i've done tests with this camera and have accumulated the latest hack patches and the ip's to connect wirelessly to your computer. I can also say, don't use flat profile, it doesn't store flat, it just makes it flat not more dynamic range and the 8 bit can't survive that colorwise.
@joewickert See: https://www.dpreview.com/forums/post/60378520
I broke the screen and replaced it. Good as new.
Thanks for the link.
I was looking at replacement screens, but could only find ones 10 times the price!
Nice.
Can anyone who owns a Yi4k help me with settings?
I have one with a broken screen. Apparently the cam doesn't like being dropped 50 metres when a drone randomly looses power. (drone didn't like it much either, but it's 3d printed so just had to print out some new arms).
Good news is camera works fine with smashed screen, but i need to set some settings by uploading a file called system.pref.upload to the sd card.
I'm trying to switch on analog AV out via USB, but I can't work out the settings.
So, if anyone has one of these and could share the settings that would fantastic.
Just need to: - switch on av out in the advanced settings touch screen menu - put a file called system.pref.download on the sd card - reboot. the current settings should be written to the file. - share the settings file - then i change name to system.pref.upload on my cam
This process was a life saver for me when wifi got turned off after a firmware upgrade.
Thanks
Protective metal case
I am waiting for the pink 4K+ to add to my collection of the right stuff.
The Pink one is now only $149!
https://www.bhphotovideo.com/c/product/1255909-REG/yi_technology_yac4kg_4k_action_camera_rose.html
Almost proper version for $185
Review
Video Samples
http://www.photographyblog.com/reviews/yi_4k_action_camera_review/
Hi guys, we upload a 1.5.8-beta firmwre for yi 4k, we added Exposure spot select and lock feature, based on the 1.5.7-beta firmware ,
https://www.facebook.com/groups/838989242858914/permalink/1386534364771063/
Present sale is $199, btw
More details, less compression artifacts - basing on my own tests, not the example above.
Valdi99, can I ask you what you see better in that video? I see an over-sharpened image whose field of view is being chopped around as the camera moves (perhaps they have the 'stabilizer' on?). What do you see the higher bit rate is imparting to that image?
https://github.com/irungentoo/Xiaomi_Yi_4k_Camera
Linky for bitrates
Significantly better, to my eye. Example:
