Nebula 5100 one hand gimbal, now with encoders
    • A new generation motor with built-in encoder for all 3 axes
    • High torque, 8-10 hours battery life
    • Made from high quality Al-Mg-Si alloy
    • Hidden cable design, 360° unlimited rotation
    • 2.5kg Payload
    • One key back to the midpoint return option
    • Direct charge
    • One key recording using button and build in IR remote
    • 1/4 screw holes for various support equipment
  • 68 Replies sorted by
  • I await their response...thanks.
  • @Spectra
    Their fault. But you also need to check words.
    They changed support department and now also have local Australian stock. So, do not worry so much.
  • Ifs, buts and maybes do fuck all to address my concerns...There is no excuse for this company to completely ignore my subsequent email after initial contact was made - I followed their instructions and made a video of the problems I was experiencing and sent a link to it on dropbox...Since then I have not heard a word.
  • @Spectra
    I remember your issues.
    I checked messages, and your last one is 3 months old.
    About vibrations. Usually it is one axis and can be fixed using software tuning. If problem is not with motor itself.
    Company will contact you asap.
  • I have had all sorts of issues with this gimbal....
    The main problem I am having is that after balancing the camera (according to their instructional video) and switching it on it just sits there and vibrates...does it when I change to different lens combinations. If I stabilise it by placing my hand on the camera it stops but as soon as I take away my hand it just starts up again and vibrations seem to fade and reappear...anyone else having these issues? Any solutions?
    The packaging it arrived in looked like crap and showed signs of being tossed around....not a great first impression.
    The main gimbal arm actually hits the top of the gimbal handle area as it swings through its axis which to me suggest either transport damage or shoddy engineering...either way unacceptable for the product to arrive like this.
    I relayed my concerns to filmpower almost three months ago and after receiving an initial replay from "Iris at Filmpower" they asked for a video demonstrating the problem which I sent them a link to... No reply since then.
    My conclusion...Avoid this company like the plague...
  • Expo photos with larger cameras
    800 x 593 - 66K
    800 x 537 - 66K
  • Nebula5100 + Riser rail + Sony FS5 & Canon 1DX
  • Cool invert mode shooting.
  • Cine Gear walk with Nebula 5100 and Nano360 camera
    And this is with m43 camera
  • @Vitaliy_Kiselev Wow, those accessories do look nice! :D
  • Nebula + Sony FS5. New video on their channel.
  • @Tim_White This is the instructional video show how to set Time-lapse function and change settings.
  • first real test filming eMTB with GH3 and unstabilised 12-40mm olympus
    Some comments : When loaded, the roll lever can touch the yaw motor when doing a 180° move, I think they should add more clearance here. I added a arca swiss syle QR plate on top of the QR plate shipped with the gimbal, but to balance the GH3 with 12-40 olly I had to adjust the pan clamp all the way to the limit (top of the L bracket in line with the screw/clamp). The mode 4 with follow on all axis is great for following a subject very fast on uneven tearrain.
    Battery life is top! did not manage to empty one batt in 2h45m of shooting (not continuous)
    moving and holding about 1 sec the gimbal by hand works a treat to setup positions.
