So it sounds like we could see a further firmware update next year to implement 10 or 12 bit HDR jpegs.
Or we will have war with 5 standards competing for it :-)
Actually no one need so called "HDR" jpegs.
It must be HEVC based stills encoding with 12-14bit linear sRGB.
Very true! I guess Dolby and Microsoft are also pushing their own "HDR" photo standards.
Here in the lumix lounge, one can find all specs, explanations og the GH5 and the known videos, but also 6K photo samples, that I have not seen yet.
Does somebody know if you shoot at 180fps, can you choose not to conform in camera and output a 180fps video file to play with it in post? Or do you have to choose some framerate up to 60fps?
I'm curious about the bitrate of each fps output.
Olympus Mk II sensor results are up, must be very close to GH5
It seems that Olympus implemented more aggressive noise reduction, now in raw also
Olympus claim it’s a newly developed sensor and with lower noise, and both wider dynamic range and improved color discrimination at all ISOs it is one of the most significant upswings in performance we’ve seen in this format.
https://www.dxomark.com/Reviews/Olympus-OM-D-E-M1-Mark-II-sensor-review-New-standard
If I may say my totally unscientific impression, based on working a lot with NR software in post, GH5 also uses heavier noise reduction than we have previously had on Lumix models, and many other cameras for that matter, and by that it gains better apparent ISO performance, but in high ISO examples we've seen so far, NR and sharpening artefacts are obvious. It seams that they've only raised the bar of what is possible to CPU, and the bar of what is acceptable to present as better low light capabilities.
This is also why we need good lab that is able to measure sensors and check also video and photo raw behavior.
I am sure that in coming years we'll see more and more focus on software due to hardware limits.
It is a worthy mission Vitaliy, and I only now see that aspect of your Lab idea. In fact, maybe these kind of tests should be sought after and funded by companies that make software for postproduction 'correction' really, since these guys are taking their game away.
For now, if 'prosumer' gear manufacturers loose compass in what is too much, someone needs to be there with legitimacy and competency to call bullshit, at least to force them to call things right. And they ARE getting more and more brave, seems like, not only in video capturing, audio has less hardware requirements, and has been victim to that kind of strategy for a while, as the recorders get 'smarter' - have more capabilities for complex software processing of what's coming in from cheaper and shittier mics. Obviously that is what is going on now with this market, and I don't see why it wouldn't spill over to higher end.
Any funding has big consequences. Company providing any funds want to see certain things in certain time, and do not see other things, never ever. This is also why this see 90% review sites declaring 'revolution' each week.
@Vitaliy_Kiselev, I don't see any trace of NR applied to RAW's in the Em1 mk2 sensor. If it was like you said, the color fidelity would have suffered but it doesn't and the noise structure is nice, not like the higher ISO's in Sony and Pentax cameras. :)
I get it. This case seems to be fail safe, but it is a different ballgame altogether, of course, I was just thinking aloud without considering how the market works.
To get back on topic, I really hope that some software processing in GH5 can be shut off, to see where we are, and that some hardware sensor possibilities are at least a bit improved and not worsened while we admire software processing. In that pdf presentation there is a page on overexposure protection in certain modes "Like709 & Knee Control Suppress Overexposure by High Luminance Video Signals", to me, everything overexposed looks extremely bad on GH5 in a very original and distinctive way that resembles some video cameras from nineties, so I hope that this is not their new and revolutionary knee control, and that it can be shut of.
I prefer more formal and scientific way, as "suffering color fidelity" is too wague.
@inqb8tr "If I may say my totally unscientific impression, based on working a lot with NR software in post, GH5 also uses heavier noise reduction than we have previously had on Lumix models, and many other cameras for that matter, and by that it gains better apparent ISO performance, but in high ISO examples we've seen so far, NR and sharpening artefacts are obvious. It seams that they've only raised the bar of what is possible to CPU, and the bar of what is acceptable to present as better low light capabilities."
I also had exactly the same impression.
@Vitaliy_Kiselev , I'm not a sensor engineer but as a photographer which used a lot of cameras in his life, I see no trances of NR applied to the EM1 mk2 RAW files. I may be wrong, yes but so far I see no trance of NR pattern like in Sony and Pentax high ISO raw files. I'm also looking forward for more scientific tests that prove or disprove this NR theory.
GH5 will be present at
Let me know if you'll be on this events.
I went to previous GH5 events at Adorama and AbelCine. May go to B&H event. Sounds like Matt Frazer won't be there but most likely Sean Robinson. I tested IBIS with manual primes, as well as a few other features. Initial feedback is that IBIS with primes is a gamechanger! Also tested GH5 with new 12-60 Leica/Pany with dual IS enabled on a my DS1 gimbal. IBIS and gimbal did NOT fight eachother and only made things smoother, though didn't get much chance to play with IBIS settings when on gimbal. When used handheld and with 50mm f1.4 on XL speedbooster, I tried the two different IBIS settings and made recordings of both - one setting was definitely better than the other (think one of the setttings engaged software based IS which seemed to introduced some less-desirable results). Will upload video results soon. Overall impressions of GH5 are really positive!
Will also add that the GH5 fit perfectly in my soon-to-be-released camera cage. Tested with speedbooster with tripod foot mounted and fit just fine. Even got to test cable lock mechanism that comes with GH5 with my new cage and that fits too, though to be honest, the cable lock is not so much of a lock, but rather is a cable/jack guard.
@sam_rides_a_mtb How does the 12-60 2.8-4.0 compare to the 12-35 2.8? Is it about as good, better or worse?
There is another interesting bit regarding the GH5 and HEVC.
Hybrid Log Gamma uses REC.2100 and its content has to be 4K 10-bit 422 but H.264 doesn't support HLG, so unless that changes, it will have to be H.265 - since I don't expect the GH5 to support VP9.
BBC and NHK are thinking about the future and broadcasting HDR content and bandwidth is important, if they were to get support by AVC codec, I would had expected them to already had done so, which makes me believe HLG won't be supported by H.264 after all.
If that's true, even if only for HDR content, the GH5 will have to output 4K 10-bit 422 HEVC and if so, why wouldn't Panasonic output it in other flavors of 4K? So I think we can expect to get 4K H.265 codec.
I am confused by statements.
Rec. 2100 has the same color space as Rec. 2020
Also, color space has little to do with HEVC or H.264 (until it is delivery format).
Plus, if it is true, it is stupid thing to select this space, as it is same story as bad long implementation in GH4.
I am also quite sick of all logs, hyper logs and such.
@Vitaliy_Kiselev Where did that quote come from?
Also, indeed Color Space has nothing to do with codec, but I never said such thing. I simply stated that the HLG standard uses REC.2100, that's simply part of HLG's specifications.
I just said if the GH5 is going to deliver HLG-ready content directly from the camera and H.264 doesn't support HLG, it should mean that the GH5 will have to deliver it in H.265.
Blood hungry Panasonic employee looking for your GH5 savings
I think HLG is HEVC.
And 4k 60p is 420 8bit so I do not think it will support HLG.
Lol..
10 bits minimun for.hdr and.flavors. NOT LESS. call it HLG HDR HEVC REC 2020-rec 2100 minimun 10 bits. Less is sdr.
Official website of Japan
http://panasonic.jp/dc/g_series/gh5/spec.html
150 Mbps (4:2:2, 10 bit long GOP (IP))
100 Mbps (4:2:0, 8 bit long GOP (IPB)
