Does spanning work, too? Have you guys inspected the streams to check for cadence issues or other issues? If so, that sounds quite promising! I was under the impression that the 45MB/s cards were UHS-1 which wasn't fully supported by the GH2. Do you think it works better than the Sandisk 30MB/s HD Extreme Video cards?
well I have been reading for some time and Im not about to argue with you, but based off of MY OWN use, I have been running this card alone for a month now, with 0 issues. and everything runs smooth, with ALL driftwood setting(havent played with anyone elses stuff) spanning, detail, death trees, motion, lowlight
"people need to get the Sandisk Extreme Pro 45mb cards they seam to be the only wholly stable cards"
Not true.
The best card you can get is Sandisk Extreme Pro Class 10 (30mb/sec advertised, 25mb/sec in testing). People are having lots of problems with the 45mb cards. Search these forums and see for yourself!
@driftwood That sounds great. I have a couple test I have done with GOP1 at home. I will look through and see if I have 10 seconds of brilliance as you said.
@PerryWilson We should have instead a "Members Who We Are VIDEO Thread" Especially all those following this thread. All of them to be shot in GOP1 as you said. Also, I think I'm finally going to make the leap and buy the Sandisk 45mb card. ReAQuainted doesn't seem to be stable on my Transcend and I want to give it a try.
I have had zero errors with an older 16g Sandisk 30 mb/s card. I have heard the 30 mb/s Sandisk is more stable than the Sandisk Extreme Pro 45mb cards? There is also a 95mb/s version. Which should I buy? I think the 30s are no longer available. I'd recommend to anyone, buy at least an 8GB Sandisk card for testing. Not to expensive to get such amazing quality. I doubt you'll get any crashes with the right card.
Hey guys, new GH2 user here. I applied your settings, driftwood, the application went well. Unfortunately my A-DATA Class 10 SDHC 16GB is not up to the task, recording gets canceled almost immediately! I'm currently looking at a SanDisk Extreme SDHC Memory Card (SDSDX3-032G-A21) off Amazon, about 60 bucks. It is not the Pro version which is UHS-1 specification. However I will hold off for now, seeing as driftwood did not get his samples yet ...
I just read smsjr's post from 12:44 AM. It states that the using the same settings the recording crashed on blue police lights. That sounds like a similar situation as I encountered yesterday (blue backlight, spotlights). Somehow I don't believe that the amount of detail is the issue here and hence the card writing speed might not be the issue ether. My scene yesterday certainly did not contain any excessive detail. Anyone any guess what happens when the codec gets confronted with blue flickering lights?
I made my first experiences yesterday with Driftwoods reAQainted settings while filming a trade show set up for a friend. It wasn't the world's most important job, but I had several crashes during recording. One crash occurred when filming a static surface that started to move after a few seconds. The other many crashes occurred while filming a blue and back-lit banner and a cabinet with halogen spotlights in its ceiling. The no matter how low the depth of field or how different the framing, the recording crashed, though not with freezing the camera. I had to default to cbrandin's safe 66M settings in order to continue filming. About two weeks ago I made a low light test with an older Driftwood GOP1 settings without any problems except for the spanning issue. I was surprised that a newer revision of the settings produced this level of problems. I was using a Transcend SDXC 64GB card which was formatted after every time I downloaded the footage. I am not sure whether the problem lies in the nature of high bandwidth settings. If so they might be useful and exciting for hobby filming, for any serios, meaning unrepeatable filming it should not be used. Let me know if I can help with any further information regarding the problem.
@driftwood, man Ill donate whatever you want... I just finished shooting a short film "Dawn" in all Intra... all Ive ever shot is driftwood settings... Ill put together some of my favorite shots and send them to you do you have a bigger dropbox then I do, otherwise well have to do them one at a time, also is this going to be a reel with music? or do you need me to sync up the external Audio from my sound guys?
@driftwood I will upload my footage this week. I shot around 3 hours of footage with your GopStoppa and reAQuainted patches this week in the Rotterdam Zoo. Pure magic.
Hey guy's just did a Remake of "Without You" Using @driftwood Gop1 ReAquanted patch. All I can say is this patch is F...ing insane.. @bkmcwd@proaudio4@PerryWilson Shot it @ ISO 640, shutter 50th, Lens pani 20mm f1.7 & Yes color graded
