A little fine tune in the settings, patches and dynamic range preset:
                  The patches in previous post are correct, but the dynamic range preset is wrong.
Here are the correct dynamic range presets, two sets, in three levels each.
Third upload have the two sets, read txt file inside the zip to understand.
                  Dear apefos,
if the world had the same dedication that you give to the gh2, then all the world's problems would be solved.
Thanks,
I think my work for the GH2 is finished now!
Dont stop apefos.there are still a lot of low budget people using the GH2 for film making including me who`s still learning for the best shot.But thank you for all you already did ,may the GH2 still work forever!!!!
The final bundle is here, patches stable and intra, with new dynamic range presets with new curves:
GH2 Blundle by Apefos 24-01-2017
                  When using the presets for the GH2, I perceived that disabling the RGB Color Corrector when using the 1DR and 2DR deliver best results. 3DR is too much shadow lifting.
For the Nex-5n keep the RGB Color Corrector enabled is great to save highlights, when using these presets (1DR and 2DR)
Thank you Apefos! Great work! :]
Video looks pretty good (The End NR4 Stable 33356)
Stream Parser screenshots:
                  Interesting things when using the dynamic range presets:
The user can make your own option among the three different sets, and each set have three levels. In each preset, there are three effects, and the user can enable/disable each effect doing own combinations. When there is sun and shadows the Color Corrector RGB helps a lot, when there is low contrast situations, disabling the Color Corrector RGB is good. Sometimes the curve shadow lifting helps a lot, sometimes disabling it can be better...
So user can try different presets and in each preset can enable/disable the effects.
Modest away for a while, I am pretty happy with this bundle, it gives a new life for the GH2.
This bundle and the gpuresize plugin for upscaling the 720p makes a long living for the GH2.
I also perceived that using the neatvideo presets and profiles uploaded in this topic is good idea for vimeo and youtube. The heavy compression for web streaming hurts the image texture and noise, so the original images in high iso becomes a dirty look, so a neatvideo denoise is welcome if the final result will be web streaming. Web streaming is not friendly to iso noise and film grain effects, a clean image is much better. I prefer to apply the dynamic range presets first, upscale the 720p and last thing is neatvideo denoise.
If the delivery will be a 35mbps gop6 bluray or a high datarate DCP file or a high datarate pendrive then neatvideo can be avoided.
These two DR presets are an attempt to solve everything with just two presets:
HC = high contrast for scenes like sun and shadow
LC = low contrast, better for faces and homogeneous light
                  When developing the Dyanmic Range Presets, the GH2 camera settings was set to:
Profile: Standard
Contrast -2
Sharpness -1
Saturation -2
Noise Reduction -2
Let me just get this straight; your patch is the solution for my never ending problem? Is this what you mean by "Diagonal rain pulsing pattern"?
                  @juanpablo_ayala Last uploaded patches can be "The End" for your never ending problem.
Why I called these patches as "The End NR4"?
When I started hacking my GH2 I perceived there was different patches with different purposes and different levels of stability. So I asked myself: why there is no patch with everything good on it?
So I started long time ago developing patches in an attempt to get the best, the maximum possible from GH2, to be used in all situations.
I studied different patches to perceive the benefits from each one, and I got the help from the masters of hack, they teached me important things. I also studied two H264 books, and wikipedia articles about compression and DCT transform. I remember the stress charts on the computer screen...
After infinite versions and patches names, when I perceived that everything was ok, so I called it "The End" because I saw no reason for use other patches, it was the end of hack for me, the camera could not do more.
Every settings in PTool was tweaked, including the most dificult things like quantization, gop tables, deblocking and matrix, with careful tests to understand what each setting could do.
The End is stable, good noise, good texture, good image quality, good for steady shots or movements, night or day, dark or light, detail of flat surfaces, low and high iso, making GH2 useful without denoise at iso 2000 and a top limit at iso 4000 which works perfect for neatvideo denoise.
The camera was at maximum datarate possible and the data was very well distributed among the I, P and B frames, IP for 720p and IB for 24p. And then a intra version started developing.
People can say: but there are matrices for more noise, less noise, jumping texture, flat texture... Yes there are, but The End matrices are set at a magical point of maths to get the best from the sensor, the most agreable point between gross and fine, balancing texture, noise and compression. The matrices adjusts the noise and texture but they also need to compress the image, because if they do not compress enough, other compression like quantization and datarate after it would hurt the image.
The End solved the diagonal rain pulsing pattern calibrating the mathematic in matrix and deblocking. This was a pain in the ass, and nobody knows what to do to solve, including considering it was a problem of decoders.
