GPU Engine Specs:
-3584NVIDIA CUDA® Cores
-1417Base Clock (MHz)
-1531Boost Clock (MHz)
Memory Specs:
-10 GbpsMemory Speed
-12 GB GDDR5XStandard Memory Config
-384-bitMemory Interface Width
-480Memory Bandwidth (GB/sec)
Technology Support:
-Simultaneous Multi-Projection
-VR Ready
-NVIDIA Ansel
-SLI HB Bridge SupportedNVIDIA SLI® Ready
-NVIDIA G-SYNC™-Ready
-NVIDIA GameStream™-Ready
-NVIDIA GPU Boost™ 3.0
-12 API with feature level 12_1
-Microsoft DirectX
-4.5OpenGL
-PCIe 3.0Bus
Support
Windows 7-10, Linux, FreeBSDx86
Display Support:
-7680x4320@60Hz Maximum Digital Resolution
-DP 1.43, HDMI 2.0b, Dual Link-DVIStandard Display Connectors
-Multi Monitor
-2.2HDCP
Graphics Card Dimensions:
-4.376"Height
-10.5"Length
-2 SlotWidth
Thermal and Power Specs:
-94Maximum GPU Temperature (in C)
-250 WGraphics Card Power (W)
-600 WRecommended System Power (W)4
-1 8-pin and 1 6-pinSupplementary Power Connectors
1 - Windows 10 requires November 2015 update or newer.
2 - 7680x4320 at 60Hz RGB 8-bit with dual DisplayPort connectors or 7680x4320 at 60Hz YUV420 8-bit with one DisplayPort 1.3 connector.
3 - DisplayPort 1.2 Certified, DisplayPort 1.3/1.4 Ready.
4 - Recommendation is made based on PC configured with an Intel Core i7 3.2 GHz processor. Pre-built system may require less power depending on system configuration.
There are no other vendors.
Nvidia price comparable to EVGA, Asus and other vendors.
