Mitakon lens Turbo, Speed Booster analog, available
  • 240 Replies sorted by
  • @monks19
    With tripod mount(!). You can see all photos here and see lack of tripod mount.
    So, you need to use lens support.
  • Hello guys, I'm after a couple of focal reducers for a couple of Panasonic G7's in nikon mount for aperture control and I'm wondering if I could ask a couple of questions, as I'd ideally like to get the Mitakon Zhongyi Lens Turbo II.
    • I haven't been able to find definitive answers about using it with the G7 in 1080 mode (for 50-60fps), will it vignette with APSC lenses? Specifically the sigma 18-35 f1.8, I've seen a guy with a GH4 on youtube say it vignettes, but then another guy says it doesn't on his G7. Does anyone know or use it with this set up?
    • Does the tripod mount from the RJ Lens Turbo fit on the Mitakon Lens Turbo II? In some photos it looks like it might, in others not so much.
    • Does the mitakon lens turbo II have the moving/adjustable back element like the RJ lens turbo? I saw a video of a guy adjusting it for parfocal focusing with the sigma 18-35 1.8, I'm thinking this might help alleviate some of the vignetting if it exists?
    Thanks a bunch guys!
  • Just got the lens turbo II for micro 43 and used it on a Samyang 14mm f2.8 for some astophotography - and have to say I am very pleased with results. Itmakes the 14mm the rough equivalent of a FF 20mm f2.0 and what's particularly pleasing is that the Samyangs great sharpness and coma is maintained. This quick output file of the galactic centre setting over New Zealand coastline has minimal sharpening and colour correction.
    1000 x 1182 - 1M
  • @brake, I use an RJ with a Tascam 17-50mm f2.8 on a G7 and only vignettes in Photo mode. In 4K it's fine. I don't record in 1080. My guess is you should be ok. At most it would be a very mild zoom adjustment to get past the edge of the lens.
  • @Aria how bad is the vignettes in photo mode 4:3, 3:2, 16:9? Does it vignette as well in HD video mode? Thanks
  • @yskunto, no it does NOT vignette in 4:3, 3:2 or 16:9. However with my 16:9 Video Lens Hood on it will cause vignette in Photo use and HD Video mode but not in 4K.
  • Can I control aperture with Canon EF version? What is solution to control aperture on lenses who have electronic control?
    I was looking for answer on this but without luck. Thanks
    You can't control it while it is on adapter.
  • Anyone have any experience with Viltrox M42 reducers compared to the Mitakon ones, which one is better?
    https://www.amazon.com/VILTROX-M42-E-Reducer-Booster-Adapter/dp/B014XPTBWA/ref=sr_1_4?ie=UTF8&qid=1478585540&sr=8-4&keywords=m42+focal+reducer
    https://www.amazon.com/Zhongyi-Mitakon-Reducer-Booster-Adapter/dp/B00MRMZBA8/ref=sr_1_5?ie=UTF8&qid=1478585540&sr=8-5&keywords=m42+focal+reducer
    The only difference I see is that the Viltrox have 5 elements/4 groups and Zhongyi have 4 elements/3 groups. Any idea which have the better performance (sharpness, corners)? I'm deciding which one I should get.
  • @pureaxis
    I suggest to make topic about this Viltrox thing and ask in it. As far as I see it is just generic brand reselling usual cheap adapters with absolutely unknown or even random glass suppliers.
  • Hi everyone! I shot this using Mitakon EF to M43, Helios 77m-4 & Panasonic 12-35 lenses. Sorry, it's without translation or english subtitles. In short, it's a story about creation of the artistic cake for culinary exhibitions. That inspired for creation.
  • Which Canon FD>M43 booster do people recommend? I need one ASAP, thanks
  • ok, PM'd you
  • I ordered Mitakon Lens Turbo Canon EF to M43 V2 on Ebay (I needed it fast). But seller sent me this version. I put Tokina 11-16mm f/ 2.8 on it. When I tested it on wide open I figured out I can not focus to infinity. Focus only work few meters in front of me (on f2.8). Do you maybe know what could be issue here? I have one day to decide should I return adapter or leave it. Thanks for help!
  • The flange focal distance is too long, that can't be shimmed or fixed (if it focused past infinity it could be shimmed and fixed. Contact the seller ASAP, if there's a simple fix (like they put too many shims n the damn thing) but chances are it;'s a bad example/ the optics are not quite right (there's a lot of factors) and you should return it with in your period, if they don't respond., and if they do respond, ask for an extension in writing. Chances are you'll be sending it back.
  • Hi everyone! My wife made paper town, and I shot it using Mitakon EF to M43, and my lovely favorit Helios 77m-4.
  • Nikon G / FX adapter
    663 x 542 - 37K
    650 x 508 - 37K
  • PR
    The Fuji X Camera Lens Turbo Adapter (Ver II) from Mitakon allows lenses to be mounted to APS-C format Fuji cameras, increasing the angle of view by 0.726x and the maximum aperture of the lens by 1 f-stop.
    The four optical elements of the Lens Turbo adapter condense light from the full frame lens and project it onto the camera’s sensor allowing the sensor to capture all of the transmitted light, negating the crop factor and effectively producing full-frame coverage on non-full-frame sensors. A corresponding increase in the maximum aperture of 1 f-stop makes the lens more effective in low-light situations.
    This adapter features 4 optical elements including one extra-low dispersion (ED) element which reduces aberrations for better delineated images. The adapter offers a sturdy metal construction and stainless steel mounts, it attaches to both camera and lens with little play and includes a front and rear protective cap. The Lens Turbo is a manual adapter offering no electronic communication between lens and camera. It is not compatible with Blackmagic cinema cameras.
    • Allows lens to be mounted to Fuji X camera
    • Increases the angle of view by 0.726
    • Increases maximum aperture by 1 stop
    • 4 lens elements in 4 groups including 1 extra-low dispersion element
    This lens turbo adaptor may not fit all lenses due to different extensions at the lens rear mount. Lenses with extension more than 3mm are not recommended to use this lens turbo adaptor. Vignetting may occur if using APS-C lenses.
  • @Thor what's your setup for using hellios (m42mount) with a mitakon II ef to m4/3?
  • Lens Turbo II Nikon G-NEX
    http://stkb.co.jp/info/?p=6973
    650 x 358 - 22K
    650 x 484 - 39K
  • Ok...to confirm once and for all, the nikon g to mft version has an aperture ring? does it vignette when used with the sigma 18-35 on the gh5?
  • @lmackreath
    Yep, for lenses with mechanical aperture lever, not E.
    https://www.nikonimgsupport.com/ni/NI_article?articleNo=000004725&configured=1&lang=en_US
    need to ask owners of all three things.
  • @lmackreath
    The Nikon version has an aperture ring wich works with the Sigma lens, but it will vignette heavily with it, because the glass elements have smaller diameters compared to Metabones.
    The attached pictures are made on a GH2 so the GH5 will have about 1.08x crop due to the GH2's wider sensor.
    Edit: The Diameter of the front element is about 22mm and the diameter of the rear element about 19.5mm.
    18MM F1.8
    18MM F16
    35MM F1.8
    35MM F16
