 35K
  • Dang, this camera is ugly... and they've sort of given up on the "pocket" in "pocket cinema camera," but other than that, it looks really outstanding.
  • Blackmagic is livestreaming it on their YT channel right now:
    People are starting to trickle in and mill about now.
  • May be it is just raw video P&S camera, for rich?
  • Ugly thing, but if has decent low light and it's sub-$1500 I would go for it.
  • Can get this or get 6x Z CAMs :-)
  • @tonalt
    There looks to be a notch on the upper right side of the LCD panel. Probably meant for you to pull and flip out the screen.
    EDIT: Looks like there's no flip screen after all :(
  • Does not look flippable to me. But mount is m43.
  • Apparently the screen on the BMD Pocket Cinema Camera 4K will be able to flip out (perfect for my vlogs, ha! As a bit of a struggle to film myself currently when I use my original BMPCC :-/ )
    706 x 714 - 45K
  • Light sleeper here, but thought I share this.
    https://twitter.com/jamiefenn/status/983257171008749568?s=19
    1242 x 1173 - 162K
