GPU Engine Specs:
         -3584NVIDIA CUDA® Cores
         -1417Base Clock (MHz)
         -1531Boost Clock (MHz)
Memory Specs:
         -10 GbpsMemory Speed
         -12 GB GDDR5XStandard Memory Config
         -384-bitMemory Interface Width
         -480Memory Bandwidth (GB/sec)
Technology Support:
        -Simultaneous Multi-Projection
        -VR Ready
        -NVIDIA Ansel
        -SLI HB Bridge SupportedNVIDIA SLI® Ready
        -NVIDIA G-SYNC™-Ready
        -NVIDIA GameStream™-Ready
        -NVIDIA GPU Boost™ 3.0
        -12 API with feature level 12_1
        -Microsoft DirectX
        -4.5OpenGL
        -PCIe 3.0Bus
Support
Windows 7-10, Linux, FreeBSDx86
Display Support:
          -7680x4320@60Hz Maximum Digital Resolution
          -DP 1.43, HDMI 2.0b, Dual Link-DVIStandard Display Connectors
          -Multi Monitor
          -2.2HDCP
Graphics Card Dimensions:
              -4.376"Height
              -10.5"Length
              -2 SlotWidth
Thermal and Power Specs:
               -94Maximum GPU Temperature (in C)
               -250 WGraphics Card Power (W)
               -600 WRecommended System Power (W)4
               -1 8-pin and 1 6-pinSupplementary Power Connectors
1 - Windows 10 requires November 2015 update or newer.
2 - 7680x4320 at 60Hz RGB 8-bit with dual DisplayPort connectors or 7680x4320 at 60Hz YUV420 8-bit with one DisplayPort 1.3 connector.
3 - DisplayPort 1.2 Certified, DisplayPort 1.3/1.4 Ready.
4 - Recommendation is made based on PC configured with an Intel Core i7 3.2 GHz processor. Pre-built system may require less power depending on system configuration.
		Nvidia price comparable to EVGA, Asus and other vendors.
There are no other vendors.
