Panasonic is introducing a second advanced compact camera, the FZ2500. This camera utilizes the same 20.1MP 1" MOS sensor as the LX10, but optimizes video performance with the inclusion of DCI 4K video recording and a true 24 fps frame rate, in addition to more conventional UHD 4K and Full HD recording modes. Also benefitting videographers, this camera includes Panasonic's CINELIKE D and CINELIKE V picture profiles for better grading capabilities, and V-Log L can be added via an optional upgrade. Additionally, high bit rate recording up to 200 Mbps is supported in both MP4 and MOV formats; video can be output over HDMI with a 4:2:2 10-bit signal; there is no recording duration limit; and a built-in ND filter can be used for enhanced control over exposure settings while recording.
More than just a video-optimized camera, however, the FZ2500 also sports a slew of specs for stills and movie users, such as a 50 fps continuous shooting rate with an electronic shutter, or 12 fps with a mechanical shutter, and an expanded sensitivity range of up to ISO 25600 for working in dim light. The built-in 20x Leica DC Vario-Elmarit f/2.8-4.5 lens covers a 24-480mm equivalent focal-length range, and 5-axis HYBRID O.I.S.+ controls the effects of camera shake for sharper handheld shooting. A free-angle 3.0" 1.04m-dot LCD touchscreen permits intuitive control and viewing ease from a variety of working positions, and a 2.36m-dot electronic viewfinder is also available. Additionally, built-in Wi-Fi also supports wireless image sharing and remote camera control.
Panasonic Lumix DMC-FZ2500 + $100 gift card for $997
Bundle for $997
https://www.bhphotovideo.com/c/product/1306713-REG/panasonic_lumix_dmc_fz2500_digital_camera.html
                  B&H also offer $100 gift card now
https://www.bhphotovideo.com/c/product/1280827-REG/panasonic_lumix_dmc_fz2500_digital_camera.html
1080p 24p vlog 8bit internal rec grading cnieplus VistaLUT
Panasonic Lumix DMC-FZ2500 + Adorama $100 Gift Card, $1197
You need to get sizing of FZ2500 and look for cage for other camera models that are slightly larger.
FZ2500 owner during eating leafs after getting expensive camera
http://www.imaging-resource.com/PRODS/panasonic-fz2500/panasonic-fz2500A.HTM#conclusion
                  Review
The camera will record 4K video, including CINE resolution, and has a number of advanced options and controls. The biggest drawback is that as you use the zoom, the lens stops down to f/4.0 from 80mm equivalent, which reduces the camera's low-light performance. Due to this, you may prefer a different camera, with a brighter lens, or interchangeable lenses if you have the budget available. If you mostly shoot in good light, or can add light to a scene then this limitation may not be such an issue for you. Video quality is very good, and there are numerous options and controls available, making this an excellent all-in-one camera for those that want both high quality video and stills.
https://www.ephotozine.com/article/panasonic-lumix-fz2000--fz2500--expert-review-29912
                  So on the first shoot, the camera randomly stopped recording in the middle of the event, wasn't even 20 minutes in!
The card I used was a Sandisk Extreme Pro 128GB formatted in camera, shooting MOV, 1080p, 100mbps, 30p, Shutter Priority Mode.  Event was indoors, church setting, no idea why it stopped.
This certainly does not give me much confidence for future jobs!  I've been using the FZ1000 previously all summer with the continuous 4K recording without any problems.
The FZ2500's lens is a good illustration of why it is a video-centric camera. Unlike the Panasonic FZ1000 and Sony RX10 III, once the lens is extended, it stays there, as zooming is internal. This allows for smooth and remarkably quiet lens movement, which is exactly what you want from a video camera. One really big deal for still and specially video shooting is the camera's built-in variable ND filter, which is accessed via a switch on its left side. You don't have just on or off options with the filter: 1/64, 1/16 and 1/4 are also available. As one would expect, the lens is optically stabilized and, for Full HD shooting, a 'Hybrid' 5-axis anti-shake mode is available.
https://www.dpreview.com/reviews/panasonic-lumix-dmc-fz2500-fz2000
[Info added by VK]
Another review
http://www.photoreview.com.au/reviews/advanced-compact-cameras/fixed-lens/panasonic-lumix-dmc-fz2500
                  Samples
https://www.dpreview.com/samples/1939264024/panasonic-lumix-fz2500-fz2000-real-world-samples-gallery
                  Coupla questions 1) does this mean there are 12 stops dynamic range or that camera can enter alcohol rebab mode? "Log recording offers exceptional flexibility as well as a wider dynamic range for color grading in the post-production process and V-LogL features log characteristics with 12 steps." I like the FZ1000 but DR was lacking. 2) Not clear what the main difference are with the FZ1000 aside from built in ND filters. Will the software respond faster? fz1000 tends to be sluggish.
not much at all, the second you start zooming it starts moving up I'm afraid
@fosterchen Up to what focal length can the camera hold f2.8 until it starts stepping down?
Just turned mine on, and I've noticed the change in F stop from F4~F4.5 starts at around 90mm in FHD, and 130mm in UHD, which means the lens is actually slower than the one in FZ1000 which can maintain F4 to 400mm.