NR4 is the best level of denoising adjusted on the matrices.
There are two versions of The End NR4 because one goes to the camera limits and other goes for perfect stability. And both versions was tweaked and tested for NTSC and PAL.
Intra frame is All-I for 24p at 120Mbps and 70Mbps gop4 for 720p60. 720p50 is gop 3 and higher datarate. It is perfect stable for intraframe, but 720p60 can use only one or two electronic features at a time: ois, auto focus, auto exposure, idynamic... Also 25p is intraframe because it shares the same gop from 24p, i did not want this, but it is impossible to change.
Stable version is perfect stable and all camera features can be used simultaneously. It is gop3 for 24p at 96Mbps and gop 6 for 720p at 55Mbps. It is gop5 for 720p50. Excelent quality with perfect stability and a little longer recording times. Here 25p is gop3.
Spanning was not possible because the high datarate makes the camera stop recording at 4GB, so I focused on image quality and stability, reliable 4GB files, if you do not stop recording, the camera records 4GB and saves the file.
People who needs HBR 30p or 25p can also trust in The End NR4 patches, because all recording modes was tested and calibrated. I recomend the Stable version for HBR. Considering HBR, probably there are other patches pushing the HBR limits, but The End NR4 goes to the maximum stable point.
With all respect to the other patches, unless you need spanning, I see no reason tho use them anymore, but patches are a personal-view choice, so everybody is free to try and choose. Whitout the other patches I would never reach these accomplishments, because I used the knowledge and achievements from them. At first moment I used settings from other patches, and after experimenting, reading and getting help to understand each thing I developed my own settings. About spanning I uploaded some attempts in this topic, but they were not tested.
Enjoy The End NR4 Stable 33356 and The End NR4 Intra-MS 11334, download them here:
http://personal-view.com/talks/discussion/comment/230212#Comment_230212
And also remember to download the NeatVideo presets and profiles for perfect denoise, and the Dyanmic Range presets to get a more cinematic image from GH2, see the other posts in this topic.
This is a better 30p hbr, stable version, only changes the 30p and 60i for gop6.
This is the version I am using in my GH2.
                  @apefos Well, thank you so very much for sharing with the world and for your kind explanation. Also, congratulations on your success. I will test in the field and provide my feedback for others. Regards.
It is good to see someone are willing to test. Other patches are full of tests, feedbacks and footage, but here, each time I post something new, there are about 300 views, but no feedbacks...
Too many versions of patches with claims of "finally the best patch". Not just your work but other patch threads too! I gave up on new patches over a year ago because there's no major improvement, just a little fine tuning and pixel peeping. The development of Driftwood patches came to an end for similar reasons.
I agree. When we are developing we think there is nothing else to do, but suddenly a new idea comes to the mind. This way we could call these patches as Never Ending instead of The End. But now I realy feel there is nothing else to do. So I will keep the name The End.
Every time I posted a new patch or dr preset there was about 300 views.
Now The End development is complete, so it is time for donate to PV forum.
If 300 people donate $5 for PV it will be 1500 to help the website.
Think about the developing since the beginging, workhorse, boson, gspot, the patch, the end...
If it is useful for you, please donate to PV and help the comunity
These two patches in this post are special made for PAL. A version with higher datarate gop3 for 25p, and a version with lower datarate gop6 for 25p. Everything is the same as Stable and Intra-MS versions, only changes the gop for 25p.
The GH2 uses the same gop for 24p and 25p. So when we want 24p to be intra, the 25p become intra also, but it is not desirable because the datarate in 25p is lower than 24p and not enough for intraframe. When we want 24p to be gop3, the 25p become gop3 also, but it is not desirable because the datarate in 25p is lower than 24p and not enough for gop3. So these two patches changes the gop for 25p in an attempt to get a better PAL HBR quality, but the drawback is: 24p gop is not ideal, so use these two patches only if you need 25p HBR.
In both versions 720p50 is gop5.
I did not test these patches in the GH2, I just changed the gop, so do your own tests.
(In The End NR4 topic there is a gop2 pal version, it can be a good sweet spot for 24p and pal in same patch.)
http://personal-view.com/talks/discussion/comment/194073#Comment_194073
http://personal-view.com/talks/discussion/comment/194204#Comment_194204
                  The End NR4 Stable and Intra hack patches and GH2 Bundle are celebrating 10K views!!! Thanks.
GH2 Bundle 08-27-2017
New improved neatvideo4 presets and profiles for 1080p24 and also 720p60 without upscale, based on the stable version patch.
Patches are the latest versions re-uploaded.
Dynamic range presets, the best ones together.
