PV Team CP++ 2018 A7 III shots
                  Our CP++ 2018 In Depth Interview
                  Is it me or did the prices suddenly jump $200 in the US and €100 in Europe?
Nothing jumped.
Check links at first topic post.
Box and contents could be from $300 camera few years back
                  Another "dual-iso" thing
Note the jump in dynamic range at ISO 640 for both cameras. That's essentially the camera's second 'base' ISO, where the second stage of the dual-gain architecture kicks in. At ISOs 640 and above, most recent Sony sensors use a higher gain mode that essentially amplifies the signal at the pixel-level to get it above the (already pretty low) noise floor.** In laymen's terms, that just means 'more picture, less noise', particularly in shadows – hence the increase in dynamic range.
Even compared to A7 II sensor is not really better, outside of dual iso stuff
Worse thing is that we do not see that they understand under DR and how it is measured.
To have such gain you need either very bad ADCs or some software tricks.
