@cas1 well that makes it 35mm and with a 500 buck .8 converter , 28mm
Yes it is still crap not to have wide angle out of the box.
I was so hoping they could read out the whole sensor and down sample..
How could they have missed people's wishes for a 4k wide angle?
Just wait for HEVC 4k 60fps 10biut HDR chipsets, will be in next generation.
It seems like all Japanese firms become so scared about HEVC legal things, so avoid it.
Despite the lack of wide angle 4K, I like the overall package of this camera. I can carry a tiny cam for Ultra Wide angles when needed. For most of the work I do this would cover most of it in a very handy package. It's a very compelling camera. I also still like the Sony RX10 II which has the constant f2.8 lens. I wish this FZ2000 had a constant f2.8 even if it meant a short focal range.
Actually the FZ1000 slow zooming is NOT so bad as in the video.
And there was much rejoicing
                  Photokina again
so what happened to the L monochrome mode on the fz2500 ?
Interview with Carol Hartfree about Panasonic new ultrazoom focusing on new features - such as improved 4K, ND filters, AF and such.
best spec sheet I've seen so far http://www.photographyblog.com/reviews/panasonic_lumix_dmc_fz2000_review/specifications/
FZ2500 video created by Giulio Sciorio
It's ND filter in AUTO position equivalent to Sony Variable ND in FS5?
No, because it's still big jumps between each ND setting (2 stops each I believe). Same as the manual ND settings, just the camera is setting them, not you. The FS5 ND moves in steps so small they're basically imperceptible.
@aldolega Ok. Thanks.
and they traded that quite useful 4k live cropping kenburnesque feature for that absolutely useless, maybe once, dolly zoom ! Man I wish panasonic would just make the camera I want !
Samples
                  Review
FZ1000 model and turns it into a mini-GH4, offering almost all of that camera's video capabilities in a convenient super-zoom format. If you want a non-interchangeable lens camera that will cover all your still and video requirements, the new Panasonic FZ2000 is the one to buy.
http://www.photographyblog.com/reviews/panasonic_lumix_dmc_fz2000_review/conclusion/
                  Just turned mine on, and I've noticed the change in F stop from F4~F4.5 starts at around 90mm in FHD, and 130mm in UHD, which means the lens is actually slower than the one in FZ1000 which can maintain F4 to 400mm.
@fosterchen Up to what focal length can the camera hold f2.8 until it starts stepping down?
